Question about CDA CI392 Front Load Washer
CDA BI 1200 WD
Washing machine drum will not go round.  Does it need a new belt?  If so, where can I get the part ?
Cda ci394 will not fast spin
Posted on Feb 14, 2009
It could well be the brushes on the motor, take them off and check them (ensure spring still intact and both are making good contact), put them back in, if it begins to work then it'll be the brushes not contacting porperly.
Posted on Nov 03, 2007
Do I need a new belt or Service. the drum still turns but out of round
Out of round? Do you mean off centre, If so it sounds more like bearings than belt. Belt connects drive motor to drum but nothing else
Jan 11, 2018 | Washing Machines
My becko wma150w washing machine fills and but the drum doesnt go round
Motor brushes need replacing. check belt tightness too
May 19, 2012 | Washing Machines
Washine machine not spinning
It sounds like a snapped belt or a broken motor. Can you here the motor run? You can access the motor and the belt from the back of the machine. If it is the belt snapped, this is easy to replace yourself. If it is the motor, you will need a repair man.
Jul 17, 2010 | Bosch Washing Machines
Drum not going round
Hi Friend,
welcome to fixya....
may be the drum belt is the fault, Here are some possible causes of a washing machine belt coming off :-
1.The drum pulley is loose
2.The drum bearings have gone (collapsed) causing the drum pulley to wobble
3.The drive belt was to slack
4.A motor fixing bolt or bracket securing the motor to the tub has broken or come loose
5.Water has got onto the belt causing slippage
6.An obstruction or item of clothing temporarily jammed the drum causing the belt to spin off ,,,,,,,,,,,,
first check whether it is hard to turn the drum if not then check the above situations,,,ok
if you think that i helped you please rate it\\\\\\\\
thank u...
Apr 03, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Drive belt came off spindle on Hotpoint First Edition Washing Machine.Have tried to replace but back of machine does not remove, just a small access hole. How can I refit a new belt please??? John Bennett...
Remove rear panel, remove top cover,.tilt washer forwards, get someone to hold it for you, and fit belt round motor pulley first, then start feeding it round drum pulley, easing drum round at same time, it will be tight, so watch you fingers,
Please rate my solution.
Thanks.
Sep 13, 2009 | Hotpoint First Edition FEW12 Front Load...
Fitting new belt
Remove top cover and lower rear panel of washer
With some help, tilt washer forward, and fit belt round motor pulley first,slowly ease belt onto drum pulley and feed slowly round, turning pulley at same time, it will be very tight, so watch your fingers, you can align the belt after it is fitted. Please rate my solution.
Thanks.
Aug 19, 2009 | Washing Machines
FAN BELT
It can be done from the top, but it is awkward.
Remove top cover, and tilt washer towards you , you may need someone to hold it steady for you.
Reach down inside washer and slip belt over motor pulley, then start to feed belt over drum pulley guiding it round the pulley, at the same time turn drum with pulley gradually feeding the belt around..
The only other way is to remove the rear half of the cabinet, this is quite an involved job.
Good luck.
Plz rate my soution.
Thanks.
Jan 24, 2009 | Zanussi ZWF1430W Front Load Washer
I need to change the drive belt on a Tricity Bendix 1200 washing machine. I have got the top of and can see the hole at the bottom of the machine but can't reach where the belt fits.
the belt goes round the motor spindle at the bottom. tape belt to large pulley. tilt machine backwards and put belt over motor shaft and tape into position. start belt onto main pulley and turn it so belt eases on. it is a tight fit
Jul 22, 2008 | Washing Machines
My Hotpoint Aquarius WF210 washing machine drum is not rotating
I think the belt has come off or has been damaged.
To open the machine slide out the machine. On the back panel lower 1/3 you will see a plastic panel remove the screws and the panel will come away. Inside you will see the belt. I suspect you will need to reattach the belt of remove it and buy a replacement.
Sin é
Jan 13, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Hoover Premier 10.1 kg washing machine
do you actually see the motor spinning? or think you hear it, check the belt hasn't come off, or gone slack, it needs to be fairly tight but not too tight, if the belt and pulley go round but the drum doesn't then you have serious damage and need a new inner drum hope i have helped and if i can help more get back to me, i am an appliance engineer of 20 years
Oct 05, 2007 | Washing Machines
CDA CI392 Front Load Washer Logo
839 people viewed this question
Top CDA Washing Machines Experts
Marvin
Marvin
NOEL
NOEL
ray gallant
Are you a CDA Washing Machine Expert? Answer questions, earn points and help others
