Question about Spinmaster Air Hogs CHLD Twin Thunder
Servo doesn't move properlly
Hello!
I bought a tandemz-1 which is exactlly the same thing as the Twin Thunder in the US. On the second day the heli's servo didn't move properlly. And it started shaking. I couldn't return it because I broke a part of the body and scratched the paint a lot. Yesterday I opened it and saw NO visible mechanical damege. All the gears were in place and nothing seemed to be wrong. Can you pleace help me fix it! Please!
  • 3 Answers
Ok it was the potentioameter. There is a metal pin going in it. If they et detached that happends. Glue them and it flys again! Good luck!
Posted on Jun 09, 2009
Two of the remote control cars we bought are broken
Sorry but these are very cheap and no parts are made for repair.
May 05, 2017 | RC Thunder Tumbler Rc Car
1997 Yamaha YZF Thunder ace 1000 R EXUP valve not working
Hi, Rosiemowatt1 either that or a wiring issue for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "Free" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Exup adjustment on the Thunderace replacement of cables and lubricating...
Thunderace Exup valve check
Yamaha YZF R1 1998 Service Manual
OEM parts for Yamaha
YAMAHA YZF1000R Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 06, 2011 | 1997 Yamaha YZF Thunder ace 1000 R
Hi i have a futaba gy401 gyro with a s9254 tail servo, i had a crash and since then my tail servo constantly wags from left to right every time i switch on heli, i have tried putting the gyro on another...
Hi
If you put the gyro on another helicopter and have the same problem then you'll need to replace it. I've tried repairing these in my lab but just not worth the effort. Good luck
May 02, 2010 | Toys
Need charging instructions for Air Hogs Havoc heli. Is remote control switch to be turned on during charging? What position is channel switch in? Is Heli on/off switch set to charge? I have no...
1.Take out charging wires. 2.turn off your heli and insert charging socket into your heli's socket. 3.the charging green light will light up while charging. 4.charging complete, the green light will turn off. 5.pull out the wires and you are ready to fly. Let the heli's battery cool down for approx. 15 minutes before charging.
Feb 19, 2010 | Spinmaster Air Hogs Battling Havoc R/C...
For my mac g4 first generation, i bought a Ati radeon 7000 PCI. the goal was to stop using my original graphics card and use the ATI radeon 7000 for my main and only screen but when i start up with my...
hello...the way is try to open the Bios Settings then disable the on board video then set primary AGP/PCIE slot Video Card to run then try again to install the video card driver but 1st you need uninstall the old driver..thanks and Good Luck..have a nice day..^_^
May 12, 2009 | IXMicro ix3D Dual Monitor (8 MB) Graphic...
Crashed blade 400 repaired it unsure of servo settings helicopter tilts forward and tends to spin around
Try setting gain on Gyro (use small plastic screwdriver) to a straight up and down position.
Set Gyro setting in Transmitter to 75%. NOTE: before turning on helicopter, be sure to center all adjustments on transmitter
Side switch on GYRO to DS and make sure the servo is moving in correct direction. If not. reverse direction with switch on side of Gyro. You may need to reverse the controller of Rudder in settings on transmitter.
This worked for me on my Blade and using the same Gyro on a self build 450 heli.
Helimangler
Apr 20, 2009 | E-Flite Blade 400 3D RTF Electric Mini...
Bee King 2 spins in anti-clockwise direction.
Go to www.helifreaks.com to get solutions to all your heli problems and questions.
Mar 25, 2009 | Esky Honey Bee King 2 RC Helicopter
Linear servo retainer replacement for e-flite mcx
It isn't a great solution, but i was able to get one of these retainers back on. Using only the screwdriver in the kit, and my thumbnail. Try to work in a well-lit, clean area, so if the retainer gets loose, you can find it. Should be obvious, but Make sure the power is disconnected to the heli
--Heli Dis-assembly--
First, disconnect the two servo pushrods from the swashplate. Unless you want to replace the swashplate, be careful not to break the connecting ball off.
Second, disconnect the two motors from the control unit. Be mindful of the direction they need to be reconnected (white/black on outside, blue/orange on inside--in that order)
Third, using the provided screwdriver, remove the two screws holding the control unit on the heli. pull it off the chassis, but be mindful of the Antenna wire. I would try not to bend this more than you have to.
-Retainer installation-
Fourth, lay the control unit on the clean flat surface, pull the servo gear shaft slightly out of the unit until it is flush with the plastic.
Fifth, Carefully drop the retainer next to the servo. Using the tip of the screwdriver, apply enough pressure to the retainer to guide it up the plastic to match the hole with the shaft.
Sixth, Apply gentle but firm pressure upwards on the gear shaft. this should push the retainer onto the shaft just enough for it to hold on.
Seventh, using your thumbnail on one hand, and the tip of the screwdriver with the other, apply pressure to both sides of the retainer to slide it down the shaft. *NOTE* This is where i had the retainer flip off the gear shaft multiple times, only to have to repeat steps 4-7.
Eighth, Begin re-assembly in reverse order from steps 1-5. Reattach the canopy, and power, and attempt flight. If it spins uncontrollably, make sure that you have the motors hooked back up in the correct polarity (otherwise it spins in the opposite direction)
NOTES--
-Tiny tweezers don't seem to allow for enough force to push the retainer onto the shaft
-A standard screwdriver of comparable size to the provided phillips head screwdriver may allow for more pressure to be applied
-The retainers like to spring off of the shaft when pressure is applied in the wrong place-- hence the clean surface to find them when they do.
-I can't seem to find anywhere that sells only the servo retainers, so if you lose them, you may need to purchase the entire servo assembly. :(
-I know check these retainers as both pre and post flight checks to ensure that they are securely into place. They seem to like to pop off during very hard collisions (which is how mine came off)
Jan 24, 2009 | RC Toys
Spinmaster Air Hogs CHLD Twin Thunder Logo
91 people viewed this question
Top Spinmaster Toys Experts
ray gallant
Terry
Terry
Are you a Spinmaster Toy Expert? Answer questions, earn points and help others
