I have an Ipaq rx 3115. When i got into my settings it lists my AC only has the main battery and the NIMH as the backup. It does show that my NIHM has 100% charge but it will not work when i unplug it from the AC plug in. Is there a way i can change my NIHM to the main battery and my AC to the backup. It says main battery is AC only, it never get charges. Backup battery charges to 100% but when we unplug device is without power. If we re-plug it then it reboots again, but without RAM data. We have to start every thing from scrach. To work with it we have to plug it always like PC.
You need to purchase a new removable battery for your RX
The removable batts usually only last about a year (like cell phone batteries).
Although it is showing 100% charge, the battery is not storing enough power to run the ipaq
The rx series uses 2 batteries, one is the removable one u can see/access when u remove the back cover. The other batt is a small round batt which stores the basic info for your system (so you don't lose your data when u swap out the removable battery).
This small (backup) batt is similar to the cmos battery on a laptop or pc.
You cannot easily replace this, as the unit needs to be disassembled to access this batt.
If you are tech-y (and brave), the replacement button batteries are sold on ebay for $9-12
Normally, if your removable batt is bad, you could still use your unit plugged in, and could
remove from AC power without losing data. Not the case if your replaceable batt is exhausted.
When both batteries are bad, you lose everything when u remove unit from AC power.
My workaround without having to disassemble unit:
Purchase and fully charge new removable batt (They have huge capacity ones available for like $15 - better than the original !).
Load up all your programs & settings the way you like.
Perform full backup to SD card (& also on PC via active sync - to be safe)
Now the only time you should lose your data (like hard reset) is if you allow the battery
to completely drain, in which case you can restore your backup.
If you purchase 2 removable batts, you can easily swapout without losing data if you
use the usb charge cable & leave ipaq plugged in while you change battery
My iPAQ rx 3115 will not turn on. I left it in my briefcase but now it just does not start. I did a...
(More)
My iPAQ rx 3115 will not turn on. I left it in my briefcase but now it just does not start. I did a reboot, the initial screen appeared, then it frozed and then it just went blank. The battery was fine but the iPAQ just won´t turn on. I returned home and immediately plugged the AC charger and nothing happened. Something similar happened a couple of weeks ago while I was outta my house and as soon as I returned home I plugged the AC charger and the LED that indicates "battery charging" started blinking, so it worked that time, but today it just does not work.
What can I do? I had a lot of stuff there that I need to access...urgently. Please help. Thanks a lot.
my HP iPAQ rx3115 continues to reset after a hard reset. How do I stop it from the continuous reset...
(More)
my HP iPAQ rx3115 continues to reset after a hard reset. How do I stop it from the continuous reset loop
