Question about Tomtom GO 910 GPS Receiver
Two dead Tomtoms
Both my Tomtoms won't switch on. I've tried soft reset using all the techniques on various forums. Also tried opening and disconnecting battery. There's green lights on both when connected to mains. They also aren't detected by PC when connected to USB port so I can't reinstall. Any ideas welcome.
Fixed both of them by changing the batteries. Easy fix and didn't lose any data.
Posted on Jun 02, 2009
My tablet won't come on I've had it charging so the battery should be full is there something I can do?
try to hard reset or soft reset, for this procedure search on gogle.com how to reset tablet, that will be helpful.
Jul 02, 2012 | Coby Kyros 716829701508 Tablet PC
Singer confidence quilter beeps 8 times won't sew
http://www.singerco.com/uploads/download/549_7469_efs.pdf
http://www.singerco.com/uploads/download/683_7469_efs.pdf
here are 2 links for a free manual, you can choose which one you need
try changing the needle
if you just bought the machine,, you may have to take it back & get
another one
Jun 08, 2012 | Singer 7422
2000 gmc sirra won't start
Well stop looking on forums , most of those people don't have a clue ! Looking at a wiring diagram of the starting electrical circuit for your vehicle ,then testing for B+ voltage an good grounds where they should be is how to find and fix the problem , not guessing an listing to other people on forums . Something that fixes there problem was just lucky guess. By you saying it won't crank i take that to mean that when you turn the key to the start position nothing happens ? Is this correct ? A lot of people get that mixed up with the vehicle won't start a run . Do you know what a wiring diagram is ? What a DVOM -digital volt ohmmeter is ? How to use them for testing a electrical circuit .
What size engine does it have ? Is it a 4X4 ? Manual or automatic transmission ?
Free wiring diagrams here http://www.bbbind.com/free_tsb.html
Enter your vehicle info. year , make , model and engine size. Under system click on engine ,then under subsystem click starting Click the search button then the blue link. Look at the wiring diagram , a lot of thing's involved . Ignition switch ,park neutral safety switch if it has a automatic transmission , clutch pedal position switch for manual trans , plus the starter motor relay ,starter motor . This is how professional automotive tech's find and fix electrical problems , it takes year's of training to get good . Plus thing's change all the time .
Electric Testing Techniques You Need to Know
Sep 12, 2017 | 2000 GMC Sierra
Garmin forerunner 205 will not stay OFF and none of the buttons respond.
Yes you can restore your data from the TC after a hard reset. You have to go thtrough the setup menu like chose which language etc first.
Well I have exactly the same problem as you and a hard reset did not work either ...
Upgrading / downgrading the firmware also did not work.... the thing keeps on switching itself on regardless....
Do you have found out something more in the mean time?
Feb 16, 2012 | Garmin Forerunner 205 GPS Receiver
My Zen seems to be totally dead after loading it with mp3 tracks. I've recharged it to no avail, it won't switch on or reset, and it is not recognised by my computer when connecting via a USB...
hi your not the only one i got mine for my birthday 8 weeks ago and now it dont work its like its dead this zen v plus to is like not the best thing to have all i see is people like me having some sort of prob with it
Sep 20, 2011 | Creative Labs ZEN V Plus MP3 Player
My pandigital ereader won't connect to wifi all of the sudden. I've tried everything. The manual said to reset, and now it's dead. Can't get it to turn on. Any suggestions?
I rare case,the wifi module can disconnect for it socket.
It's usually cause by mishandling the unit.
If it's under warranty then you should send it in for repair.
====== The DIY method is to power off the unit.
Place a large soft towel on a table.
Place the display face down.
Apply GENTLY pressure (side to side and top to bottom) on the back of the unit.
PLEASE apply pressure gently!!!!!!!!!
With some luck,you will press the wifi card back into its socket.
Sep 11, 2011 | PANDIGITAL 7270FW Tablet
My old blueberry iMac won't come on. I've changed power cords and tried different keyboards. No lights come on. Could it be the power supply? If so, where do I get one and how easy to install?
This is usually due to the BIOS/Clock/CMOS battery dying. If the battery is dead, it won't start up at all.
Check out YouTube for instructions on opening your model, and replacement batteries are available at just about any Radio Shack, or online at various places. These guys may have them, too: http://www.headgapstore.com/
Aug 03, 2011 | Apple iMac Blueberry Mac Desktop
Monitor
Sylvia,
It's seems you had a stuck pixal... Turn your monitor off and try this tips: Wn't work in every case. It may take a few attempts to make sure you are pressing exactly on the dead pixel.These instructions will fix "stuck" pixels, not "dead" ones, like red, blue or green. An alternative, but similar technique involves gently massaging the stuck pixel with a warm damp soft cloth.Alternative technique to tapping: Using a rounded pencil eraser, push with moderate pressure into screen at stuck pixel.
Good lucks!
May 12, 2008 | LG Flatron 295LM 22" LCD Monitor
Tomtom GO 910 GPS Receiver Logo
235 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
