Question about NetGear DG834N Router (DG834N-100AUS)
Connection problem. shows limited connectivity and disconnects
I have a Netgear DG834N router (Roughly 2 year old), on the remote system, I can detect the wireless network, When i connect it, it take long time and connects with a limited connectivity. and finally disconects.,. all lights are green and flash. but no wireless service. Can you please help me with this issue.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 116 Answers
Limited connectivity means you didn't get an IP address. Is the router set to give addresses via DHCP, or is another PC doing that? Most common cause of this problem is wrong authentication (normally "open") or encryption type (WEP, WPA or WPA2). Pklease note that encryption keys can be set as HEX or ASCII, if they are HEX it will be only numbers 0 to 9 and letters A-F. ASCII can be anything.
Posted on Jun 01, 2009
I have a DG834N wirelss router, it has recently kept doping the netwrk connection both wireless and wired, the only way to overcome the problem is to reboot the router, any idea why or solutions?
Sometimes the ISP (Internet Service Provider) might have done something on their network that is causing it.
Try removing the power cord from the modem and the router. Then plug the power cord into the modem only and let it cycle up for about 2 minutes. Then plug the power cord into the router and let it cycle up.
If it still drops, then the router could be going bad.
Jun 07, 2012 | NetGear Computers & Internet
Netgear router problems
Disconnect wireless connection from laptop and connect it back, ensure that you are connected to your own wireless networ and thet the encryption key is correct.
Jul 22, 2008 | NetGear WGR614 Router
After firmware upgrade the no wireless signal and the router is not recognized by my laptop even if I connect it thru lan cable
You may have taken a bad update try factory default if you get in try to download from verified site new firmware
reset to factory default
press and hold reset button during the whole process and only release when completed.
1)press reset button 30 seconds
2)remove power cable 30 sec
3)plug in power cable 30 sec and then release.
You should no be set for 192.168.1.1
username admin
password is password
Apr 01, 2012 | NetGear DG834N Router (DG834N-100AUS)
After a good time in use a laptop cannot ''see'' the netgear wgr614 router, altho it detects other local wireless networks. Also, the cable connection informs me that there is limited or no connection....
Have you tried unplugging,and re-plugging in the router, that will soft reset it, and also at the same time, rebooting the PC? If no good, log onto the Router and check all the settings... Can you use another PC to "See" if that one can detect it OK?
Feb 22, 2010 | NetGear WGR614 Wireless Router
How can i access my router configuration to open port 3074?
Open any web browser, such as Internet Explorer or Mozilla Firefox. In the address bar, enter "192.168.0.1" and press the enter key. This will bring up the login prompt for most Netgear wireless routers. If that doesn't work, try "www.routerlogin.net", "192.168.0.5", or "10.1.10.1" until the login window appears.
Should be able to acces it from the web interface.
Dec 18, 2009 | NetGear DG834N Router (DG834N-100AUS)
Dg834n lost installation disk
Please note that Router does not require installation software for its configuartion. It can be configured manually using the below steps:
1. Connect the cable/phone line coming from Internet Service Provider to the WAN port of the router(isolated port).
2. Connect the computer to the router using any one of the 4 available ports.
3. Open the browser (Internet Explorer, Mozilla Firefox or Safari).
4. Access the router usually by typing 'http://192.168.0.1' or 'http://www.routerlogin.com' in the address bar.
5. Login to the router (username = admin password = password unless you have changed it).
6. Click 'setup wizard'(at the top of list) from left menu.
7. Select yes and click next.
8. It should give you a "PPPoA Detected" and then click next.
9. Enter the login and password of ISP click apply.
10. Once the settings are updated click on 'router Status' and click on 'connection status' button(at the bottom of the page).
11. Click on connect button.
12. Connecting to server should show 'connected'.
13. If you receive 'CHAP authentication failed', close the 'connection status' window and click on 'Basic settings'. Check the login and password for ISP and apply the setting again.
14. Open up another browser window and try to access internet.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Oct 27, 2009 | NetGear DG834 ADSL Firewall Router with...
Cannot connect to my Netgear WRG614 v6 router. My Dell laptop shows an excellent connection but it says limited or no conectivity???
if it says limited or no connectivity, it means that there are a couple of settings that needs to be configured for your wireless connection. click on start > run> connections> wireless connection >when you see your wireless network, try to disconnect from the network and try to connect again using the right wep key (if you have it enabled). or you can try checking the wireless properties. start > run> type in ncpa.cpl and hit enter. right click on wireless connection and click on properties. highlight tcp/ip and click on properties. make sure that the settings are set to obtain automatic. hope this one helps.
Jun 04, 2009 | NetGear WGR614 Router
One computer connected the other limited or no connectivity
When using a router your IP is assigned to your Router. Then Your router assigns IP's to whatever is hooked up to it. Set everthing to detect automaticly. Might delet connection and create a new one.
Mar 11, 2009 | SMC Netgear 5Port Gigabit Ethernet Switch...
NETGEAR ROUTER DG834N
please try to remove the powercable from the router and then plug it back in the router after 1 min ....
if it still doesn't work then try to reset it ... if the problem still prevails then u can contact on netgear customer care as they will provide u the replacement ....
Oct 22, 2008 | Computers & Internet
NetGear DG834N Router (DG834N-100AUS) Logo
249 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
