Question about Canon NP 6050 Copier
Paper pick up problem
My canon np4050 machine has 2 trays (folio and A4R). the paper is picked up from folio tray, but it has a problem with A4R tray to pick up a paper (jammed). Many local service engineers tried and got failure to solve this problem. please give me the correct direction to solve the problem.
SA Kannan
  • 30 Answers
Hi,try to clean feed rolls,sensors.clear any misfeed sheet from paper supply area.send me a result.
thank you.
Posted on Jun 01, 2009
Canon ir3300 showing paper jam in 2nd tray but thre is no paper jam in it
  1. Locate and dust your paper sensor eyes
  2. make sure paper size adjuster for tray 2 is locked at proper position.
  3. Examine pick up roller from tray 2, clean or replace as necessary.
Mar 12, 2015 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
Full page is not copied
Hi, did you place paper in tray also horizontal? the paper in tray and on glass must be horizontal if you want to copy A4R size.
DO NOT forget to adjust the blue paper size indicator on paper tray to A4R also.
Also under user mode, under copy sett. you can find option for auto rotate, so copier will adjust size automaticaly.
Jul 17, 2010 | Canon iR 2016i Black and White Copier
Canon IR 3300 model - Paper Load Liver problem in second tray
The tuck tuck sound is sound of paper pick up claw in pick up mechanism of second paper drower.The case is that the pick up clow is worn out and may be broken, so you need to replace it.To replace it you must remove complete pick up unit from the right side of copier, if you are not service technician do not do it by yourself it could be complicated if you do not know exact schedulle of parts and what does it doing.
Nov 12, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Samsung Scx-4216f wont pick paper out of drawer
Below would be the suggested solution regarding paper feeding problems;
If Paper does not feed into the machine.
• Remove any obstructions inside the machine.
• Paper has not been loaded correctly. Remove paper from the
tray and reload it correctly.
• There is too much paper in the paper tray. Remove excess
paper from the tray.
• The paper is too thick. Use only paper that meets the
specifications required by the machine.
Below is the suggested paper specifications;
Supported Sizes of Paper
Paper Dimensions* Weight Capacity**
Letter 8.5 X 11 in. (216 X 279mm)
• 60 to 105 g/m2 bond (16 to 28 lb) for the paper tray
• 60 to 120 g/m2 bond (16 to 32 lb) for the Bypass tray
• 250 sheets of 75 g/ m2 bond (20 lb) paper for the paper tray
• 1 sheet of paper for the Bypass tray A4 210 X 297 mm (8.3 X 11.7 in.)
Executive 7.25 X 10.5 in. (191 X 267 mm)
Legal 8.5 X 14 in. (216 X 356 mm)
Folio 216 X 330 mm (8.5 X 13 in.)
Hope this helps!
Sep 10, 2009 | Samsung Office Equipment & Supplies
I have a canon image class d680. the machine no
Have you tried to clean the pick up rollers with a rag with a small amout of WD-40 or Simple Green. Clean the roller then whip off with a dry rag. If the problem improves you need to replace the pick up rollers. If not you may have to replace the paper feed clutch. Also, look to see if the seperation pad is ingaging when the paper tray is pushed in. Open the left side door. I've seen the actuator break. Also, have you tried to use the manual feed tray???? I know you made sure the paper guides in the paper tray are set correctly for the size paper in the tray??? Good Luck
Feb 26, 2009 | Canon Office Equipment & Supplies
Paper won't load from both cassettes
is the copier seeing the paper in the cassette, if yes then your pick up assy. connectors could be loose or your pick up assy s. are bad. try switching the assy first before replacing also check your connectors
Jun 19, 2008 | Canon CLC 1150 Color Copier
Unexpected message: 6B22
That is a pre heater fault.
Preheater exit sensor in unexpected state during fault.
Preheater exit sensor in unexpected state during stage.
  1. Check system grounds.
  2. Check the Drum Maintenance Kit NVRAM contacts during oiling for continuity.
  3. Check the waste tray.
  4. Replace the Preheater ( REP 2.0.17).
B2M
B2N
B2P
B2Q
The preheat flag tripped unexpectedly while picking paper from Tray 2.
The preheat flag tripped unexpectedly while picking paper from Tray 3.
The preheat flag tripped unexpectedly while picking paper from Tray 4.
The preheat flag tripped unexpectedly while picking paper from Tray 1.
  1. Test the Preheater Sensor using Service Diagnostics.
  2. Check system grounds.
B3M
B3N
B3P
B3Q
B3S
B3T
The preheat flag timed out waiting for the paper picked from Tray 2.
The preheat flag timed out waiting for the paper picked from Tray 3.
The preheat flag timed out waiting for the paper picked from Tray 4.
The preheat flag timed out waiting for the paper picked from Tray 1.
Preheater sensor timed out during stage.
Apr 17, 2008 | Xerox Phaser 8200 Laser Printer
When Tray 1 (A4) is empty it is picking up Tray 2 (A4 ? letterhead) and we don?t want that to happen cause we print in bulk! When Tray 1 (A4) is empty it is picking up Tray 2 (A4 ? letterhead) and we don?t...
Hello Uncle123,
I don't have a user manual at my fingers, but you can go into "additional functions". I don't recall if it is within the"common settings" tab or "copy settings" but you can designate any paper tray to be "unique". For example you can designate tray 2 as "colored paper, or recycled paper" .In which case, if you are feeding from tray 1 and it runs out the copier now knows that tray 2 has a type of paper that is different than the current run.Even if the paper size is the same. I hope this helps. Take care. ..............................spinal.........................
Feb 22, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Canon NP 6050 Copier Logo
142 people viewed this question
old marine
old marine
