Question about Kitchen Appliances - Others
Subtle breadmaker belt totally perished
Hi there,ive got a subtle mbj 20c breadmaker need a belt its totally perished
My afk breadmaker blade suddenly stopped turning
Most likely needs a new belt... Do an online search for "bread machine parts" (with your model number).... Most bread machine belts wear out after a couple of years even if you didn't use the machine very often because the belts dry out and start fraying over time... We've changed numerous belts on lots of different bread machines and most belts are very reasonably priced and very easy to change... Shop around for prices... I have seen some places charge double.. so make sure you do your homework before ordering a belt...
Hope this helps,
Regards,
Linda
Jan 27, 2015 | Kitchen Appliances - Others
Unable to print X or Z Report
Could be you've a couple of busted RAM chips there. Have you ran a diagnostic?
May 11, 2014 | Samsung Sam4s ER-5240M Cash Register
Breadmaker belt purchase
Hi, If you have your old belt, most of them have a code written on the smooth side of the belt. Email me that code and I'll see if I have that belt in stock. The code will looks something like this: STS 60 SRM 471 My email is daryl441@msn.com
Apr 27, 2013 | Kenmore KTR2205SPR Bread Maker
Hi i have a Sunbeam Oster Company Automatic Bread maker Model 4839 For household use only Style BB 100 and ive had it for quite a few years. I havent used it in quite a long time also. I want to start...
nvm some other site gave me the instruction manual and its working great! I just made 10 pies and sold all of them for a total of 150 big ones! phew...i thought i was gonna need a new one! the inspector even thought it was brand new...Thanks for nothing fixya.com ^_^...you guys ****...-_-'
Sep 02, 2009 | Kitchen Appliances - Others
Need a belt for K6725 breadmaker bjc
Hi, I have the same machine and the belt was in tiny rotten pieces...I wound a piece of yarn around the wheel and drive shaft (lie the machine on a kitchen counter, lid open and hanging down off of the counter, bottoms up, and remove the screws from the teardrop shaped brass colored safety cover, remove the cover and expose the wheel and drive shaft) pull the yarn tight and knot it. Then cut the yarn about an inch from the knot. Measure the yarn when pulled on a little. Mine measured 23.5"....I then googled bread machine belt 23.5" and up came one for an Oster Bread Machine (The one I was repairing was a Regal Kitchen Pro 6725) from totalvac.com located at 2 De Bush Ave Unit A8 Middleton, MA 01949
It was $7.95 for the belt, $6.95 S & H to a VA address, total cost $14.90 so I decided to give it a shot. When it got here, I removed the safety cover, held the machine up and shook as much of the old rotten rubber belt pieces out as I could, and replaced the belt by placing it over the sticky string on the drive shaft and teasing it over the wheel. It is an exact fit. Be sure the ribbed side of the belt is down against the wheel. Screw the cover back on and run it through a dough cycle so that the belt will get coated with the sticky stuff from the sticky string on the drive shaft. Until the belt is coated, it will turn the mixing blade, but it will slip. Hope this helps. Patti
Patti Wilson
September 2009
Aug 04, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
Magic Chef Breadmaker CBM250 - Manual
use a 25 inch O-ring 1/8 th inch dim.
it works as the belt
May 23, 2008 | Kitchen Appliances - Others
Pacific breadmaker pb-001 i need the instructions
If you require instructions for a Pacific PB-001 Breadmaker go to
www.askjack.co.uk/objective/content/view/154/a
Then just print off what you want!!!
May 18, 2008 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
49 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
