Temp control r0500 air conditioner settings Why does my air conditioner stop blowing cold air (its not the air filter)?
    Novelist:
  • 166 Answers
There are a variety of probable causes of your AC's failure to blow cool air. Unfortunately, it is difficult to diagnose your situation without being there. However, I have a great, handy diagnostic article that specifies the main problems so that you can definitely come to find the cause applicable to your AC's failure. You AC may need a recharge of refrigerant/Freon by a technician, but short of that, try this first:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Does_Not_Cool.htm
This should defintely help.
Brad
Posted on Jun 01, 2009
Temp Control Problems
Hi, hild, first thing; stop the AC by remote controler, than select the fan option pressing by mode button and next start the AC, wait 8 minutes, if the unit still blows cold air, the thermistor has to be replaced. I hope this was helpful to you! success!
Jun 12, 2013 | LG Art Cool LA181CNW Split System Air...
My air conditioner runs but it is not blowing cold air anymore. it is a Friedrich room air conditioner QStar. Help
1. check the filter and clean it while your at it. 2. check to see if it iced up and if so thaw it out and set the temp a bit higher. close all rooms not in use. my guess is it is iced up because of a dirty filter.
Jul 19, 2011 | Heating & Cooling
Heat stops aprox 10 degrees before it gets to the set temp and then it just blows cold air.
Try new air filter.Maybe going off on hi temp limit control ? Short run time.
Jan 05, 2011 | Honeywell TH4210D1005 Heater
LG neo plasma air conditioner does not blow cold air
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 04, 2011 | LG LS-J0910HL Heat & Cool Mini Split Air...
Hampton air conditioner. When I turn it on it blows out cold air but after about an hour the blowing stops.
Check your control setting if it is an electronic one. Check thermostat / thermistor. If the fan stops check the fan relay. Could be controller problem also. Take assistance from service provider.
May 26, 2010 | Hampton Bay HBLG5004 Air Conditioner
Honeywell T8112 Air Conditioner Will Not Cool, But Blower Works
make sure the system switch is in the cool position, then press run program button and allow a couple of minutes for system to cycle on, if it doesn't come on press the button for lowering the set point, set it to 72 degrees and then press the hold temperature key.
May 27, 2009 | Honeywell ER150B Air Conditioner
Sometimes it blows cold, sometimes it doesnt.
The coils that are located right behind the filter need to be cleaned extremely well. You can purchase a spray from your local hardware dealer that can clean the coils. Also, rinse the fins at the back side of the unit as well. Dirty units can cause this to happen. If you clean it and it continues, you have developed a refrigerant leak. Since window units are so inexpensive today, it is not cost effective to hire someone to come out and find and repair it. Hope this is of help to you.
Apr 11, 2009 | Frigidaire FAC052K7 Air Conditioner
Heating & Cooling Logo
99 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
