Question about Hoover F8100900 Upright WetDry Vacuum
Hoover f8100900 will not suction
We have a Hoover F8100900 which is about 3-1/2 years old. I had used it about a month ago, and although it was nosy, it worked well. When I tried to use it yesterday, it was again noisy, but now it does not suction the water with the cleaning solution back up into the dirty water tank. Any suggestions?
    Top Expert:
  • Hoover Master
  • 47,765 Answers
Tank possibly is not properly seated .
Posted on Jan 12, 2018
    New Friend:
Here is a site which will guide you through possible causes that are causing the problem with your vacuum and help you pin point the correct one. Hope this helps. https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Vacuum-Cleaner/113-203--/Hoover-Vacuum-cleaner-won-t-pick-up-no-suction
reddevil6
  • 1673 Answers
SOURCE: hoover steam vac clean surge
The recovery tank lid isn't locked down all of the way around. The foam filter on the inside of the tank lid is up too far, needs at leasat a 1/4 in gap from the top. The filter screen by thye indicator is clogged. Some have a duct that sits in front of the recovery tank, either it isn't there or not pushed down all of the way.
Posted on May 15, 2008
SOURCE: hoover steam vac model F5853-900 series 17.9
Make sure that the recovery tank is completely close.
Posted on Jan 20, 2009
SOURCE: recovery tank not working
recovery tank empty where do you look to see where the hair ball is so i can clean it
Posted on Apr 04, 2009
SOURCE: Hoover Steamvac hose won't spray water
http://www.hoover.com/pdfs/manuals/F5914900.pdf
Before using tool
It may be necessary to remove air from
the system (“prime the pump”) so the
clean solution will flow to the tool. Follow
these steps:
1. Attach tool to hose and turn the carpet
cleaner ON.
2. Put the tool on a hard surface or
against your hand to block off the suction.
3. Wait a few seconds (can take up to
15 seconds). Then squeeze the trigger
and begin cleaning.
GOODLUCK!!!!
Posted on Jun 21, 2009
  • 190 Answers
SOURCE: Hoover Steam Vac V2 Deep Cleaner leaking clean water
Fill the tank and determine if the plastic is leaking, or if the valves are leaking. if the tank is cracked, it would need replaced. There is an improved design now available.
You may cycle the valves on the bottom with the eraser end of a pencil.
Posted on Oct 03, 2009
I have a 1 year old Hoover carpet cleaner . I went to use it today and it won't start. Everything seams to be in the right position. can't figure it out..
Dual Power™ Carpet Cleaner - Hoover
hoover.com/products/.../dual-power-carpet-cleane...
The Hoover Company
Rating: 3.5 - ‎84 reviews
Dual Power™ Carpet Cleaner. Easy to Empty Tank ... You currently don't haveany recently viewed items. ... 3.5 out of 5 stars. ... The Hoover Dual Power™ Carpet Washer deep cleans on the double. ... 1 Year Limited Warranty .... The rinsing stage is a must and it cleaned a 20 year old carpet that was badly stained.
Hoover SteamVac Troubleshooting: Carpet Washer Loss of ...
? 1:19
https://www.youtube.com/watch?v=6TkcWjuz1zw
Aug 16, 2013 - Uploaded by Hoover
Your SteamVac carpet cleaner should pick up as well today as the day you got it. If you're experiencing loss of suction or noticing that your SteamVac won't . ... Hoover 1 year ago ... thank you! worked and i did not have to wait for call center to open! thank ...This machine is running well almost four years in.
Repairing a Hoover Carpet Cleaner ' ThriftyFun
www.thriftyfun.com/Repairing-a-Hoover-Carpet-Cleaner.html
I have a Hoover f7412900 carpet cleaner and one day the brushes stopped working. ...It was a couple years ago, so I don't quite remember, but it was in the manual, ... Itwon't start back up. ... If it is only 5 months old, it is likely still on warranty. ... Do not try to fix this yourself, as you may void the warranty if you start taking ...
Jan 29, 2016 | Hoover Vacuums
Download hove maxextract floor finishers model
Hi! Follow the link to view the owner's manual for the Hoover F8100900. http://hoover.com/file/622/
Thanks!
Jul 07, 2014 | Hoover F8100900 Carpet Cleaner with Max...
I have a Hoover Windtunnel UH70212. Just a few months old. I used the attachments a while back and now there is very little suction. The power brush attachment doesn't work at all. Any suggestions?
If there is no suction, there has to be a blockage somewhere in the dirt path. You should hear the motor working a little harder in this condition. Please check the entire dirt path from floor to exhaust (clean all filters too) to find the obstruction.
Thanks for your question @ FixYa.com
Mar 13, 2011 | Hoover U8341-900 WindTunnel 2 Bagless...
I have the same problem as discussed above. My Hoover Pet Cyclonic upright stops working while using it. The bottom feels hot when this happens. When it first occurred, I emptied the canister and even...
The vacuum is probably getting hot and the thermal sensor in the motor is shutting it off and then allowing it to come back on after it cools down. You mentioned replacing the secondary filters, replace the exhaust filter too.
If replacing all the filters did not solve it you may have a clog or restriction somewhere causing the loss of suction and the overheating.
Mar 09, 2017 | Dirt Devil Hoover Uh70085 Pet Cyclonic?...
Floormate stopped vacuming water
I'll answer last question first. Your floormate has a 1 year warranty. And should be taken in for repair.
Your issue of not picking up water, is related to suction and getting the dirty water to the recovery tank. check for obstruction in the nozzle, check the filter for debris clogging. If you have an issue with this dealer I would call customer support.
Sep 26, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Windtunnel spits dirt back out the back
Your problem sounds to be an obstruction in the foot (lower body) of the windrummel. Most all windtunnel's have a second cavity for suction to go over the top of the roller. When you remove the bottom plate, next remobe the belt and roller, under the roller will be a removable cavity, take it out. remove the dirt and clean out any debris. also check the suction path connecting hose. if your belt has not been changed in the last 12 months, I would recommend changing that as well.
Jan 17, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover not performing
proberly a blockage .Any new product is covered for 12months waranty.hoover also comes with 5 yrs parts waranty.
Aug 31, 2008 | Hoover Vacuums
No suction on Hoover Wind Tunnel.
Greetings from GoVacuum.com,
First this is a common problem on ALL bagless vacuum cleaners. Usually it takes longer then 1 day however.
Is there no suction in the suction hose, or is it not suctioning from the floor?
Most people buy a bagless vacuum once, then return to a bagged one after their bad experience, you are not alone!
Please give me the model number to your Hoover, (found on the bottom or the back of the vacuum on a foil label).
Thanks,
Chris Jones
GoVacuum.com
1-866-468-2288
chris.jones@govacuum.com
Aug 18, 2008 | Vacuums
Hoover Light on
ALTHOUGH MOST FILTERS SAY WASHABLE THEY DO STILL NEED TO BE REPLACE AS WASHING THEM SHRINKS THE FILTER AND EVENTUALLY CLOSES THE AIRWAYS. WHICH ALSO IF NOT REPLACE WILL OVER HEAT MOTOR IN MACHINE AND CAUSE MOTOR FAILURE.
Mar 27, 2008 | Vacuums
Hoover F8100900 Upright WetDry Vacuum Logo
35 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
