Question about Canon imageRUNNER 5000 Copier
Accessing ir5000 engineers console
Does anybody know the keypad sequence to get into the engineers console?
I have to ir5000 in different locations in the building. One is jamming all the time and I'd like to see the humidity readings.
TIA
  • JayMax Nov 02, 2007
    Thanks for taking the time to reply flopez. When the Canon engineer was at my office last he showed me in the copier console that the location was humid (~30%) on the display, and that was the cause - the paper is stored next to the copier. I'll have a look at that code on Monday, thanks again.
  • 3 Answers
The correct procedure to enter engineer mode is additional functions (head with a star in, to the left of the number 7 key) 2 and 8 at the same time...then the head with the start again.
Hope this helps.
Posted on Nov 22, 2007
  • Canon Expert
  • 270 Answers
I'm sorry but flopez is wrong about getting to service mode. Press the additional function key, the 2 & 8 keys at the same time, and then the additional function key again. Select copier, then display, then analog. You should see, I believe, 3 readings. HUM is what you want. But flopez is correct - if the paper curls alot after a copy then the paper is too damp.
Posted on Nov 17, 2007
  • 161 Answers
You do not need humidity readings. If the copied paper curls at the edges as soon as it comes out of the unit, the paper (not the copier) is humid. Besides, there are no humidity sensors on the copier. There is a humidity switch to reduce humidity, but no sensors to notify any levels.
Anyway, the code is: 5,8 (simultaneously) - ADDITIONAL FUNCTIONS - 5,8 (simultaneously) - ADDITIONAL FUNCTIONS.
Posted on Nov 02, 2007
Firing sequence
There are various sequences depending on the make and model and how many cylinders there are. To make matters more complicated each sequence starts from number one cylinder but different manufacturers move the location of number one around - some even place the timing cylinder at the back of the engine...
Apr 03, 2017 | Cars & Trucks
The smart wash light on my kenmore elite model 66513753K602 is flashing. I have tried the suggested button sequences to reset it and they have not worked. How do I troubleshoot it to determine which...
From the tech sheet:
CHECKING KEYPAD
OPERATION
A rapidly blinking LED over
one of the keys of the keypad
(or sometimes a "dead"
keypad/console) indicates one
or more key switch lines are
stuck or shorted on either the
control or the keypad. To
determine if the control or
keypad is faulty, do the
following test:
1. Unplug dishwasher or disconnect
power.
2. Open the dishwasher door.
3. Open console and disconnect the
keypad ribbon connection from
the control (at P1). Make sure all
other connections are made.
4. Put console back together. Do not
close the dishwasher door.
5. Plug in dishwasher or reconnect
power.
6. Wait 5 seconds.
7. Close dishwasher door.
8. Monitor the control's response:
? If the control is OK (no longer
sees shorts with the keypad
unplugged), it will respond by
turning on a Drain Motor for
2 minutes. Check and/or
replace the keypad if the
control responds OK.
? If the control is not OK (still
unplugged), then the drain
motor will NOT respond and
will remain off. If no response,
replace the control.
Jan 21, 2015 | Kenmore Dishwashers
Workshop manual for a 1994 nissan serena
Cylinder head bolt torque sequence
The Rod Bearing Cap Torque
The Main Bearing Cap Torque 38 Foot pounds (Final torque)
Step 1: Torque 10-12 Ft/LbsStep 2: Torque 17-21 Ft/Lbs
Note :
Torque sequence ------------------------
' 11 '
front ' 13 9 3 1 6 8 '
of ' '
engine ' 14 7 5 2 4 10 '
' 12 15 '
Step 1: Torque all bolts in sequence 22 Ft/Lbs
Step 2: Torque all bolts in sequence 47 Ft/Lbs
Step 3: Loosen all bolts in reverse sequence
Step 4: Retorque all bolts in sequence 22 Ft/Lbs
Step 5: Retorque all bolts in sequence 43-51 Ft/Lbs
Step 6: Retorque bolts 11 thru 15 in sequence an
additional 4-6 Ft/Lbs
** CAUTION ** This engine uses 2 different length head
bolts. "#1" Is the long bolt, while remaining bolts
are short. **Do not confuse location of these bolts**
recheck final torque in sequence
Dec 06, 2012 | Cars & Trucks
I need to know where the timing marks are on a 96 4wd isuzu rodeo. CAN ANYBODY HELP ME PLEASE?
  • I hope you get this, I was going to go to bed until I noticed how bad you were needing some timing marks :)
  • Injection pump and camshaft alignment marks-diesel engine
  • Tensioner pulley bolt sequence (diesel)
  • Crankshaft sprocket timing mark-2.3L and 2.6L engine
  • Camshaft sprocket timing mark-2.3L and 2.6L engine
  • Timing belt installation sequence-2.3L and 2.6L engines
  • Timing belt tensioner lockbolt-2.3L and 2.6L engines
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 06, 2011 | 1996 Isuzu Rodeo
My craftman 139.52606 opener does not have a learn button to set pin on keypad. I had keypad working at one time but since I changed the battery I can't rember how to reset the keypad.I also changed...
If the keypad is hardwired, do this:
To program the keypad, first unplug the garage door opener from the electrical outlet. Next, remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next, enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Sep 02, 2011 | Sears Craftsman LiftMaster Chamberlain...
1995 Audi A6--Cant find obd-1 port--It isnt anywhere anybody says it is!!! Antibowtie440@aol.com
Hello antibowtie,
There three different locations it could be in depending on which fuel/ignition system you have. Below I will provide you with all three, I 'll include pictures also.
This data link connector is located in the lower corner of the auxiliary relay box in the engine compartment left side.
netvan_75.pngxt
The next one is located in the center console to the rear of the ash tray under a cover.
And the third location is behind the front storage compartment in the center console.
I hope this helps you.
Regards,
netvan
Apr 09, 2011 | Audi A6 Cars & Trucks
Want i login to Yahoo Messenger Chat it keep saying i have been signed out because I'm sing on a different computer or device can somebody help me with this Problem.
Hey buddy, sombody probably knows your yahoo ID's password and is accessing it from another computer.
Change your Yahoo ID's password and dont share it with anybody. This should prevent you from signing on a different compute or device.
Let me know if this helps. Thanks! :)
Dec 08, 2010 | Computers & Internet
Atari 2600 problem with left control plug on console
Well maybe the controller ports need to be resoldered then try soldering then with a solder iron.
Nov 21, 2009 | Atari 2600 Console
Need Comcast Remote Code for Input Button on an LCD Samsung
samsung codes 10060, 10812 10702, 10178, 10030, 10766, 10814, 11060, 11903
press tv on the comcast remore it will flash
hold set up until the tv button flashed 2 times fast
key in the code
press power to see if your tv goes off
if so press power to turnit back on and you are done.
Dec 15, 2008 | Philips DVR-1
Won't run - normal light flashes
You may try removing power to D/W for a minute and reconecting. likely cause though is keypad (console). If a light above a pad stays on the pad is likely closed all the time. Normal is probably cycle most often used. you can test the keypad by removing power to D/W and accessing the control panel. remove conncter P-1 and using an ohmeter test resistance between 13 and 4 on the connecter coming from keypad. yes without very small clips or 4 steady hands it is a little tricky. in the field we use a breakout board. if you get any reading when not pushed pad is bad. you may find a manual inside the kickplate which explains the keypad sequence. it may be control but more likely keypad, even if test is inconclusive.
Jun 07, 2008 | Whirlpool 24 in. GU2500 XTP Built-in...
Canon imageRUNNER 5000 Copier Logo
208 people viewed this question
old marine
old marine
