Question about BenQ FP92G+S (Black,Sylver) (Silver, Black) 19" Monitor
Benq FP92G Display couple of seconds then blank. LED still green.
Hi! Pc boots up fine. But any display for more than a couple of seconds the screen goes blank. The green light for power is on the monitor. It's a benq FP92G. Tried going into BIOS but samething, display comes up for just a couple of seconds. Put an old monitor in and it worked fine. I also noticed if I turned the monitor on and off on the Benq, the display comes up normal for a couple of seconds then blank again. What are your thoughts?
  • 822 Answers
Budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Posted on Jun 01, 2009
SOURCE:
Acer laptop display goes off after some second
Try booting into safe mode. Chances are that you have set the screen resolution and refresh rate to some value that the LCD cannot handle. That is why it works until Windows takes over. Once you are in Safe Mode you can get things under control.
Jul 20, 2014 | Acer Computers & Internet
My screen size is long and thin for my BENQ FP92G. Please advise how I fix it. Roger Perkins
change display resolutions, go to panel control , display icon and change the resolutions , tray many options
Aug 01, 2010 | BenQ FP92G 19" Monitor
Monitor light is green but display is black
your power supply board, probably has some bad caps in it
Jun 12, 2010 | AOC LM729 17" LCD Monitor
Blank HP w1907
If the power light does not turn color and stay's green on startup, it is not a power problem. It is most likely the inverter. If the unit is in warranty, send it out ASAP. Contact HP customer care by email and have the issue logged in.
If in warranty, they will send you a box by FedX second day and have repaired.
This is a 19" monitor and will not be worth paying for repairs if not in warranty.
Sep 03, 2009 | HP w1907 LCD Monitor
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
19" Topsync CRT display is flickering
the motiter to pc cable is problem yaar you change it the problem is solved
Dec 06, 2008 | ZT Group CISNET A7050 PC Desktop
Benq FP71G+ 17" LCD with Power Recycle (shutdown & return).
Seems either aproblem with Invertor board or Front panel switches are leaky.
Samir
Aug 17, 2008 | BenQ FP71G 17" LCD Monitor
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
Screen displays fine for a second, then goes blank
Dor, BenQ has a 3yr warranty on their monitors. I would contact their tech support and receive an RMA to return it for repair. It will cost you shipping out there but they will ship it back. I has a BenQ FP731 myself and it blew a capacitor inside that allowed the screen to stay on. Fixed it and had it back in 5-7 days. Good luck.
Aug 15, 2007 | BenQ FP737S-D 17" LCD Monitor
Blank scren, led stays green for only one second
Explicit enough to see that's this a a repair shop job. That also probably means a replacement- cost of which will not be much more than repair prices. One thing how ever- the power supply[which would appear to be the problem] is this built into the screen [that is does the screen have mains power direct? Or is it powered from an external 'Power Brick' If it is of the Power Brick type - then a new power supply is the answer - get on of the stabilized universal type with a fistful of connectors and a voltage selector switch.
May 24, 2007 | BenQ FP737S-D 17" LCD Monitor
Open Questions:
See all BenQ FP92G+S (Black,Sylver) (Silver, Black) 19" Questions
BenQ FP92G+S (Black,Sylver) (Silver, Black) 19" Monitor Logo
559 people viewed this question
Top BenQ Computers & Internet Experts
Steve Allison
Steve Allison
Tommmix
Level 1 Expert
Joaquim Martins
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
