Question about Sony VAIO FX120K PC Notebook
Connect an InFocus Projector to a Sony Vaio SZ79GN Laptop
I can't seem to find out how to make this laptop detect my projector - Fn + F4 or F3 doesn't work.... I can't connect one Infocus Projector to a Sony Vaio SZ79GN (Fn+F7) and to a Acer TravelMate 4670 (Fn+F5) what can be the issue
Connecting laptop to projector
Connecting an External Monitor or Data Projector
You can switch to anexternal monitor or data projector by two methods.1. Connect the externalmonitor to the laptop's video port, power up the external monitor first and thelaptop. The video information will automatically switch to the externalmonitor.2. If you power up thelaptop first then you can switch the video output to the external monitor bypressing the Fn key and one of the Function keys, depending upon your make andmodel laptop. You can also toggle between the external monitor or both LCD screenplus the external monitor or back to LCD screen only by pressing the Fn keyplus one of the function key. Here is a list of keycombinations for some of the laptops :-IBM ThinkPad = Fn + F7HP and Compaq = Fn + F4Toshiba = Fn + F5Dell = Fn + F8
Jun 05, 2012 | HP Pavilion dv6200 Notebook
The screen shows "No signal
if your are running on laptop inorder to show the pictures on projector, try to look on Fn+F3 or F4 it depends on your laptop. check your laptop that has a sign of small monitor.
Aug 25, 2011 | Office Equipment & Supplies
Cant get it to work with laptop
power ON your projector and laptop
connect your laptop and projector with VGA cable and press
if your laptop PANASONIC or NEC (Fn+F3)
ACER, HP,SHARP,TOSHIBA (Fn+F5)
LENOVO, SONY (Fn+F7)
DELL, EPSON (Fn+F8)
FUJITSU (Fn+F10)
APPLE (F7)
If problem exist remove the VGA driver in your laptop and reinstall the correct driver not a standard display driver
Feb 09, 2011 | Panasonic PT L720U Multimedia Projector
Tried projector no work
Connect your projector to your laptop using a VGA cable. Now turn ON your projector and your laptop.
To make your screen projected, look at your function keys (F1 to F12). Look for the icon which looks like a laptop LCD and a TV. It should appear like LCD icon/TV icon. In some model it is in F4 while F3 in Lenovo. Example, you found the icon in F4, just press and hold down the FN key and press F4 to send your desktop image to the projector. This combination is called the "dual monitor" setup which in your case, the second monitor is a digital projector.
Jun 23, 2010 | Everex StepNote NC1500 Notebook
Projector does not get signal from my HP DV 6000 Laptop
try pressing FN on your keyboard then press F3 = FN+F3 at teh same time to project waht is in the laptop to the projector........
if not go to desktop right click anywhere select display properties it should give you the option to select the monitor and projectors detected by the laptop to show what is on you laptop as well posbbile u will need to either expand or if the option cloning will be present to have both show on the laptop and desktop ^_^
Jun 04, 2010 | HP Pavilion dv6000z Notebook
VAIO VGN-Z520N/B 13.1" Laptop : where is the volume control on sony vaio laptop...
You can use the Fn+F3/F4 Function Keys to control the volume.
To increase the Volume, press Fn+F4 and then press Up or Right, or Keep pressig Fn+F4.
To decrease the volume, press Fn+F3 and then press Down or left, or Keep pressing Fn+F3.
Hope this helps..
May 13, 2010 | Sony VAIO VGN-Z520N/B Laptop
Is there an alternative to the
You can try powering off the laptop, connect the projector, power on the projector, then power on the laptop. Sometimes it can boot directly to the screen of the projector if detected at startup.
Another option could be to attach a USB keyboard to your laptop and use that to press the Fn + F4 keys.
Jan 14, 2010 | Computers & Internet
Need image to show on both the HP laptop and the InFocus IN15
make sure the laptop is plugged in and not on battery. also make sure the dmi-vga cable is not too long. the signal isn't strong enough to get to both screens.
Jun 04, 2009 | InFocus LP70+ Multimedia Projector
Can't get the projector to project an image from my laptop.
Yes you need to press something on your laptop ...maybe FN +F3 or FN+F4..but after you have image but your projector still turn of...then follow my next comment.
Takecare..
Apr 19, 2008 | Computers & Internet
Acer Aspire 3680 + View Sonic Projector
does it work with external monitor ?
the key should be Fn+F5 or Fn+F6
I believe you need to hold fn and press f5 to choose the target (lcd, monitor, lcd and monitor).
Feb 26, 2008 | Computers & Internet
Open Questions:
Sony VAIO FX120K PC Notebook Logo
491 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
