Question about Acer Aspire 5500 5570-2609 Laptop
LAptop turning off whenever it feels like it.
My Acer Aspire 5520 keeps turning off. Then when I try to turn it back on the little green light flashes, but the computer wont boot up. I cannot turn it off either....have to disconnect the battery or wait for it to die. HELP.
    Problem Solver:
  • 8 Answers
Ctrl+alt+del
make sure close all working procedure.
Posted on Jun 01, 2009
  • 822 Answers
Recharge your battery with your charger.
  • rommel dadulla
    rommel dadulla Jun 01, 2009
    remove the battery to stop flashing then recharge battery.
My laptop wont turn on
You may have a RAM problem. Try reseating the RAM modules, if this does not fix your problem, remove the RAM modules and take then to your friendly computer repair shop and get them to test the RAM for you.
Feb 06, 2012 | Acer Aspire 5520-5908 Notebook
My Acer Aspire 5520 wont power up when i tried to turn on. Battery getting power supply. orange light is glowing. but i pressed power button, it does not turn on. pls give me a solution. I removed my...
start your computer keep pushin f2 now youll see first use arrow keys go to were it says change reboot to f12 then restart your computer then it be set on a f12 press f12 then it will ask to run your windows go to that one.
Jan 27, 2011 | Acer Aspire 5520-5908 Notebook
Aspire 5532. my lapyop keeps saying logging off and wont turn on
Tap the F8 at the time of startup and get to advanced boot options. Select safemode with the arrow keys on keyboard and tap enter. Try to login. If yes, try a system restore. If no, try last known good configuration. If that also is not helping, then try an OS reinstallation.
Dec 21, 2010 | Acer Aspire 5520-5908 Notebook
Power button goes on and off, and no response
Power drain the computer by removing the battery and power adapter and press the power button for 1 minute. then insert back in the battery also the adapter to your computer and start the computer.
If the solution won't work
, try using flash light on the monitor,if you can see anything on your screen, possible backlight is the problem, however to isolate also the issue you may use an external monitor to check if you can have a video using other monitor and if not? you may contact the tech support of your system for possible mechanical failure.
hope it helps.
please post positive comments and rate.
May 13, 2010 | Acer Aspire 5520-5908 Notebook
My acer aspire 5520 keeps shutting down on boot. When i switch it on, its shows the boot screen then immediately shuts down. I had previously installed windows 7 on my second hard disk drive and the duel...
Insert your restore CD if errors are found and not fixed by the checkdisk function listed above. Turn your computer off and then back on. You'll beasked to hit any button to boot from your CD; press any key. You will then beasked if you want to install a fresh version of your OS or "Repair" acurrent copy. Choose the "Repair" option.
Dec 24, 2009 | Acer Aspire 5520-5908 Notebook
Acer aspire 5520 laptop. Is it dead?
To verify it isn't a battery issue you can try taking the battery out completely and plugging in the A/C adapter and turning it on.
Without more information it's hard it's hard to diagnose your issue more specificially. Do you get any lights on the front?
Jun 21, 2009 | Acer Aspire 5520-5579 Notebook
Black, cannot boot up... etc.
Try taking out battery and plug in power. If it works, battery is faulty.
If not, try taking out your hard disk plug in power, if it works, hard disk is faulty.Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Jun 02, 2009 | Acer Aspire 5520-5908 Notebook
Acer Aspire 5520 boot problem power on linght blinks
If you can't get past the bios boot then likely its a problem with the bios settings or a hardware issue on the motherboard. Make sure the processor fan is running when it turns on.
Feb 23, 2009 | Acer Aspire 3100-1405 Notebook
A hard disk problem is preventing windows from starting.
The black screen with flashing cursor can be caused by the files needed to boot being located in sectors of the hard drive that can no longer be read.
You can try booting to the XP CD, and go to recovery console and RUN CHKDSK /F See if that fixes the file structure and allows the system to boot. If that fails, you can try a repair installation of Windows. If that fails, the most likely resolution is replacing the HDD and reloading Windows and the drivers.
Jan 31, 2009 | Acer Aspire 5520-5908 Notebook
My acer laptop wont turn on and the little green light is on???
I have an ACER aspire 5520. Very familiar with this prooblem. Are you getting any POST beeps when you turn on.
Step 1. simple solution. Are you plugged in AC household outlet v.s. laptop battery?
step 2. Do step 1 if you are on battery power
report back.
Jan 16, 2009 | Computers & Internet
Acer Aspire 5500 5570-2609 Laptop Logo
165 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
