My laptops screen becomes darker if i leave it for a while but once it got dark and since never get back to bright...could u please help me how to bring bright screen back...thanx
i even installed a new windows but its screen is still dark, i want it to be bright...but thanx anywayi even installed a new windows but its screen is still dark, i want it to be bright...but thanx anyway
You can't post conmments that contain an email address.
Wait for your computer to die open it up log on go to the desktop right-click > Properties > Screensaver > Power... and set all to "Never" and your done
The screen may become dark if Picture mode is set to Cinema or Custom. If the screen continues to remain dark after changing the picture quality mode, go to the Backlight, Picture, Brightness menu and adjust the brightness to your liking. When Power Saving is fixed to Low or High, the screen becomes dark. Some TVs have a Light Sensor so the picture will just become brighter or darker depending on the lighting in the room.
You can also try programming from a different source, like a DVD player or VCR to check whether the problem is caused by the device that sends the signal to the TV.
If Picture mode is set to Cinema or Custom, the screen may become dark. If the screen is still dark after the picture quality mode is changed, change the setting Backlight, Picture, Brightness and adjust the brightness to your taste. ... If Power Saving is set to Low or High, the screen becomes dark https://www.sony-mea.com/en/electronics/support/articles/00024643
Check your display settings in the Power save part of Control Panel. You can set a brightness for battery and AC. Normally you set it brighter on AC and dimmer on battery (to save battery life) but if you've adjusted it for some reason that would explain it
look on your keyboard for the key with the 'fn' meaning function and then press the up arrow key on the keyboard. This will make the screen brighter this happens when you are on your battery to save power. You can also do it manually by accident.
On your laptop there should be key combinations to change the brightness of your screen. Once you do this, it will stay that way for each mode until you change it again. There should be in blue above the arrow keys, the F keys, or the number keys, a symbol that indicates brightness; one key for up and one key for down. You press the FN key and that corresponding key to turn your brightness up or down. Once you got it set, leave it. It will stay that way until you change it again.
Please try and external monitor if the picture is OK then you are having LCD problems. I dont know for you but over in the States here:
http://lcdrepair.net They maybe, are able to help you.
