Question about HP DeskJet 940c InkJet Printer
Hp ink cartridge replacement
Thank you for your assistance in this matter.
Everytime I replace the ink cartridge when the ink requires replacement the ink does not seem to inject.  Sometimes I restart the system, that does not help.  Sometimes I turn off my computer et al for a day, that does not help.
I put new cartridge in 2 days ago, still does not work.  As the cartridges do not have instructions for this and the person who owns the hpdeskjet 940c printer is unable to locate the manual to alleviate this problem.  HELP!!!
Sincerely
C. at grayshaverhickey@hotmail.com
    Genius:
  • 1,601 Answers
Greetings, I have a Canon Pixma M610 and this problem just started happening. Everytime I replace an ink cartridge, the new ink color doesn't print AT ALL until I run a "deep clean". Then,...
Try removing all ink cartridges and printhead from the printer. Then, look inside the printer with a flashlight. Look into the right side of the printer and see if there is lots of ink gunk. Remove if any and try not to leave ink gunk on other printer parts. Turn printer off when removing ink gunk. Then after you are done cleaning, turn printer on and wait for it to command you to insert printhead. Do that and close cover. Then, insert cartridges when printer asks for them. Hope that helps. -Alex
303Electronics eBay Stores
Jun 07, 2017 | Canon PIXMA MP610 InkJet Printer
My canon pixma iP 1800 does not recognise refilled colour cartridge. Can you suggest a fix?
  1. For the not-so-tech friendly, installing ink cartridges in printers can be messy and time-consuming. Although companies such as Canon are constantly trying to make designs more convenient for all users, there are still several tips that can help new printer owners install Canon PG-40 printer cartridges without mess or hassle.
  2. Compatibility
  3. Although many printer cartridges are specific to only a few models, the Canon PG-40 printer cartridge was designed for use with many models of the Canon Pixma and even some of the Canon fax machines. As of September 2010, the Canon PG-40 ink cartridge can be used with the Pixma iP1600 through iP1800 printers, the iP2600 printer, the MP140 through MP190 printers, the MP210 printer, the MP460 and 470 printers, the MX300 and MX310 printers and the JX200 and JX210P fax machines. This versatility allows users to stick with the same type of ink cartridge over the life of several printers and allows small business offices an opportunity to buy one type of cartridge for all office printing requirements.
  4. Refill
  5. Replacing printer cartridges can be expensive and, if it is possible, as it is with the Canon PG-40, refilling is a cheaper and more environmentally friendly option. Refill the PG-40 by gathering a 10 cubic centimeter syringe with a 1.5-inch needle, a pair of latex free gloves, an MIS Yellow Drill Tool, Scotch tape and black ink. Remove the label from the top of the cartridge and use the yellow drill tool to open the vent hole that was covered by the label. Next, load the syringe with 20 CCs of black ink and inject it into the ink hole (where ink leaves the cartridge for the page.) Make sure the needle reaches the bottom of the ink tank and then slowly inject the ink into the cartridge, stopping when the ink begins to well up at the needle insertion point. Now remove the needle and clean the top of the cartridge off to avoid color contamination. Put a small strip of Scotch tape over the vent hole and poke a small hole in the tape with a pin. Now reinsert the cartridge and run up to three cleaning cycles to calibrate the printer.
  6. Resetting the Ink Level
  7. While refilling ink in a PG-40 can save money, it can also cause difficulties when using the automatic ink level sensor. Reset this sensor by removing the cartridge after the printer has been calibrated and placing a thin strip of Scotch tape on the line of gold-colored leads nearest the ink hole on the bottom of the ink cartridge. Replace the cartridge and wait for the computer to display a warning about the ink cartridge being loaded incorrectly. Remove the cartridge and move the tape from the first to the second level of leads and replace the cartridge. When the PC displays a message that the cartridge is not recognized, remove the cartridge and replace without the tape. The ink level will be reset.
Jan 09, 2011 | Office Equipment & Supplies
I whant to refill pixma canon ip2700 with black ink but dond now how
Color Cartridge 1. Place the cartridge over somepaper towels in case there are any spills.Remove the label sticker from the topof the color cartridge. 2. Drill into the three small holeson the top of the cartridge to widen them so they will allow syringe needles. 3. Fill a syringe with 6 mL ofmagenta ink. Insert the needle into the refill hole that is located below thetwo protruding rectangles on the top of the cartridge. Slowly inject the ink. 4. Fill a syringe with 6 mL of cyanink. Insert the needle into the refill hole located below the large rectangleon the top of the cartridge. Slowly inject the ink into the cartridge. 5. Fill a syringe with 6 mL of yellowink. Insert the needle into the refill hole located below the small rectangleon the top of the cartridge. Slowly inject the ink into the ink chamber. 6. Replace the cartridge into theMX310 printer. Black Cartridge 1. Set the cartridge on some paper towels. 2. Drill a hole into the dimplelocated directly above the semicircle on the top of the cartridge.Fill asyringe with 20 mL of black ink. Insert the needle into the hole and slowlyinject the ink. 3. Replace the cartridge into theCanon MX310.
Nov 28, 2010 | Canon PIXMA MX310 All-In-One Printer
I need to replace the print cartridge but the carriage only stops on the far left under the frame. How do I get it to stop in the middle so the ink cartridges can be replaced?
switch the machine off then open the cover for ink cartrigde move the belt that the printer heads are on until in the middle replace cartridges and switch on machine this should work if the cartridges still does want to move the carriage rail could be very dirty and requires cleaning if you do not what you are doing advise you get a tech to assist you in this matter
Oct 18, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Everytime I try to print , all i get is a a blank page
If you are using it on a MAC there are known issues.
If however it is a pc then maybe you should check your ink levels using the software that you installed with the printer.
Have you recently replaced the ink cartridges and if so did you use original HP cartridges ?
If you didn't use original cartridges then there is quite a good chance that they may be faulty and should be returned to where you purchased them for replacement.
If you did use original cartridges did you remove the tape on it before installing ?
Check by doing the cartridge replacement steps and take out any cartridge you may have replaced recently and check that the pull off tape tags are removed.
Aug 19, 2009 | HP OfficeJet 6110 All-In-One InkJet...
"E", doesnt print scan or copy
Ink has dried inside the printer.
Assuming the printhead is seperate from the cartridge, i would inject JR Inkjet flush into the old cartridge and put it back into the printer. Leave it to stand for an hour or two, then run several cleaning cycles.
Once the ink comes through (if it does) replace your new cartridge and clean again until the print quality is restored.
If this does not work. Then i expect a new printhead is required. (i would try the first suggestion repeatedly).
Ink cartridges should be replaced immediately if possible. and even if u need our technician support contact us at http://tinyurl.com/mtgjzz
Jun 22, 2009 | HP PSC 1315 All-In-One InkJet Printer
Brother MFC-420cn NO CARTRIDGE message. I replaces black ink cartridge . How to detect which cartridge needs replacement when all of them seem to have ink in them.
Here's a permanent fix. Basically you cut the wire to the ink sensor. You can no longer see the ink levels, but that didn't matter anyway, as it was incorrect before!
First of all, TURN OFF THE POWER TO YOUR PRINTER. Then lift up the scanner and remove the three screws along the top of the control panel. With a bit of force, snap-up the most inner two
Sep 05, 2008 | Brother Office Equipment & Supplies
Ink reading emty when replaced
If the cartridges are refills they won't show ink levels but you should still be able to print. Then just print until appears to run out of ink,
Mar 27, 2008 | Canon PIXMA MP180 All-In-One InkJet...
Ink or printers problem
Most likely the ink cartridges for this printer have a chip on them. This chip tells the printer how much ink is left and when it is low or out, you must replace the whole cartridge otherwise if you just refill it, the chip will still report the same amount of ink as it doesn't go by the actual ink level inside the cartridge, it determines the ink level by calculating approximately how much ink has been used while it was printing. So it doesn't matter how full the cartridge is, unless you replace the cartridge or reset the counter on the chip somehow, it will still display the calculated amount not the actual amount.
Jun 10, 2007 | Compaq Armada M700 Notebook
HP DeskJet 940c InkJet Printer Logo
74 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
