Question about Hand Tools
Floor jack won't stay
I have a Craftsman 3 ton floor jack, it will lift fine, but after a short while it will let it self back down. What could it be, if it is the seals is it a easy fix, my buddy to me to throw it away and get a new one if its the seals.
  • Arthur Trav May 11, 2010
    Does it come down very slowly, or fast?
    If you are prepared to throw it away, pulls it down first and see if you can replace the seals. You may be able to buy them, or even make them.
    If you then find you cant fix it, only then throw it out. Good luck!
If you are having a problem with the jack slipping...if its Craftsman , they may take it back and provide a replacement. Even if you could fix it, it never works that same. It is not worth your life. I know, I lost my husband when a jack slipped 3 years ago this month.
Posted on Feb 07, 2011
  • 1,040 Answers
Your buddy is right "gravedesigns".It's not worth getting squished over, no joke!!
Jim
Posted on Jun 02, 2009
  • Jim Parker
    Jim Parker Jun 03, 2009
    Thanks for the rating "gravedesigns". If you should have any questions about drywall finishing, or know someone who does, put your questions to Category:"Tools-Building & Power-Hand Tools" at FixYa.com
    Thanks Again,
    Jim
How to overhaul/ repair a hydraulic floor jack?
Sounds like a bad seal on that plunger that pumps up and down. That plunger should unscrew and then it's pilled out , there should be an O ring. That is where it probably is leaking. You probably need to top off oil. You can jack oil in an auto store or Lowes, etc.
Jun 08, 2014 | Automotive HEAVYDUTY Hydraulic Bottle Jack...
What is a jack lift?
"A jack lift is a mechanical device used as a lifting device to lift heavy loads or apply great forces. Jacks employ a screw thread or hydraulic cylinder to apply very high linear forces.
A mechanical jack is a device which lifts heavy equipment. The most common form is a car jack, floor jack or garage jack which lifts vehicles so that maintenance can be performed.
More powerful jacks use hydraulic power to provide more lift over greater distances. Mechanical jacks are usually rated for a maximum lifting capacity (for example, 1.5 tons or 3 tons)." (Wikipedia)
Oct 07, 2013 | Hoisting
What size floor jack do I need for a 1987 toyota camry?
Any roll away floor jack from a autoparts store will be fine and strong enough
Mar 04, 2013 | 1987 Toyota Camry
How does a floor jack work
Place jack under what you want lifted and close valve and put rod in jacker and jack up till your height is good,to let down turn valve counterclock wise.
Sep 13, 2012 | Automotive HEAVYDUTY Hydraulic Bottle Jack...
Craftsman 3 ton floor jack will not stay up
you need to bleed the air from the cylinder. there should be an air bleed or else you bleed it at the relief needle. also, if it still leaks down after you bleeed out the air, the seat for the relief valve or the seals at the relief valve cartridge are worn
Apr 01, 2009 | Home Fencing
What Jack and stand to get for my '04 Ram 1500 Short Bed V6?
THE SAFEST CHOICE IS THE 3 TON.. YOU COULD GO WITH THE 2 OR 2.5 TON, BUT WITH THE SIZE OF YOUR TRUCK YOU NEED THE 3 TON..REMEBER TO ALWAYS USE THE JACK STANDS..GOOD LUCK KEITH...
Mar 14, 2009 | 2004 Dodge Ram 1500
Sears 4 Ton Hydraulic Automotive Floor Jack-Will Not Lift ?
I have a Sears 1 1/2 ton floor jack. I was able to buy a repair kit from Astro Pneumatic Tool Company 372 OLD U.S. Hwy 52 South Mount Airy N,C 27030-8093
1-800-221-9705
John
Sep 27, 2008 | Plumbing
Hand Tools Logo
865 people viewed this question
Top Hand Tools Experts
Don Numinen
Don Numinen
Bill Boyd
Dan Apthorp
Are you a Hand Tool Expert? Answer questions, earn points and help others
