Question about CTX S762A 17" LCD Monitor
Monitor turns off after two seconds
I moved and went to hook my computer back up and the monitor comes on for about 2 seconds and then turns off. If you turn it off and back on again it comes on and repeats the same issue. I bought a new cable and the problem still exists. I packed it very carefully?
  • Twintek Nov 08, 2007
    Monitor comes on momentarily after startup then turns off and green light blinks. By powering the monitor on and off, eventually the monitor will stay on. Almost like a problem related to warm up. Power supply???
  • tvolke Dec 08, 2007
    have same prob, moniter powers up fine and displays for about 2 sec's then goes black, power light is still on though.
What board did you replace capacitors on?
Posted on Jan 28, 2008
The solution was not a backlight problem. Backlights have different failure characteristics than was stated. The problem turned out to be several defective (open) electrolytic radial capacitors. Found by trouble shooting the pc boards with a good cap tester and replacing the defective caps. Works great....now!
Posted on Jan 27, 2008
    Problem Solver:
  • 18 Answers
Caution on Inverter advise...
If the inverter is bad, you will still see non-backlit video on the lcd screen if you look real carefully. It will be very faint, but you will see it, especially if the video being displayed has alot of contrast.
The job of the inverter is to provide starting power to illuminate the LCD's fl lamps and then maintain the selected intensity. The video is a separate issue and will always show on the LCD. So, if your monitor powers up and if you are positive that there is a video signal going in to the unit and you cannot see a faint image of it, do not bother with the inverter, it is not your problem, it is the LCD itself or the video circuitry (very expensive to repair. Trash unit and just get a new one)
CharlyV
Your inverter board is bad. They run anywhere from $30 - $80. They are very easy to replace. I have had this problem with three monitors and replacing the inverter board fixed the problem. Hard to say where you will find the part. Just do a search for 'inverter board' with your model # on any search engine.
Good Luck!
Posted on Dec 08, 2007
2 Suggested Answers
SOURCE: Starlogic monitor
I been working on lcds for some time and what I find is caps in power supply dry out over time. If you can open case and see if cap pop out at the top of it. thats your problem...cybrg0000
Posted on Feb 10, 2008
My monitor won't come out of sleep mode
Try unplugging the power cord from the monitor for 10 seconds and plugging it back in.
Jan 31, 2018 | Westinghouse Computers & Internet
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
My pc was taken apart so I could move. When I hooked it back up the monitor comes on for a couple seconds and says that my pc is in analog power saving mode. The power light on the tower just blinks c
It might be in a corrupted hybernation mode.
Try turning the computer off by pushing the power button for 10 seconds and then do not choose resume but the other option.
Nov 08, 2013 | HP Pavilion Computers & Internet
My Soyo monitor (DYLM1998) stays blank (black) except when it is turned on, the monitor shows a picture for 2 seconds and then goes blank again. If I turn the monitor off/on several times, it finally...
your power supply has a short in it this is comon ive seen this before try to replace cord if attatched take it to someone for repairs if not attatched its the cord most of the time loose wire..
Apr 10, 2011 | Soyo DYLM1998 Monitor
I have a Soyo Monitor, Model MT-NI-DYLM1998. It had been working OK, but I put my computer in storage for 2 weeks and then tried to reconnect. The Soyo monitor stays blank (black) except when it is turned...
i have encountered this same issue with a monitor like yours its very common especially for lcd monitors there is a bad diode on your monitor board and you will not be able to fix this yourself you can buy another or use just a regular crt monitor or your best bet is to have it repaired im sorry and i hope this helps
Dec 19, 2009 | Soyo DYLM1998 Monitor
Monitor just won't stay on.
  • power chord may be faulty
  • check the cable that connects it to the computer correctly
  • may be an internal circuit breaker
  • check the ports on the computer
Oct 10, 2009 | Samsung 923NW 19" LCD Monitor
LG monitor turns on for a split second and then goes black
Sorry to be the bearer of bad news but you called it, the monitor needs to be replaced.Now all we have to do is set the actual time of death...only kidding. Take care, Dana
Sep 13, 2009 | LG Flatron L1750S 17" LCD Monitor
Monitor remains in standby
turn the monitor off and the computer off. unplug it from the wall. let set for 10 sec. make sure you have it in the right place and in all the way. turn computer back on, then the monitor.
Dec 18, 2007 | X2Gen MG15VT 15" LCD Monitor
Starlogic monitor
Oct 21, 2007 | CTX S762A 17" LCD Monitor
Monitor problem
I have had similar problems. It would appear that the power supply is at fault, not the monitor.
Dec 27, 2006 | Microsoft Likom HD19A 19" LCD Monitor
CTX S762A 17" LCD Monitor Logo
2,078 people viewed this question
Top CTX Computers & Internet Experts
Rommel Balcita
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a CTX Computer and Internet Expert? Answer questions, earn points and help others
