Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
No connection I have a WBR-1310 D-link wireless router and I have no connection. I checked my internet by connecting directly and it works. I reset the router but that doesn't work. I tried unplugging it for 30 seconds and plugging it back in, nothing. That is the extent of my knowledge and has worked in the past but not now. When I reset the wan light won't stop blinking, even overnight. same problem, does router have vista compatibility issues?
  • Anonymous Mar 31, 2014
    Cannot connect a snom 300 phone using this router...cannot seem to get past the firewall even with the firewall on the router turned off. The phone works if I connect directly to the modeum
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 116 Answers
No, it sounds like your authentication or encryption is wrong. Authentication should be "open" encryption can be WEP, WPA or WPA2, and can be in alphanumeric characters (ASCII) or restricted alphanumeric (HEX) with numbers 0 to 9 and letters A to F only.
Are you able to detect the wireless network broadcast? (SSID). Are you able to get a wireless connection AND a legitimate IP address? Try tunning "ipconfig" from a command prompt, your IP should NOT be 169.254.(anything).
Posted on Jun 01, 2009
Wbr 1310 does not seem to connect to laptop. erthnet cable is connected from modem to wan port on router and another erthnet cable from port 1 on router to laptop erthnet connection. no...
connect your computer to the router and open internet explorer and in the address bar type, 192.168.0.1 and push enter. it might be 192.168.1.1, don't remember. login and setup your internet connection. if you have cable internet set it to DHCP. if you have DSL you will have to get the settings off the providers web site. you can also try resetting the router. with the power on, press the tiny reset button on the back of the router for about ten seconds. you will see the lights go out and come back on. once the router reboots try it again. Good luck.
Aug 14, 2011 | D-Link 802.11g Wireless Router WBR-1310...
Error 103
Press in and hold the reset button on the back of the router. Connect directly with a patch cable and configure your wireless settings by typing 192.168.0.1 in address bar. Download the manual here:
http://www.dlink.com/products/?tab=3&pid=WBR-1310&rev=WBR-1310
Mar 08, 2010 | D-Link 802.11g Wireless Router WBR-1310...
My laptop say i am connected with internet access but it is not; when i check network magic there is a red x through router and laptop; how do i fix this...have unplugged and reset but nothing works; seems...
uninstall the network magic . that software has lot of issues.
You can uninstall the program and try to connect using the windows utility. that is very easy and that works properly.
Is there any computer connected to the router with the cable. If yes then open the router set up page and check the wireless settings of the router.
Click here for more information about the router and network
Jan 13, 2010 | D-Link 802.11g Wireless Router WBR-1310...
After connecting router wbr-1310, DSL connection states "limited to no connectivity." What could be causing that problem and how can it be corrected to operate the router?
limited to no connectivity with a wireless system means that it is not picking up the signals from the internet device you have, check if everything is plugged in properly and that your internet connection (modem) has enough strength to be able to be wireless.
Sep 04, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I have comcast cable net and D-link WBR 1310
Hi, forget about the USB connection since you wanted to use a router for your wireless connection. Contact Comcast asnd make sure they assist you in making your computer connect to the Internet using the ethernet connection because you are going to use the ethernet connection for the modem-router connection. Once your computer is online with the ethernet connection, you can connect your Dlink router to the modem and configure it for Internet connection. There will be more steps before you can use the wireless connection. Just make sure you can get online with ethernet connection first.
Jul 23, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Router won't connect w/desktop
yeah well..since if u had XP you will not be having that problem..but since it is vista..you ll have to ask your internet's customer care..to reset modem through which your wireless router gets the signal..and then try it should work for sure..ok
May 25, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Unable to connect to the internet
Mike, Try setting up a new connection in Internet Options in Control Panel. Please let me know how this works for you.
thanks
Jan 24, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Cannot access the WBR-1310 webpage
if you are wireless, after a reset you need to connect with the router using an RJ45 lan connector lead. Reboot your notebook, while connect to router and then type in the default address for the set up page normally 192.168.0.1
Oct 05, 2007 | D-Link 802.11g Wireless Router WBR-1310...
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
287 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
