Question about Philips 42PFL3603D 42 in. LCD TV
TV freezes at "Philips" screen
After turning off my Philips 42-inch LCD HDTV, I turned it back on a few minutes later. The "Philips" startup screen displays on the TV...and nothing else. It just sits there. Furthermore, I can't turn it off with the remote, OR the power button on the TV. I have to unplug it. The problem persists after plugging it back in.
  • eddie_shizni Jun 01, 2009
    I have left the TV on for over 15 minutes. The screen does not go away.
  • Brett Andrew May 01, 2013
    Same thing is happening with my tv, was hoping for answers having a hard time finding it, i've got it to work again by just leaving the tv off for about 10 minutes unplugged, then plugging it back in, but it doesnt always work. hoping for a more permanent fix
  • 61 Answers
A professional. -These electronics go threw a self diagnostic when they start up, normally they turn off when they find a problem.
Posted on Jun 01, 2009
SOURCE:
Philips 42PFL3704D/F7. Why does it keep restarting?
Philips 42pfl3704d/f7 power reset when HDMI, USB, or cable ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Oct 9, 2012 - 5 posts - ‎2 authors
Philips 42pfl3704d/f7 power reset when HDMI, USB, or cable attached ... or Cable TV to unit the power resets, philips screen comes on and keeps on resetting. ... I tried a cable to the tv without the box and I do get picture.
Philips 42PFL3704D/F7 42-Inch 1080p LCD HDTV
www.amazon.com/Philips-42PFL3704D-F7.../B001LP...
Amazon.com, Inc.
Rating: 3.3 - ‎50 reviews
Amazon.com: Philips 42PFL3704D/F7 42-Inch 1080p LCD HDTV: Electronics. ... Will do all I can to prevent others from getting ripped off by Philips. ... came up every few weeks and would take an hour or so of reset before working properly.
Visit the support page for your Philips LCD TV 42PFL3704D ...
www.philips.ca > philips > Televisions > 3000 series
PhilipsFind support for your LCD TV 42PFL3704D/F7. ... How do I output sound from myPhilips TV to external audio devices such as Home Theaters, Soundbars, AV ...
42" Philips 42PFL3704D/F7 LCD TV WON'T COME ON - A
Dec 29, 2015 | Televison & Video
I have a 42 inch philips lcd tv and it will not turn on. Tried unplugging it for 60 seconds and only the light will blink red sometimes and then blue sometimes. Do I change out the power source
Number of TV have a bad batch of capacitors on the power board. If you look like split mushrooms that is a bad sign. But there are kits if you know how to solder.
Oct 25, 2015 | Philips 42PFL7403D/F7 42-Inch 1920 x 1080p...
Philips 42PFL7422D/37 42-Inch 1080p LCD HDTV Picture went out but still have sound. Any tips on how to fix it?
If the backlight of the LCD-panel does not function, (no picture) then Master and/or Slave inverter are defective. Inverter boards are screwed to both sides of the LCD display, if they have revision 1.2 boards then they will need replaced with revision 1.3 boards.
Feb 16, 2011 | Philips 42PFL7422D 42 in. LCD TV
I have 42 inch lcd philips tv. Sound does not work when I turn tv off and then back on. I have to turn tv off, unplug hdmi cable from back of my tv, plug back in and then sound will work when I turn tv...
something problem with your connection from cable to tuner, if in good contact. you need to remove back cover and re solder tuner ckt board side. specially in 32 pin ic.
Mar 07, 2010 | Philips 42PFL5603D 42 in. LCD HDTV
Lcd tv shuts off by itself and then turns on by itself
philips tv turns itself off and on agianevery 10 mins roughly with a gap of a few mins before coming back on. only had a few months
Dec 27, 2009 | Philips 42PFL5603D - 42 IN. LCD HDTV
One half black verticle screen
Manufacturer Philips Part Number 932224850682 Description LCD DISPLAThis part is no longer available
Aug 20, 2009 | Philips 42PFL5603D - 42 IN. LCD HDTV
My 42 inch lcd phillips tv turns on and of by its self and freeze
If it is still under warranty address this. The problem is the signal board. The one with rca jacks and RF connectors.
Aug 19, 2009 | Philips Televison & Video
My flatscreen tv gets green dots that appear on screen while...
The first mistake was the Philips TV. They are the worst tv. They are constantally needed to be updated. If you have warranty, I would recommend you taking it back or calling philips customer service and getting your tv repaired or replaced.
Apr 07, 2009 | Philips Ambilight 2 52 in. Flat-Panel LCD...
Phillips 42 inch LCD HDTV w/HDMI
I CAN'T TURN ON TV
WHEN TRIED TO TURN IT GOES OFF
I SEE RED LIGHT BLINKING ALWAYS.
Dec 11, 2007 | Philips 42PFL5332D 42 in. LCD Television
Philips 42PFL3603D 42 in. LCD TV Logo
1,305 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
