Question about Fedders A7D18E7B Thru-Wall/Window Air Conditioner
No cold air.
My air conditioner sounds like it is running. but no cold air comes out . then it just shuts down.. but it won't turn off I have an older Goodman ductless mini split unit that keeps "tripping" the switch between the indoor and outdoor units. I have had it checked and am told it is an issue with the motherboard. trying to locate part...can you help? Part number is B1100134.
Speed boy
  • 76 Answers
SOURCE: York Mini-Split Not Cooling? : (
This can only be a gas problem.
the split units goes on on and off if a shortage of gas is involved, the chances that you would here it wont be that big for the fans would make too much noise.
get a repair man for a re gas and all is well.
Good luck.
Wouter.
Posted on Oct 22, 2008
SOURCE: DeLonghi Planus quick connect split heat pump.
I was told by a delonghi technician that it does this to defrost the unit.
Hope this helps.
Posted on Apr 22, 2009
SOURCE: ac split unit indoor an ouydoor unit electrical wiring diagram
machine off
Posted on Apr 25, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Fujitsu mini split outdoor unit not running, but indoor unit is running after turnning on
Check the disconnect switch and make sure that both the fuses are good and not shot. If one is shot then the system wont work. There are two fuse. Also be careful due to you will be working around 210 volts
Posted on Jun 01, 2009
  • 3 Answers
SOURCE: i have a split air conditioner my out fan keeps
It depends on the effiency of the unit. The fan could be cycling because the condensor coil is not hot enough. When it get hot enough the fan will turn on. If not you have a bad fan motor
Posted on Jun 25, 2009
My unit is making a loud noise and is spitting water out with the cool air
i have had units turned too cold and ice forms on coils. shut unit down and take it out of window. turn /tilt and when all water runs out, re install and turn back on to a Higher , less cold setting.
Jul 29, 2012 | Hampton Bay HBLG5004 Air Conditioner
Airconditioner not getting cold
do you hear the compressor come on? shut it down for a munite or two and thenstart it back up you should hear the compressor come on with a diffrent sound thatn the fans. let me know Jon
Aug 04, 2011 | Kenmore 70088 Air Conditioner
Air conditioning cycling on and off to fast, does not seem to know when to shut off, clicking or shut off sound when it wants to shut off but doesn't it keeps running. It is blowing ice cold air.
It sounds to me like the thermostat needs replaced. If what you hear clicking noise but the unit does not shut down that is probably the problem. Thank you.
Jul 25, 2011 | Dometic Rooftop RV Air Conditioner
I have an RV with a duo therm rooftop air conditioner... when i turn the air on.. the compressor will run for a few minutes.. it blows cold air and then the compressor shuts down. Low freon??
Quite possibly low on refrigerant. Sounds like a pressure switch is shutting the comp. down after it pumps down for a few minutes. Someone will have to check the refrigerant with guages if you don't have any of your own. There should be ports to connect a set of guages near the compressor under the cover.
Apr 13, 2011 | Dometic Rooftop RV Air Conditioner
Blows cold but shuts down no freeze up
Check the capacitor. It should be a dual capacitor , runs both compressor and fan. This sounds like your problem only because both the compressor and the fan go out together. Good Luck Hope I helped
Dave
Sep 16, 2009 | Dometic Rooftop RV Air Conditioner
Ice forming on inside of unit air not cold
clean the filters and check the drain, to clear the drain run a jug of warm water down the pipe
Aug 19, 2009 | Dometic Rooftop RV Air Conditioner
Fedders wall air conditioner
If the compressor only turns on after the units it's shut off then it is a control board problem (stuck relay)
Jun 19, 2009 | Fedders AEY12F7F Wall/Window Air...
No cold air.
Is the air conditioner completely dead? See section 1. Is the thermostat knob turned to the proper setting? Is the compressor motor running? The compressor is a football-sized case with no apparent moving parts. It is located inside the air conditioner at the center. Is it humming or making any kind of continuous noise or causing the lights to dim? If it is making a continuous noise, and your air conditioner is still not cooling at all, there may be a serious problem with one or more of these areas:
  • Compressor
  • Condenser
  • Evaporator
These items are not user serviceable. You will need to contact a qualified appliance repair technician to repair these components.
If the compressor is not running but you do have power to the air conditioner there may be a problem in one or more of these areas:
  • Compressor
  • Overload and/or relay
  • Thermostat (Open thermostat)
  • Burnt wiring
  • Bad selector switch
  • Capacitor
May 26, 2009 | Fedders A7D18E7B Thru-Wall/Window Air...
Fedders A7D18E7B Thru-Wall/Window Air Conditioner Logo
67 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
