Question about LXE MX6 Portable Terminal
Touch screen not working
Hand held scanner touch screen not working
    Problem Solver:
  • 9 Answers
Try taking it in and getting it calibrated. if that doesnt work its something wrong with the sensors and they arent picking up on your touch
Posted on Jun 01, 2009
My touch screen doesn't respond to touch and I am unable to make copies.
Does it respond to any touches or is it greyed out? This problem can be caused by either a bad touch pad or a defective scanner. Try accessing other options on the front such as the administrative menu. If those work, then the scanner might be bad or locked? Lift the automatic document feeder lid and check the lock on the left hand side to make sure the scanner is not locked. Restart the machine as well, could be an intermittent problem or static discharge.
Jun 06, 2011 | HP LaserJet M3035 MFP Printer
Hand held scanner to open a box?
If you were to have it open using any barcode, you could build a circuit that uses the beep of the scanner when it reads a barcode.
If you wanted it to only work with specific barcodes it would get far more complicated, you could right a program that displays a white or black box in a corner of your computer screen and just build a simple light detection circuit and tape the CDS Cell of the circuit on your screen where that box gets displayed.
Apr 23, 2010 | Uniden Hand Held Scanner - BC-246T 2-Way...
Can't use touchscrren - i've don't soft resets - no luck cleaned the screen won't calibrate
Try doing a hard reset. To do this you can follow these steps:
1. Press and hold the power button.
2. While holding the power button, use the tip of the stylus ( or a similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your hand held.
3. Wait for the Palm2.gif Powered logo to appear, and then release the power button.
4. When you see the message that warns you about erasing all of the info on your hand held do one of the following:
a) Press UP on the 5 way navigator button on the bottom of your hand held to finish the reset and show the touch screen.
b) Press any other button to do a soft reset.
5. When prompted , tap to align the screen, and then set the language you want to use on your hand held. A screen appears showing the Palm logo and a progress bar. From there continue to set up your Palm and then do a hot sync. Best wishes....Hope this helps.
Sep 16, 2009 | Palm Z22 Handheld
Hand held pro 83 scanner
http://support.radioshack.com/manuals/ome20-501.pdf
May 30, 2009 | Radio Shack Pro-82 Scanner
Cant get weather on hand held scanner
The 92 does not have a separate/dedicated weather band feature, but you can program individual NOAA frequencies into it. Weather broadcast frequencies are: 162.400 MHz : 162.425 MHz : 162.450 MHz : 162.475 MHz : 162.500 MHz : 162.525 MHz : 162.550 MHz.
Apr 10, 2009 | Uniden Nascar BC-92T Scanner
Not hearing certain frequincies
not all scanners will pick up the same, the hand held can't pick up frequency as far as the other one.
Mar 11, 2009 | Radio Shack Pro-97 Handheld Scanner
Hand held cb
installed ones, are you refering to base stations? these rigs are more powerful because of the higher wattage outputs and stable installed aerials. :) your handheld can put out as much as 5 watts of power.
May 18, 2008 | Radio Shack Pro-95 Handheld Scanner
Leapfrog leapster hand held console
Had the same problem and no target. Wait after it says touch the center of the target for at least 5 minutes maybe longer and suddenly it will beep and appear. After touching each of the 5 targets as they move from corner to corner and then center the stylus and touch screen once again worked.
Art
Jan 08, 2008 | Video Game Consoles & Games
LXE MX6 Portable Terminal Logo
350 people viewed this question
Top LXE Computers & Internet Experts
David Payne
David Payne
Are you a LXE Computer and Internet Expert? Answer questions, earn points and help others
