Question about AudioBahn AW1206T Car Subwoofer
No power to my subs
I have a audiobaun amp and two 12's. When i was driving my subs stoped hitting. My amp still lights up and the needles jump but my subs are not getting power. I check all the connections and everything is good.Could my amp be the problem and is there a way to test it? Probably a dumb question lol
    Problem Solver:
  • 14 Answers
It is a audiobaun. Get rid of it. :-)
Posted on Jun 01, 2009
Audiobaun 1800-dt amp smoked now have alot of engine noise
depending on the the amp make, it might be a resistor or a fuse that burnt in the grounding circuit, explaining the engine noise
Apr 29, 2010 | Car Audio & Video
MTX 12'' sub noise
Sounds like your sub is overextending itself, and possibly losing contact at the voice coil. Overextending will make a weird rattling sound, losing contact at the voice coil will make a popping sound.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jan 12, 2010 | Car Audio & Video
Power is not going to my sub
( I am assuming your amp does not turn on)
You will need a test light. You can get one at a hardware store for a dollar or two. clip the end of the test light lead to a good ground, and touch the needle to the red 12v constant that feeds the amp. If it lights up then you are getting power from the battery. Next, turn the car and the stereo on and touch the needle end of the light to the small blue signal wire that goes into the amp. This should light up as well. If either of these don't light up then the wiring is faulty. If they both light up then we need to test a bit more.
First make sure your ground wire is tight at both the amp and the car body. It should have metal to metal contact with the car (no paint on the contact area)
Apr 24, 2009 | Car Audio & Video
1000 w sony xplode works at low volume then red lights at volume5
Most likely one of your subs are blown, or the Ohm's are too low for the ampliphier. Try hooking up one speaker at a time to the amp and see if it does the same thing. If it shuts off on one of the two speakers, that speaker is most likely blown.
Apr 19, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
When powered on protection light comes on
ya i would say its not grounded right
Mar 02, 2009 | Car Audio & Video
I plugged int he rca's but he the lowest sounding bass possibe
kicker subs arnt ment to hit the lowest bass, unless you go spend a **** load of money, im talking 3000 wat amp, ant some 15' or bigger subs. the most commen kickers are 12' subs, so im asuming you have 12' subs, if not, this (said lightly) should work. try turning the bass boost screw on the amp to the middle of its turning range. this will offer the greatest balance between high and low bass. if you want more low bass, turn it past half. if you want more high bass, turn it down. i have mine set to mid range, but i also recently purchased 2 18' kickers. with every new set of subs, you should spend at least 15 min tuning the amp to get the best performance. every sub is different. hope this helps, good luck.
Jun 27, 2008 | Kicker KX800.2 Car Audio Amplifier
No volume
check when the amp is powered on the is a beat on start up -if yes then chk the input conetions of amps if no then chk output connetions of amp.
May 26, 2008 | AudioBahn 400w E Car Speaker
Amp cuts off
You may have a problem with the power source feeding the amp. You need to check the voltage across the amplifier's B+ and ground terminals when the amp is playing/cutting off. If it's dropping below ~11 volts, you need to determine why it's dropping so low.
Sep 18, 2007 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
My amp turns on then the music cuts in and out
check your main ground, if possible try to read voltage across making sure 12-14v present with load and some signal.
Aug 08, 2007 | Verge VGA285 Car Audio Amplifier
AudioBahn AW1206T Car Subwoofer Logo
94 people viewed this question
Top AudioBahn Car Audio & Video Experts
Colin Stickland
Colin Stickland
Jerry Naidoo
Robert Rankin
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
