Question about LXE MX6 Portable Terminal
Touch screen scanner is not working
The touch screen on my scanner is not working
Hello. I have two motorola mc9090 handheld scanners. Both are Clicking constantly (as if the screen was being touched) and when i try to touch the screen there is very little to no response.
The screen may be out of calibration. Press the blue FUNC and ESC keys to launch the calibration app. Use your stylus to touch the center of each target as it appears. If this doesn't work, you are likely in need of a touch-screen repair.
Sep 13, 2017 | Motorola Computers & Internet
Mpc4500 touch screen not working
Either the screen has failed. or the cable is disconnected. The cable that connects the screen to the main board. That cable is not user serviceable take the machine to a brother tech. I happen to be one but?
Nov 11, 2013 | Ricoh AFICIO MPC4000 MPC4501 SD YLD...
My touch screen doesn't respond to touch and I am unable to make copies.
Does it respond to any touches or is it greyed out? This problem can be caused by either a bad touch pad or a defective scanner. Try accessing other options on the front such as the administrative menu. If those work, then the scanner might be bad or locked? Lift the automatic document feeder lid and check the lock on the left hand side to make sure the scanner is not locked. Restart the machine as well, could be an intermittent problem or static discharge.
Jun 06, 2011 | HP LaserJet M3035 MFP Printer
Micromax x600 touch screen problem
my micromax mobile touch screen not working how to slove this problem.how to go inside screen setting
Feb 10, 2011 | Computers & Internet
No touch input is available for this display is indicated when u right click my computer then properties
That's not an error message unless your monitor is actually a touchscreen. It simply means the monitor is not a touch screen. A barcode scanner is not a touch input device.
Oct 21, 2010 | Computers & Internet
The scanner will not get past the ailgnment screen
Check if the plastic Touch screen is peeling from case, glue it. If you see some "smog" inside touch screen, Replace it.
Aug 23, 2010 | Symbol MC9060-G
Can you improve the screen touch sensativity on a MC9090-G RFID?
Quick answer no you can't. The touch screen is a resistive panel and hence you may get panels with slightly different tolerances, but that’s about it.
If they are old and worn they do tend to need a bit more persuasion to work and once they stop working they need replacing.
Hope this helps.
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL 01202 620955
http://www.biastechnology.com/
Jun 08, 2010 | Symbol MC9090-G RFID Handheld Barcode...
Touch screen not working
try taking it in and getting it calibrated. if that doesnt work its something wrong with the sensors and they arent picking up on your touch
Jun 01, 2009 | LXE MX6 Portable Terminal
How to fix the touch screen for a hp pavillion tx 2000
Please run system restore from your control panel to an earlier date.
Apr 24, 2009 | HP Pavilion TX2000Z Notebook
Can not get the scanner/email to work
NOTE: You must be a System Administrator to perform this solution.
  1. Press the [Log In / Out] button on the Control Panel. The Login screen will be displayed.
  2. Enter the System Administrator userID using the numeric keypad on the Control Panel, or select the [Keyboard] button on the Touch Screen to enter the userID, and then select [Save] on the Touch Screen.
  3. If necessary, enter the System Administrator password using the numeric keypad, or select the [Keyboard] button to enter the password, and then select [Save] on the Touch Screen.
    NOTE: The default userID is 11111, and the default password is x-admin (must be entered in lower case). If the userID and / or password have been forgotten, a service call must be placed.
  4. Select [Confirm] on the Touch Screen. The System Administrator Menu screen will be displayed.
  5. Select [System Settings] twice. The System Settings screen will be displayed.
  6. Select [Common Settings].
  7. Select [Maintenance / Diagnosis].
  8. Select [Software Options], and then select [Keyboard].
  9. Enter the Software Option password for the Scanner option using the keyboard on the Touch Screen.
    NOTE: The password can be found on the inside cover of the Scan Manual and is case sensitive.
  10. Select [Save].
  11. Select [Close] four times.
  12. Select [Exit].
Nov 15, 2007 | Xerox CopyCentre C128 Black and White...
LXE MX6 Portable Terminal Logo
105 people viewed this question
Top LXE Computers & Internet Experts
David Payne
David Payne
Are you a LXE Computer and Internet Expert? Answer questions, earn points and help others
