i-mate K-jam Smartphone
Problem for i-mate K-jam Smartphone
I-mate k-jam wont charge
By ella72 on Jun 01, 2009
i have an i-mate k-jam and it wont switch on. i have tried both the usb cable and the charger, but get no LED lights indicating charge?
Best Solution
posted on Jul 30, 2009
Very Helpful)
dmisdm
Rank: Apprentice
Rating: 100%, 1 votes
you cannot charge the i-mate unless you have it turned on
another way which worked for me is to buy a battery dock or a seperate
battery charger
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jun 01, 2009
Helpful)
sonu_sehgal
Rank: Guru
Rating: 88%, 455 votes
Sir please check your battry
Was this helpful?
Yes
No
Solution #3
posted on Jul 27, 2009
Somewhat Helpful)
pravdemon
Rank: Apprentice
Rating: 75%, 1 votes
battery checked and replaced with new one, still same.
Was this helpful?
Yes
No
Solution #4
posted on Aug 22, 2009
Not Rated)
19921992
Rank: Master
Rating: 0%, 0 votes
this has happened to me both times, but dont worry it is easy to fix. all you need to do is put enough charge in the battry to get it to turn on, even if its only for a second.
to do this, find an old phone charger or something similar, one that you no longe use. check that the output is 3.7volts dc. cut the end adapter off, and strimm the two wires back. IMPORTANT, USE A METER TO CHECK WHICH IS POSOTIVE AND WHICH IS NEGATIVE, mark the posotive with tape so you dont loose it.
take the battery out of the phone and plug your stripped down charger in. now simply touch the posotive wire to the posotie terminal on the battery, and the negative wire on the negative terminal. hold them there for arround 5 minits, and that should give it enough charge to turn the phone on long enough for you to plug it in. at this point the lights will turn on and the phone will be back to normal
to stop this from happening again, simply dont let your battery run totaly flat, if the warning comes up turn your phone off untill you can charge it
good luck :)
Was this helpful?
Yes
No
Popular Solutions for i-mate K-jam Smartphone
Questions and Unsolved Problems for i-mate K-jam Smartphone
Do you recommend i-mate K-jam Smartphone?
Answer
Answer
i cant access my gprs on my i-mate k- jam phone
Answer
iam not able to get any signal in my i mate kjam
Answer
i have imate jasjam mobile when i switch on my mobile only white screen will come i cant view the... (More)
Answer
I lost my installation cd and left my charger at a hotel was wonderin how to get my phone to charge... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PDA Experts
Top Computer & Laptop Repairmen
in , CA
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
