Question about JVC RV-NB1 Radio/Cassette/CD Boombox
Cant close CD Lid.
Small Plastic Catch on Lid Lock control broke. Where can I get replacement, please. I need a part number for the cd lid on my jvc rv-nb1
  • 29 Answers
Contact customer support at JVC America,they will help you there
Posted on Aug 20, 2009
Why is lid not locking?
Replace the lid lock. If you post a model number I can give you a part number. Over time lid locks sometimes wear out over time( most of them are 90% plastic). Lid locks should be relatively inexpensive. Also if this is a top load washer you can replace it yourself instead of hiring someone.
Aug 13, 2017 | Fisher and Paykel Washing Machines
Lid lock bypass
Your "lid lock" really is an interlock to prevent machine operation when the lid is open. I use a plastic clothespin to close the interlock because the lid on my washer got bent
May 12, 2013 | Frigidaire Washing Machines
Not work CD Player
HelloCheck the CD spins inside it, when we close the lid. if not, check the lid. There is a small swelling like formation at its edge that will get into the CD player, when we close it. This will hit on a micro switch inside the set, which in turn send a CD in signal to its system control IC. If this signal does not reach the main system control IC, it won't sense that CD is in. If this switching process is OK, when you close the CD lid, make sure that the CD mechanism has the trouble, and need service. OK.
Dec 18, 2011 | Aiwa CSD-TD49 Cassette/CD Boombox
Washer fills with water but won't agitate or spin.
Hello, welcome to FixYa.
Based on your description it sounds like a lid switch problem.
Here`s how you can check it pretty easily...
( this is based on the most common Whirlpool, Estate, Kitchen-Aid, Roper, Kenmore, Inglis topload washer, not neccessarily applicable to ALL...especially those built in the past 1-2yrs. the model number would distinguish if it applies to your particular model )
Lift the lid, if you observe the underside of the lid there will be a plastic "strike" or "actuator" that goes into a hole when the lid is closed.
Check the hole where the actuator goes into the cabinet and insure you can see a gray oval shaped piece. If so take a small screw-driver, pen/pencil or something small enough to fit thru the small hole and try activating the switch by pushing it down ( machine must be in the agitate or spin cycle ). If you don't see it, the switch has likely broken loose and needs to be replaced.
If it start's to function than the switch is not being contacted properly by the actuator on the lid and likely is due to the switch being worn...unless the actuator on the lid is broke, if so there`s the problem.
Make sure the switch is being held in place via the two screws along the side, if they are loose tighten them, if it is broken, it will need to be replaced.
Here`s a helpful link for changing it out,
http://videos.wittysparks.com/id/3098139337
The lid switch will look like this...
Let me know what you find and if I can assist you further.
good luck.
macmarkus :)
Aug 19, 2010 | Estate Washing Machines
Plastic catch broken DeLonghi KBX1510
try supper glue??? but dont hold your breth that this will work,,, it realy dont like hot wet places! i know this from first hand experience,,,
as its holding up my left lung!!!!!! and im not kidding you there?
Oct 24, 2009 | DeLonghi KBX1510 Cordless Electric Kettle
Kenmore Elite Oasis 27062, the lid lock broke
Simply attach both wires from the switch to jumper.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 11, 2009 | Kenmore 24032\24036 Top Load Washer
REPLACMENT CD LID LATCH FOR DURABRAND MOD. CD-1493
http://cgi.ebay.com/CD-DOOR-LID-LATCH-LOCKING-DEVICE-STEREO-BOOMBOX-PART_W0QQitemZ220225587206QQihZ012QQcategoryZ48626QQtcZphotoQQcmdZViewItem
Dec 20, 2008 | Durabrand CD Player with Cassette...
Lid Closure
OK - There is nothing that drives the door to close and stay closed. There is a little plastic gismo the locks onto a little protruding tongue in the lid keeping it closed. To release the lid, you must press the lid foreward so that it releases the lock in the little plastic gismo. I found this out only after removing the board above the main deck of the player and which, fumble-fingers me, I managed to damage the board and will have to replace it along with the little plastic gismo that holds the door closed. I am not sure if either of these parts are available as I have had the unit for quite a while. This leaves me in a quandry as I really did like the little player. It was a dandy. So, if you ever get an inquiry on how to keep the lid closed on a JMC_800, tell them to replace the little plastic gismo and that will do it.
Aug 29, 2008 | Jensen JMC-800 CD Shelf System
CD Lid/door catch broken, will not stay closed
Chris, I know it has been a while since you posted this and I don't know if you ever solved your problem but if not....you might want to check out this sight. http://search.express.ebay.com/Consumer-Electronics_MP3-Players-Portable-Audio_Boomboxes?_sop=2 Kennyblan@charter.net
Mar 26, 2007 | Cambridge Soundworks C1MUSWKE CD Shelf...
JVC RV-NB1 Radio/Cassette/CD Boombox Logo
271 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
