Question about Toshiba 42H83 42" Rear Projection HDTV-Ready Television
Toshiba 42 inch rear projection TV
When i first tuen it on the picture is all fuzzy with lines Horizontally going across after about 15 mins it starts to get clearer and after about half an hour it is fine, being at least 3 years old I would imagine something needs replacing can anyone tell me what it could be?
  • GradeA Oct 23, 2007
    are there any websites where i would be able to purchace one or is there a part number? I hve trawled google but to no avail
    thats great thank you
    I am in the uk but you certainly pointed me in the right direction
  • 87 Answers
You likely have a bad hyper board.  As time goes on the lenght of time it takes to get a clear picture will increase and eventually the picture will never clear up untill the part is either repaired or replaced.
Posted on Oct 23, 2007
  • Dewayne Turner Oct 23, 2007
    The part is NLA from toshiba.  The part nubmer is 23148024.
    You can send your old one to PTS Electronics for rebuild.  There telephone number is 800-844-7871.
Purple static lines and a jumpy picture
Your picture tube is about to go.
If it's still under warranty,take it back.
Hope this helps.
Nov 26, 2013 | Mitsubishi VS-45607 45" Rear Projection...
It has shrunk to about 6 inches all the way around the screen so the total picture sizr is 36 inches instead of the 42 inches otherwise clear picture little fuzzy when turning on but becomes a clear
Don't know what wires your using to connect to tv. It does matter, sometimes the connections go bad, either at the tv or cable box. Have you tryed to stretch picture in settings?
Feb 10, 2012 | Toshiba 42H82 42" Rear Projection...
FINE LINES HORIZONTALLY ACROSS SCREEN, ABOUT 2 INCHES FROM TOP. SCREEN IS DISTORTED ABOVE THESE LINES
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Mar 02, 2011 | Mitsubishi WT-42311 42" Rear Projection...
Green lines developing about every 6 inches going across horizontally with slight arch on end sony projection tv KP57WS500
This is convergence out ICs failure and will be replaced for correct picture in TV.
Let me know if you can solder parts in circuit board of TV with necessary tools to provide you IC number and store address, or call local TV tech for fix if you are not comfortable with TV repair.
Thanks.
Oct 31, 2009 | Sony KP-57WS500 57" Rear Projection...
Toshiba 52WM48 - Dark line across top of screen about 4 inches
replace the vertical ic, LA 7833 and four capacitors near it, i encountered this last two days.change the parts and it ok now.
cost of this parts is about $20.00
Jan 22, 2009 | Toshiba 42H83 42" Rear Projection...
Vizio 42'' LCD having intermittent fuzzy screen on stdrd channels
you might have an overheating problem- make sure you have adequate ventilation around your tv
Nov 25, 2008 | Vizio GV42L 42 in. LCD Television
Toshiba 42 WH36 P REAR PROJECTION
You have a convergence problem. Need to replace convergence IC's.
Jun 02, 2008 | Toshiba 42H81 42" Rear Projection...
RED AND GREEN LINES HORIZONTALLY ACROSS TV
This sounds like you may have bad picture tubes. Most likely the green and red tubes. You would have to have them replaced and realigned. I would call a Sony ASC and get an estimate to verify this. An onsite service call could verify if this is what's causing your problem.
Jan 22, 2008 | Sony KP-51HW40 51" Rear Projection...
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 23, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba - 50H13 Projection TV
There is a large metal case behind the input board in the back of the set called the hyper board that needs to be replaced.Good Luck
Oct 07, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba 42H83 42" Rear Projection HDTV-Ready Television Logo
150 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
