HP IPAQ 1930 does not hold the sd card.
When I insert any sd or sdio card into the slot and push it in, it fails to get held in and it springs back. HOw do I fix the problem.Any suggestions. (The sd card and the sdio cards are checked on other pda's and work flawlessly)
  • 61 Answers
It might need to be pushed in another millimeter? i use a finger nail.
Posted on Jun 01, 2009
How to remove/load sd card stuck in Huawai M860
The SD memory card slot is spring loaded, to insert the memory card insert the card into the SD memory slot with the SD card contacts going in first and gently push it in until it locks in place. NOTE if the SD card does not slide into the slot easily then the SD memory card has been inserted back to front, turn the SD card around and insert it again.
To remove an installed SD memory card, press the SD memory card and it will pop out slightly then you can then pull out the SD memory card.
Mar 12, 2013 | Cameras
Were can i find a sd wifi card for ipaq h3970
I don't know where you are in the world, but searching eBay for "SDIO" usually turns up a good selection of SD wifi cards.
Jan 30, 2010 | Compaq iPAQ H3970 Pocket PC
How do I set-up my WLAN card to my HP iPAQ Hw6515
The HP IPAQ 6515 will support WLAN access via a SDIO WIFI card (which looks like a 'long' standard SD card): it is just a bit tricky to get this add-onl SDIO WIFI card to work properly!
For more deatils and confirmation, please google:
ipaq+6515+sdio+card
Sep 29, 2009 | HP iPAQ hw6515 Pocket PC
pls i want dell inspiron 1525 drivers .pls help us.
Thanx
pradeep
Jun 01, 2009 | Dell Latitude D600 Notebook
IPAQ 6515 doesn't recognize new HP 8Gig SD card when inserted. I reset but nothing happened. Any idea what the problem might be.
I am sorry?
You want me to give you my solution for nothing and want to charge me $9.95 for it.
I could not find any posted solutions when I checked your site.
Dec 13, 2008 | HP iPAQ hw6515 Pocket PC
HP IPAQ H4150 + Memory Cards
Your HP IPAQ has a SDIO expansions slot...
which is a new technology.
so will have to use an SDIO card ...
this is a secure digital IO card.
hope this will solve the problem
Oct 30, 2008 | HP iPAQ H4150 Pocket PC
HP ipaq with navtec gps software and sd card fails
Ok, nice job Robert,
I'm posting your solution here to remove it from the unsolved problems list.
Solution by Robert:
This problem was finally resolved as a corrupted map file on the SD memory card in the hp ipaq 5550. Solution was to reformat the memory card using fat32 memory format. I used a SD memory card slot on my laptop and right click the drive letter and select format to format the memory card. After that, I reloaded map files to the memory card and all was OK. Note that previously I had loaded map files on the memory card successfully but that was not good enough. A reformat of the memory card was apparently needed.
I had also previously tried a hard full reset of the ipaq by pressing and holding the lower two buttons (calendar and itask) while holding in the reset button with the stylus for 5 seconds and resynced my contacts and reloaded the gps software, but this was to no avail. Try the re-format.
Jun 22, 2008 | HP iPAQ H5550 Pocket PC
Palce where to insert sim card
It's not a phone. It's a pocket PC.
CAUTION: For synchronization to work properly, install Microsoft
ActiveSync on your personal computer before you connect your
iPAQ Pocket PC to your computer.
To install a CompactFlash (CF) or Secure Digital (SD) card into
an expansion slot on the iPAQ Pocket PC:
1. Locate the appropriate slot on the top of the iPAQ Pocket PC.
To identify slot locations, refer to the Getting Started
document that came with the iPAQ Pocket PC.
2. Before inserting a CompactFlash (CF) card into the CF
expansion slot, pull the plastic slot cover from the CF slot.
3. Insert the expansion card into the appropriate expansion slot
and push the connection edge of the card firmly into the
expansion slot.
✎If your expansion card is not recognized, follow the card
manufacturer’s instructions to install it.
✎For more detailed help, refer to the Help files installed on your
iPAQ Pocket PC. From the Start menu, tap Help > Connections.
✎To prevent power loss, remove any expansion cards from either
the CF or SD expansion slots before turning off the iPAQ
Pocket PC.
44bf6e2.jpg Your iPAQ Pocket PC supports 802.11b Wireless LAN (WLAN) technology using the expansion slot in the top of the device. Figure 1: Expansion slot c00059391.jpg To make your Pocket PC a WLAN device, you need:
  • To purchase a WLAN CF or SDIO expansion card
  • To have access to a wireless network
Dec 29, 2007 | HP iPAQ H2215 Pocket PC
My Pocket PC with a 4Gb Sd
Hi tHEyOs, Well I?ve been poking around and here are the facts I?ve found: -The largest SD memory card HP lists as an accessory is a 2GB card. -The actual specifications sheet states the SD slot supports SD, SDIO and MMC but makes no mention of any size limitation. My suspicion based on my own personal use of HP hand held PCs is that it will probably accommodate your GB SD memory card. In my own personal experience is that the devices list as accessories only those memory cards that were prevalent at the time the PC was released. So even though the HP site only lists 2GB as the largest its only because the larger cards didn?t exist in the marketplace at the time so it really isn?t any kind of indicator. To me the specifications sheet is the ultimate reference and it doesn?t make note of any type of imitation. If you are still apprehensive buy the memory from a mail order house like TigerDirect and tell them you want a 4GB SD module for an HP H2210 PocketPC. If it doesn?t work you can return it for a full credit. If you have any more questions let us know and please don?t forget to rate the posting.
Feb 11, 2007 | HP iPAQ H2210 Pocket PC
IPAC 2210 + 2GB SD Cards
FYI - Use the SDIO update from the HP site, then do a hard reset and maybe even a couple os soft resets. Interestingly, it takes a while for it to appear (the SD Card). Even if you take it out and put it back, you will need 1 or 2 soft resets to get it to show up.
Sep 11, 2005 | HP iPAQ H2210 Pocket PC
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
