Refrigerators Logo
Posted on Oct 23, 2007
Very little ice
My ice maker is not making much ice
  • 8 more comments
  • Anonymous Mar 14, 2008
    not making ice
  • Anonymous Apr 29, 2008
    very little ice
  • DocHolladay May 12, 2008
    my icemaker is not making much ice
  • reremac May 18, 2008
    ice maker not making ice
  • Celtie Jul 21, 2008
    again ice maker is not making very much ice. Does anyone have a solution? I just turned down the temperature to see if that would speed up the process. We get one ice dump every 8 hours. Your thoughts?
  • Anonymous Jul 22, 2008
    ice maker not making too much ice
  • Anonymous Sep 05, 2008
    Ice maker will only dump once or twice a day.
  • Cheryllaney Oct 04, 2008
    Our Scotsman is producing about 1 to 2 ice cubes an hour. Once the cubes drop down into the bin they start to melt slowly. The repair man came and replaced a part (I'm so sorry that I don't know what part, but it was in a very small 4"X6" box). He turned it back on when he left, and it began to do the same thing. The inside of the box is cool, but not 32 deg. Any ideas what the problem is?
  • Anonymous Oct 06, 2008
    Little ice is made. It appears that the action that kicks out the ice when dumping gets hung up and when you manually push it back down, it will make another tray of ice.
  • IHateMyFrig Oct 16, 2008
    I've had the same problem for quite some time. Usually an ice cube gets stuck and prevents the mechanism from moving. I move it manually and it will make anywhere between 5 ice cubes to 500. Really great for planning a party!!
A
Anonymous
The problem may be connected to the mineral content in your water supply. Particles can bond at the valve/water supply line entry point and restrict flow. Turn water supply off, remove icemake line, carefully screw openings, have someone open water valve and expel particles. a solid stream means it's ok. A dribble means it needs more reaming ..repeat if necassary. If flow is good and ice crescents are still small then the icemaker valve on the refrigerator may need to be replaced. A quick fix can be tried by taking off the IceMaker face. Increase duration of fill by turning adj. toward "+''. judge lar
amershan
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 20, 2008
amershan
Contributor
Level 1:
Answers
Questions
0
Helped
790
Points
We just hooked the water up today at 1:00 PM and I have a few cubes but it is not full. How long does it take to fill it up? Is there something I can do to fix the problem?
Why is icemaker making a clicking sound?
Ice Maker Not Dispensing Ice ' ThriftyFun
www.thriftyfun.com/Ice-Maker-Not-Dispensing-Ice-4.html
Sometimes your refrigerator ice maker makes ice, but does not dispense it. ... If it gets pushed all the way back to the ice maker it prevents the metal arm from full ... Itry not to put anything on the shelf over the bin and also try to keep it pulled out just a little ... My ice maker is making a clicking noise and not making much ice.
Ice maker making ice, but won't come out thru door
www.appliance-repair-it.com/ice-maker-making-ice-but-wont-come-out-...
If when you attempt to dispense ice (and it doesn't work) the whole refrigerator seems to .... Many have just bought a new refridgerator or don't use the ice dispenser. ... I'vetried to decrease the cold in it from the dial and that doesn't help. ... The motor was working and the auger would turn with no ice in bin but the added ...
4helpful
2answers
Ice Maker not making ice
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
2answers
Frigidaire FRS26ZNHD2-ice maker stopped making ice called Frigidaires 800# they told me to replace the 2 stage water valve did that still no water to ice maker
ice maker is bad has it,s own timer built in to let water in if you have water to your unit ,,, be sure the little lever is down on top of the ice bucket. if it is up this will stop the ice making process this i s a device to keep the ice from over filling the ice bucket
Ice maker isn't working. It won't make ice. We
The Icemaker in the 215 is a complex little turkey.....
Here's a link to the service manual PDF...Pretty good ice maker sections.
http://www.ajmadison.com/ajmadison/itemdocs/DA68-01778A-EN.pdf
2helpful
GE ICE MAKER, VERY LITTLE ICE,
I had this problem with my GE ice maker not working and it was an unbelievably easy fix. If you have the same ice maker then you will see a green light by the power switch. Below the ice maker is a "paddle" ice sensor. The paddle is attached to the ice maker and there is a coil type tension spring. If your paddle is loose, make sure the end of the spring (the pointy wire end) is inserted into a small hole. You probably can't see the hole but move the wire end until it pops into the small hole. You should now have tension on the paddle. At this point I had heard that the freezer light bulb may be drawing too much current for the ice makers motherboard. I removed the bulb and, UNBELIEVABLY, the ice maker began making ice! Try removing or replacing the LIGHT BULB first!
Ice maker won't kick out the ice
sounds like the heater in it is going bad that heats up the metal you just have to replace the ice maker
1helpful
GE Bottom freezermakes little ice
The ice maker has a temperature sensor inside that lets the ice maker know its time to drop the ice and refill with water. That could be the problem or the water control valve for the ice maker is not opening when its called to refill the trays. I will try to help you, Sea Breeze
Ice maker not making ice. red light on control panel blinking twice.
Remove the ice bucket and inspect the ice maker for an ice cube stuck in the ejector. Hit it with a little heat of a hair dryer till it gets loose and the ice maker starts rotating. Replace the ice bucket. See if it starts making ice again amigo.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Ice maker won't stop making ice
it's time to replace the ice maker, it will not stop, the you can feel the small bar when it looks in to the of position.
Kenmore Elite refrigerator 795.775.62600
make sure the ice maker is turned on, push and hold the little round button on the front for 15 seconda and see if it starts up an cycles. Also check to make sure the fill tube isn't clogged to the ice maker and another thing to check is the water valve.
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
