Question about Toshiba Satellite M55-S331 Notebook
VGA connection from PC to TV --TV says "no signal"
I have a Toshiba Satellite M-55 series laptop and an Element HDTV.
I'm trying to use the TV as a larger monitor and followed the directions from the TV manual. I'm using a VGA connector but get a "no signal" message from the TV. Is there a setting on the computer that needs to be changed regarding the monitor or display output?
On the remote control for your television, there should be a source or input button. Pressing the key repeatedly will switch from cable input to standard tv input, to s-video, or ypbr, or game, or various others. Try doing this and see if the image appears, this awlays works for me. If I am telling you something you have already tried, i am sorry!
Posted on Jun 01, 2009
What do I need to connect a laptop toshiba Satellite L675D-S7052 to a high definition tv
Assuming what you are trying to do is make your HDTV a giant monitor, your HDTV will need analog video input capability --either a standard d-type VGA connector or RGB composite RCA plugs. The laptop has a d-type VGA output. You will need a cable that has matching end for your laptop and TV....either VGA-to-VGA (d-type) or VGA-to-composite. This will handle the vcideo. You will also need a min stereo-to-mini-stereo cable to connect the audio from the headphone output of the laptop to the HDTV.
Sep 06, 2014 | Toshiba Computers & Internet
Laptop to HDTV
... you can probably buy a usb adapter for your computer... might try ebay
Oct 13, 2013 | Toshiba Satellite L655d-s5050 2.1ghz 3gb...
Will my sanyo hdtv hook up to my toshiba satellite c655
If your TV has a VGA computer input connector, the you can connect a VGA cable from the TV to the video port on the Toshiba laptop.
Jan 27, 2013 | Toshiba Satellite C655-S5068 Notebook
I connected my Toshiba L305 laptop via a VGA cable to my hdtv and it worked beautifully for a while. Suddenly, the TV indicated that there is no signal. I
If you were using the computer at the time, it may be a cable/plug/socket failure. Try a different cable.
If you were watching a movie, you may want to check your screen saver settings. Try doing what you were doing and see if it disconnects after a specific time (so if your screensaver is set to 10 minutes, does your TV lose signal after 10 minutes?).
Apr 30, 2012 | Toshiba Satellite L305-S5911 Notebook PC
How do I connect a Toshiba Satellite to my Plasma TV
1. Make sure both the laptop and the TV have VGA adapters.
2. Get a VGA cable to connect the two
3. Upon connecting, press the input button on the remote and navigate to an option that says something like "VGA Computer"
4. On your computer, go to Start and in the search box, look for connecting to a projector.
5. Choose the option that suits your needs and you should be connected.
Hope this helps!
Aug 26, 2011 | Toshiba Satellite L500 Series Notebook
What do I need and how do I connect my Toshiba L305 model PSLB8 050302f to my hdtv to view online tv?
I dont believe that laptop has an HDMI port on it. If you have an LCD TV then your TV may have a VGA or DVI input on it. You can connect your laptop to the TV by using a VGA to VGA or VGA to DVI cable. If you your TV doesn't have one of these input ports, then you're not going to get your laptop connected to your TV.
Mar 03, 2011 | Toshiba Satellite Pro L300 Notebook
Trying to connect my toshiba satellite a205-s5804 laptop to my sony bravia lcd 1080 t.v. I have connected VGA from laptop to t.v.VGA pc in on t.v..Also headphone out to sound in on t.v.. T.V. not excepting...
Please double check that your VGA cable is working properly and you have installed the most updated version of video drivers.
Is the TV not even playing the sound? Are you on the right channel? Only try checking the sound on a AV channel by using a headphone jack to AV jack cable.
If you have a S-Video port try connecting with it you can get that cable for a buck in a dollar store.
Hope this helps.
Mar 23, 2010 | Toshiba Satellite A205-S5804 PC Notebook
Can i connect toshiba satellite a205 to tv?
Yes VGA carries RGBHV--RGB and Horizontal and Vertical Sync information along with DDC info where available.
Now is that port on your TV a d-sub 15 pin standard VGA connector?
http://en.wikipedia.org/wiki/VGA_connector
If it is, then yeah you should be able to output VGA from a PC to the TV with a proper cable.
However if the TV has DVI or HDMI connections on it, it's better for you to connect it that way. DVI/HDMI is a digital signal and if it's a digital-based display tech TV, then you're better off using that. Also if the TV does resolution above 1360x768 (i.e. if it does 1080p) you can get higher resolution by going via DVI/HDMI...
Dec 01, 2008 | Toshiba Satellite A205-S4617 Notebook
Open Questions:
Toshiba Satellite M55-S331 Notebook Logo
651 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
