Question about GE Ovens
My GE XL44 Oven turns on by itself. Not sure what is going on and I do not want my hosue to burn down. Any ideas? Thanks. The oven is only 5 years old. I'm having the exact same issue. The oven frequently turns on by itself and seems to get hotter every time it does. Apparently the true model number for this unit is JGBW21HED3WW.
docjohn174
  • 943 Answers
SOURCE: GE XL44 gas oven
hi thanks for the question just because the igniter lights up doesn't mean its good, the gas will not light, if igniter isn,t hot enough. and a very common problem is that the igniter does come on, but not hot enough to ignite the gas . replace the igniter thanks the appliance doc
Posted on Sep 30, 2008
SOURCE: Amana Electric Oven Issue
My oven never reaches the proper temperature sitting for baking. Controls for the oven only is push buttons. How can I adjust this. This has been going on since I have bought the Amana
Posted on Nov 08, 2008
  • 29 Answers
SOURCE: GE XL44 oven not working, but the broiler is...???
CHECK THE IGNITOR, IT SHOULD BE GLOWING ORANGE BEFORE GAS IGNITES. IF NO GLOW, REPLACE IGNITOR.
Posted on Jan 28, 2009
WRMtech
  • 70 Answers
SOURCE: ge xl44 oven not igniting but burners ignite
The most common failure for a nobake on this type of oven is the bake ignitor. turn unit on and look at the bottom of the oven, you should after about 30-45 seconds see an ORANGE glow, if you do not, chances are you have a failed ignitor.Remove lower part of oven and if you have a meter, place one lead on each terminal and check for continuity( a closed circuit)
If you have an "open" circuit, the ignitor is bad
Posted on Feb 26, 2009
SOURCE: What are the instructions to clean my self
Do you have a model number?
XL44 is a line of ranges.
Instruction Manuals can be found HERE
Posted on Mar 20, 2009
Ge xl44 gas range, oven will not come on. everthing else works fine
If you see the ignitor glowing down there that means power is getting to the oven circuit. You have a weak ignitor if that is the case. Sometimes you can bump it and make it work. Check out this video
Sillicone carbide ignitor operation
XL44 service manual
Jan 31, 2011 | GE Ovens
GE gas oven XL44 JGBP29GES1WW not enough heat
I suspect a faulty ignitor. It must draw a certain amount of amps to open the gas valve
XL44
Jun 09, 2010 | GE Ovens
Oven won't light.
Make sure your oven timer is not set for automatic cooking
Dec 06, 2009 | GE Ovens
I have a GE Profile Spectra XL44. When I turned my oven on to 375 it read 100 degrees for 10 mins. I open the door and there was no heat. I then tried the broiler to make sure it worked and the the element...
i wouldn't say it is "normal", but yes, the bake element in the bottom could have burned out again. it depends too on how often you use the oven. if you use it every day, chances are it will burn out quicker than say someone who only uses it once a week. you can check the element for a burn hole or a blister break. you can also check it for continuity with an ohm meter if you have one. hope this helps.
Nov 07, 2009 | GE Ovens
Ge xl44 oven not igniting but burners ignite
Feb 26, 2009 | GE JGRP17 Gas Single Oven
Jan 28, 2009 | GE JGRP17 Gas Single Oven
GE XL44 gas oven
Jun 25, 2008 | GE JGRP17 Gas Single Oven
Ovens Logo
205 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
