Question about JBL BP1200.1 Car Audio Amplifier
No audio,tuner is ok
After battery replacement my 2001 Sienna LE, my car radio is turning on but no sound.Any help is appreciated.
  • erebooni Jun 02, 2009
    Sorry for confusion, it turns on and tuner is working, you can tune to any station you want to, but there is no sound. Thank you for you response anyway.
  • 61 Answers
Do you have to enter a code? they are normally in your car handbook. call the manufacturer and ask them? holden will give codes to there stereos? and some just don't want to work!
Posted on Jun 01, 2009
2005 Toyota Sienna. Radio turns on, can see station or CD, but no sound from speakers at all. Complete silence. Just one day, stopped working while driving.
If you have a multi-speaker setup like my 4Runner (also an 2005) Toyota uses a separate amplifier; i.e. not built into the the head unit (radio). The only home solution would be to clean the contacts where all the plugs connect. Back of the head unit, and the amplifier. If this doesn't fix it the amplifier probably has failed or the electronics in the head unit. Don't forget to disconnect the negative battery cable before doing any of this work, and make sure you have the security codes for the radio before you disconnect.
Nov 25, 2014 | 2005 Toyota Sienna LE
I have a 2009 Toyota Sienna van and had the battery replaced, the radio will not work now.
Does radio show "CODE" in the display?
Call dealer or look in your owners manual.
4 digit code will get it back.
Always save the "memory" in the systems when changing the battery.
Use an external 12 V. source to keep computer,clock and radio
memory.
Losing memory may cause the engine to NOT idle and run poorly as well.
A 9 V. battery in the cigarette lighter is one way.
Mar 02, 2013 | 2009 Toyota Sienna
Problem with 2005 Toyota Sienna
Check all fuse panels & fusible links
Sep 30, 2012 | 2005 Toyota Sienna LE
I have a 2001 Sienna. I find in the morning the radio will sometimes lose it's presets. Also,the van starts fine but the odd time, when you go to start the engine, nothing happens when the key is turned. ...
If it starts without a jump, i would say it's the igntion switch that cuts off power to the radio at times. If it does need to be jumped, then replace the battery.
Jan 10, 2011 | 2001 Toyota Sienna
When turn on airconditioner the air too smell no good with toyota sienna 2001 le
The system is full of 'stuff', the filters are dirty etc. Get it cleaned in a professional shop. Or you can buy a quick first aid: a scent'bomb', which you let seep into your AC filters. Will keep the air fresh for about a month.
Oct 24, 2009 | 2001 Toyota Sienna
Pioneer deh-6400 tuner has no audiobut cd plays ok
Did you also use an antena adapter? If not you may need one. Original in the vehicle is small and can pop out from the radio.
May 18, 2009 | Pioneer DEH-P6400 CD Player
Radio turns off in starting position
this look like a low battery and every time you try to crank your car it takes more power and kill the main power to the radio
solution # 2 the radio as 2 power wires one is always hot ( with current) and the other is connected to the ignition switch if you have replaced the radio those 2 wires maybe are connected backwards the one that goes to the switch is probably connected directly to the battery and the one is suppose to be always hot is probably connected to the switch if you have the original radio have your battery tested and if is ok then try get a haynes book at any auto parts for you car and try to follow the wire that is always hot normally is a yellow or orange wire
solution #3 this apply only if you car still have the original radio
turn your ignition switch to the on position but don't crank your car and turn your radio on select a radio station then turn your ignition key off and wait 3 minutes then turn your ignition switch on again with out cranking your car and the radio should be in the same radio station you select if this test pass then chances are is your battery getting low and if this test fail then the hot wire has a blow fuse look for the fuse inside the hook let me know what happend and good luck
Mar 18, 2009 | 2001 Toyota Sienna
Where is the fuse for the radio.....2001 sienna
There are two fuses for the radio...RADIO No. 1 and RADIO no. 2
RADIO No 1 is under the hood in the engine compartment fuse box
RADIO no. 2 in in the fusebox under the dash, on the left side of the instrument panel.
The graciousness of a FixYa rating for my assistance would be greatly appreciated.
Jan 14, 2009 | 2001 Toyota Sienna
JBL BP1200.1 Car Audio Amplifier Logo
149 people viewed this question
Top JBL Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Mark Skinner
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
