Question about Pioneer (DVR-108) DVD±RW Dual Layer Burner
Not reading DVDs
My DVD drive has stopped reading DVDs although it still reads CDs. I have tried installing a new driver and also uninstalled and reinstalled the drive but it hasn't helped. The problem affects both data and video DVDs.
Thanks for your help,
Terry
    Novelist:
    Champion:
  • 382 Answers
What is the computer and operating system?
Posted on Oct 24, 2007
TSSTcorp TS-L632 (B) drive is writing CDs, reading DVDs but not writing DVDs.
First check that your drive is indeed a DVD writer and not a 'hybrid' i.e. CD writer and DVD reader. If it is, go on the manufacturer's site and see if they have Win 8 compatible drivers - Win 8 is a fairly new OS so they may not have had time to get a new one out.
Feb 19, 2013 | Computers & Internet
It reads CDs, but DVDs: "Please insert a disk in drive.."
DVD SOHD-16P9S drive doesn't read any kind of CD or DVD
hi,there is no problem in drivers .
check the hardware parts
there are 2 possibilities in your case
1.the laser beam which reads the dvd or cds is malfunctioning
2.ensure that the cable & buses are properly connected
in case laser beam is damaged you got to get it repaired for proper functioning
all the best
Dec 19, 2007 | Lite On SOHD - 16P9S Internal DVD Drive
Can't read the cds & dvds
make sure the dvd drive is getting power
you might have to physically unplug the plug you cd rom back in this should activate the found new harware wizard or you might try
control panel admistrive tools,computer management,device manager scroll cd/dvd rom drives right click you can update driver disable or uninstall select properties from there you can troubleshoot or select driver you can update roll back driver uninstall if at any time you see a yellow question mark? you need to install a driver
hope this helps
Nov 17, 2010 | LG (GDR-8162BI) (GDR8162BI) Internal DVD...
Dell vostro 1510 dvd drive problem
update the firmware and or update your dvd drivers
Jul 21, 2009 | Dell DVD-rom DVD Drive
My cd drive will read cds but not dvds i try to istall somethig it wont work
Hi dkush29306,
while the other two posters have pointed out the obvious, that CDROM drives only read CDs, and that you need a DVD drive to read DVDs, i would like to add something to this.
I will asume you have a CDROM COMBO Drive, that *should* play CDRs and DVDs.
if you find it does spin CDs up and read them, but not DVDs then i might be able to offer some suggestions.
firstly, make sure there is no software conflicts (like two CD Writing softwares trying to use the CD Drive at the same time.. ). you shouldnt have to worry about drivers for the CDROM, as the default OS ones should suffice. but they may be corrupt. you could goto Device Manager if you are on Windows, and uninstall and reinstall the driver for the CDROM. it should find it automatically in the install wizard.
ok at this point i don't see how software could cause any other issue , so we should look at it being a hardware issue:
if you have the ability, try changing the IDE Ribbon Cable that connects the CDROM to the Motherboard. if that doesnt work, try changing which plug in the IDE cable the CDROM plugs into. these plugs usually have a blue plug at one end (motherboard end), and there is two plugs at the other end, or master and slave. keep the jumper pin on the CDROM set to Cable Select, so you dont need to change it to slave, when its plugged into the slave port, or master pin if set to the master port.
finally, if none of that helps (and it probably won't ) you might find that the actual fault is due to the laser in the CDROM not focusing tightly enough and therefore cannot read the data on a DVD ROM because of this. the only way to tell if this is ok or not, is to plug it into another computer and see if it can read DVDs.
you might just be better off spending 20-50$ and buying a new CDROM Combo drive from your local computer hardware store.
Jul 17, 2009 | Computers & Internet
My laptop still cant read cds or dvds
Try going to the site for the manufacturer of the cd/dvd drive and download/ install the latest driver. Also look in devive manager to see if you have any conflicts (yellow ?)
Feb 11, 2009 | Toshiba Satellite A135-S2386 Notebook
DVD-RW not recognising blank disk
Did you try a DVD firmware update? Some dvds need new firmware to reconize some DVDs
May 30, 2008 | Computers & Internet
DVDRW will not read CDs
1)right clik on my computer
go to
properties
device manager
clik on cdrom
uninstall it then re-install it
after reinstall try using the drive
2)update windows ,use custom and see if it finds an updated driver,if it does or doesnt update windows anyhow.
after you restart the computer try using the rom drive.
if that doesnt work;
go buy a cd/dvd rom cleaning disk at your local electronics store and use it.
if all this doesnt work;
buy a new rom drive
Dec 08, 2007 | Computers & Internet
Pioneer (DVR-108) DVD±RW Dual Layer Burner Logo
195 people viewed this question
Top Pioneer Computers & Internet Experts
Computer Links
MadeletricO
MadeletricO
Paul Bade
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
