Question about HP OfficeJet 7110 All-In-One Thermal Printer
Scanner Error Turn printer off & back on
When we print several jobs or try to copy & especially scan jobs we will get a scanner error.  We have uninstalled & reinstalled the software.  The printer & everything still works just annoying to have to turn it off all the time.
  • 5 more comments
  • Anonymous Nov 08, 2007
    I have the same problem
  • Medic-6194 Nov 12, 2007
    ANY fax recieved, copy job, or just sitting on the desk for 30 seconds, a "SCANNER FAILURE" appears and asks to be turned off and on again. No matter how many times we do as it asks, the result is the same.
  • jimbol Nov 12, 2007
    the problem is the same error scanner turn off... but when i turn on there is the same problem...
  • evamc Dec 06, 2007
    scanner failure, turn printer off and back on, Still same problem
  • demiana Dec 24, 2007
    My printer keeps asking me to turn it off and on but the scanner error keeps coming back. I need to know what to do becasue it is paralyzing my operations. I can only print from my PC. I can't scan, fax, or copy.
  • Anonymous Jan 30, 2008
    have to turn it off all the time. And the printer can not copy or scan. please help.gbenga from Nigeria
  • Anonymous Mar 23, 2014
    Dear Sir/Madam,
    We have the Toshiba 523. It completely does not work in copying, although it works in first time after turning on.
    Unfortunately there is not any maintenance company and related services in here. It should be mentioned that the printer and scanner of the devise works properly.Thank you for your time and consideration.
    Best Regards,
    Amir Abdi
    New Friend:
Dear Sir/Madam,
Best Regards,
Amir Abdi
Posted on Mar 23, 2014
    New Friend:
I m italian my inglish is not good... i solve the problem clean the guide of the carrel of the light... so i can run more easy...
Posted on Nov 13, 2007
Solving scanner error 5
If you are using windows - go to Printers / Devices and uninstall the printer
Turn the printer off and wait a couple of minutes
Now turn on the printer
Now add the printer in windows again and it should work
Jun 30, 2017 | The Office Equipment & Supplies
Screen saying scanner error
You can try uninstall and install printer driver or try a known good connectivity cable.
Dec 13, 2012 | Canon MX310 Office All-In-One Printer
Can't get the scanner to work
Check if it's a hardware, software or a USB connection problem.
If you are able to make a copy using the Copy button on the printer operator panel, then hardware is good.
Try to disconnect and reconnect the printer into your computer.
Then send a print job. If print job is sent successfully, then USB connection is good.
Try to update your printer driver by reinstalling the printer software. If you are scanning a document for editing, make sure the Lexmark OCR scan software is installed on your computer. The scan software is avialable only on the installation disc that came with your printer.
If problem continues, please contact Lexmark Technical Support Center to further troubleshoot this problem.
Jul 06, 2011 | Lexmark X8350 InkJet Printer
My HP Photosmart C5240 will print from computer but will not scan or make copies.
Is there any error message displayed on the control panel of the printer just like one of the following:
Scanner failure, power off and on
Scanner System Failure
Scanner failed, cannot make copies or fax
Scanner failure. Unable to scan, copy, or send a fax
Scanner failure, cycle power
You may want to try following these steps:
1. Check if the scanner light does turn on when you initiated the scanning process, if not you need to reset the product.
2. Try using your other electrical outlet because your AVR or Surge Extension may not be providing enough voltage for the printer.
3. Try using dirty cycle, meaning you need to directly cut the power of your printer by pulling of the power cord from the rear side of your printer and wait for about 30 seconds before inserting again and turn it on.
If all these steps do not improve your printer functionality, you may want to call the HP online help and ask for replacement.
Job Espinosa
Feb 15, 2011 | HP Photosmart C5280 Printer
I cannot print or copy with my HP LASERJET MFP M2727 NFS because the control panne show this error: SCANNER INITIALIZING ERROR 5. The only thing that is suggested is to turn on the device. When I turn on...
This sounds like a Scanner/Flatbed Problem. This series of printers have a known problem with this component. The scanner is failing to initialize itself. The scanner does need to be changed by an Authorized HP Warranty Repair Facility. It is possible that it may be covered under an HP Extended Warranty program. See repair information VIA posted Link.
M2727INFORMATION
Cheers!!
Jan 27, 2011 | HP Laserjet M2727nf Multifunction Printer
Canon Pixma MP198 error code 2 114 0
i got a same prob..i can't print,scan and copy and the refill warning always appeared..i hv refill the cartridge and i shut it down and try again and again..it's the cartridge prob or the printer prob..?
Feb 21, 2010 | Canon PIXMA MP190 All-In-One InkJet...
I have an Epson CX9400Fax all in one printer, fax, scanner. Yesterday it quit accepting print commands from the computer. It still copies, scans and saves scan files from the unit to the computer so I am...
Reinstalling the software is great, but did you first remove your printer usb cable, uninstall the printer and then re-install your software?
If not, do those 3 steps in that order and try printing again.
Best wishes,
Graemevm
Dec 17, 2009 | Epson Stylus CX9400Fax InkJet Photo...
I/O error when trying to scan. Used to work OK
Good day Sir,
These are my suggested solutions.
  • There ma be a copying or printing job in progress. When the job is complete, try your job again.
  • The selected port is currently being used. Restart your computer and try again.
  • The scanner driver is not installed or the operating environment is not setup properly.
  • Ensure that the machine is properly connected and the power is on, then restart your computer.
  • The USB cable may be improperly connected or the power may be off.
Thank you and God bless.
Nov 19, 2009 | Samsung SCX 4200 All-In-One Laser Printer
My all in one printer/scanner is not scanning. prints and copies fine, but does not scan
Form your issue that you are able to print and copy but unable to scan it is very clear that it is a software issue. Copy and scan fuctions work this way.
Copy - completely related to hardware.
Scan - related to software
uninstall and reinstall the full version software from Hp for the operation system of your computer.
Aug 23, 2009 | HP DeskJet F4280 All In One Printer InkJet
HP OfficeJet 7110 All-In-One Thermal Printer Logo
314 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
