Question about Epson LQ-2180 Dot Matrix Printer
After connecting, its all lights(10) are of/on symalteneously but not responce by any switch
After connecting its all lights(10) are of/on symalteneously but not responce any switch
    Problem Solver:
  • 9 Answers
Switch Off the printer and Check for carriage Movement manually.
Posted on Jun 01, 2009
Turned key in ignition got no responce tried connect to ecu unable to respond
With a voltmeter check out the main battery fuse cartridge located in the fuse box usually 3 or 4 of them bolted to fuse box you cant mistake them they are the largest physically in the fuse box , If this reads ok check your Battery Earth strap and Engine earth strap .sometimes the dash lights if these straps are poor but they can not carry enough power to complete circuit.
Jul 03, 2015 | Cars & Trucks
Volvo v40 airbag light staying on after problem sorted, how do i get it to switch off?
it needs to be computer reset so u will have to find someone who has one. not just dealers
Oct 01, 2012 | 2000 Volvo V40
1988 chevy S-10 Stalls out, has a late and hesitant responce when give gas runs terrible
Any check engine light? If check engine is on, you could diagnose by fault code. If not, I would try throttle position sensor.
Dec 25, 2011 | 1988 Chevrolet S-10
When i connect nokia 2690 to pc in data storage mode it is connected but when i try to connect in pc suit mode vo connect hi nahi hota hai
try to synchronise ur mobile with pc. for synchronising do this..
1.connect ur mobile to pc with data cable
2.then switch off ur mobile...
3.Now press switch ON button for some second(don't start ur mobile)
4.After tht ur mobile automatically synchronise with ur pc now start ur mobile nd try to connect.
Nov 15, 2011 | Cell Phones
I had a suzuki motorcycle,problem is the tail light lit already upon switching the ignition switch and no responce when you step on the brake.what will be the trouble?
Either the front or rear brake light switch may be stuck in the 'on' position. If it was the tail light that is on, the headlight should be on as well. Try removing the wires from each brake switch to see if that fixes the light problem. Make sure that adjustment of the switch or it's actuator is not the problem after identifying the offending switch. Otherwise, replace the switch. Hope this helps!
Feb 14, 2010 | 2006 Suzuki Forenza
Seems to be no power, not charging either.
Connect your mp3 player to your PC and then charge it for 4-5 hours properly then it will work.
Thankyou. :)
Jan 08, 2010 | Samsung YP-K3 MP3 Player
Turn iginition key no responce to starter. Bought new key with chip still n o responce.
try to start it in neutral. the trans. has a safety switch that will not allow the car to start in anything, but park and neutral. sometimes the shift lever gets a little out of line with the gear indicator. also try firmly shifting into and out of park a few times. this may flip the switch. good luck
Sep 28, 2009 | 1995 Chevrolet Lumina
Need puk code for net 10
if u want to get ur puck code for ur mobile then call to ur mobile connection service provider. they will give u puck code, its their responcibility, thnx
ahsan ali
Aug 29, 2009 | NTL VS1500 Cordless Phone
Eflite 60amp esc - no throttle responce
Lower throttle trim all the way. It will arm like a charm.
Cliff
May 23, 2009 | E-Flite 60-Amp Pro Switch-Mode BEC...
No responce from accelartor after brake peddle is pressed
If check engine light is on get the codes pulled.
Jun 04, 2017 | 1996 Audi A4
Epson LQ-2180 Dot Matrix Printer Logo
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
