Question about LG WM2487H Front Load Washer
LG WG3431HW OE Error: Rattling & Not Draining.
LG WM3431HW. The drain filter area is rattling, and it ends up stopping with an 'OE' error pre-spin. I don't see any coins or debris in the drain space. There is a hairline crack in the plastic white piece that spins. I also tried to check the drain tube but don't see any obstructions or kinks. I am currently manually draining the washer. Drain and rinse cycle has OE error as well.
Did u find the problem? I m currently having the same issue. Please let me know if you have the solution. Thanks
Posted on Apr 24, 2012
Water will not drain says oe
Posted on Aug 08, 2009
What is Oe error lg model lds5540st
The OE error or fault code to indicate that the washing machine is not draining properly. Check to be sure the drain hose isn't clogged or kinked. If that checks out, check to see if the drain pump or drain pump filter are clogged. Sometimes objects that are put into the washing machine, for example combs, money, hair pins, etc. end up in the filter. Finally, if the drain line is clear and the pump seems to be clear and functioning properly, you may need to replace the drain pump assembly.
Jul 04, 2014 | LG LDF7561ST
LG 1419LF My dishwasher stops during its cycle, it shows an error message: OE, there is 2 inches of water at the bottom of machine...Please help...
Hi
OE in your dishwasher is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. If the issue returns after cleaning then the drain pump assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 04, 2011 | LG Dishwashers
Getting a "oe" error how
See
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
Check the drain hose for blockage. and see if the water filters is clogged. Specific instructions will vary based on your specific LG model. Most LG frontloaders have an access panel on the front for the water filter.
Apr 21, 2011 | LG Washing Machines
LG WASHER STOPS BEFORE THE END OF THE CYCLE..OE IS THE ERROR MESSAGE ON THE SCEEN
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Feb 04, 2011 | Dishwashers
Stopping during rinse cycle . not spinning. OE light
The code OE is a draining error. The washer has sensed that the water has not completely drained all of the water within 10 minutes and will display this error code. The grinding noise you are describing is most likely a failed drain pump or clogged with foreign debris.
  1. Locate your drain pump access door on the front of the machine.
  2. Clean out the filter area.
If you are unable to resolve the issue by cleaning, I would recommend replacing the drain pump.
Jan 17, 2011 | LG Washing Machines
I keep getting an error OE on my LG WM0532HM front load washing machine and it won't spin out the water, just stops after a few minutes
The OE error is "Outlet Error" for the draining the water from the unit.
The unit is having trouble draining the water from the unit and that is why there is an error code.
You need to be sure there is nothing in the pump's filter (located at the bottom left on the front panel) that is restricting the water's flow.
If the pump's filter and housing is clear then it is the pump that has or is going bad.
The pump will fail because a seal will let water into the back side of the motor and case it to lock up.
If you need a part number for the drain pump, let me know.
Apr 24, 2010 | LG WM-0532HW Front Load Washer
My washing machine showing an OE error before end of cycle
OE error is noyhing but an Outlet Error.. OE simply means “the pump is blocked”. Clean and straighten the drain hose / clean the drain filter. Check the hoses (drain hose) and the pump filter but if it didn't cure the problem then turn the thing upside down and strip the pump out of it check if anything is caught in the impellor.. if so remove it and everything will be fine..
Jan 18, 2010 | LG WM-2277HW Front Load Washer
Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
May 02, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
LG Intello wm-1460FHD stops spinning during the wash load.
OE is a drain error (indicating the machine has not drained out in under 10 minutes). If the drain pump is not coming on at all then you have a bad drain pump motor. If it is trying to drain then you may have a clogged up drain hose. The most likely cause is a bad drain pump motor. Hope this helps.
Jan 11, 2009 | LG WM-1480FHD Front Load Washer
LG WM2487H Front Load Washer Logo
1,469 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
