Simpson Electronic water not stopping
This machine has overfilled and flooded the house several times in12 months.
It is working fine again now.
What could this be? Level sensor swithch. Solenoid valve. Controller.
  • 15,935 Answers
Pressure switch - it measures the weight of the water (in bars) and tells the valve to close.
Check/replace it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
My Simpson exist set 950. Why does it overfill and pour water on the floor?
it sounds like your water level clip is broken and needs replacing
Jun 01, 2015 | Simpson Washing Machines
Simpson washing machine will not fill
faulty control board or timer
Nov 19, 2017 | Washing Machines
Kenmore he4t code hf
hf error stands for hot water not being detected, make sure both hot and cold water are open and not reversed. if unit overfilled and flooded garage, the is if with you pressure switch or pressure hose. remove to lid of machine and you will find pressure switch and hose to the right side, inspect hose for any pin holes, if ok, order pressure switch
Apr 03, 2013 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
The dish washer draining pump keeps going and water dose not come on
Tmachine is probably in flood sense mode. Tip it forward onto a towel and see if water runs out from the base. If so be careful not to flood the house, but empty the base carefully and run the machine. Check that it does not overfill again if it does there may be a sensor or water valve proble. Good luck
Sep 07, 2010 | Dishwashers
The water will not spin out and the digital display display FL and beeps. What is the problem? It's in a house where it hasn't been used for a couple of years but seems to be fine.
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Jun 01, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Fl code on kenmore calypso cannot clear
this is the fl code on a whirlpool calypso which is probably the same since kenmore is just a name,, whirlpool built the machine if u didnt know kenmore doesnt build anything they just put their name on things... (FL is a flood conditon.) FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
Feb 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My simpson encore 605 beeps when you press the start button buy no water comes threw. Water is on at the tap. Same if water is on hot or cold. worked last night then stopped today. can you help
problem was caused by lever mechinism under lid ,which pushes down safety lever inside top box behind electronic control pad. when lid is closed. Adjusted to suit , now machine is working fine.
Nov 05, 2009 | Washing Machines
OVERFILLED AND FLOODED HOUSE
1 of two problems happened.
1) either the water level sensor went bad. Which tells the water inlet valve when to shut off and the machine to start operating.
2) The water inlet valve has failed. This comes from the water hose and fills the washing machine.
May 25, 2009 | General Electric WCSR2090D Top Load Washer
Dishwasher not pumping water
anti flood mechanism activated in base pan you have a leak once the anti flood is activated in puts the machine into permanent drain thats why it runs even with the door open but only runs the drain pump not the wash pump.
Mar 01, 2017 | Bosch 24 in. SGI43E05GB Built-in...
Washing Machines Logo
112 people viewed this question
Top Washing Machines Experts
