Question about Insignia Digital-to-Analog Converter for Analog TVs
No volume Our converter box has been working fine for 5 months. Now when the TV is first turned on, the letters "SAP" appear on the screen, and there is no volume.
    Scholar:
  • 66 Answers
Make sure the volume is up on the box this volume should be different from the actual tv volume and afterward make sure the tv volume is up too also go into the converter box itself and make sure it is not set to convert to any other language. it seems that maybe it might be trying to convert to spanish and not english which could cause no sound to be output at all seeing as how most channels are output in english audio.
Posted on Jun 01, 2009
Brand new, connected to new cox cable box, video works great but no sound
if just running HDMI cable try adding audio cables too, check all your volume and mute settings in the system setup.
If you have audio on most channels, but have silence on some or all of your local network channels, you may have the Secondary Audio Programming (SAP) turned ON. Complete the following steps to turn off SAP.
  1. Press the Settings or MENU button on the digital remote.
    Result: The Settings screen displays.
  2. Choose from the following options.
If... Then... Disable SAPdisplays Press the Select button. Choose SAP Languagedisplays Use the left or right arrow buttons to choose the English setting and press Select. PREFERENCESdisplays Scroll to the Language option, select Audio, then select the option labeled Primary or the one labeled English. If the above quick fix doesn't work, there may be a problem with MTS, Stereo, or another SAP issue. Try the following:
  • Verify in the program listing guide that the program has MTS, Stereo, or SAP features.
  • Check to see if the MTS, STEREO or SAP light on the TV or VCR is on.
If the light is not on, try the following:
  • Push the MTS, STEREO, or SAP button on the TV or VCR.
  • Adjust the fine tuning on the TV set to restore the stereo or SAP.
http://www.cox.com/residential/support/tv/article.cox?articleId=81da8760-5c47-11df-ed4d-000000000000
Jan 20, 2016 | Televison & Video
Control
1) tight the springs contacts batteries with pliers, for better contacts.
2) clean the contacts batteries.
3) open the remote control and clean the Keypads from oxide, dust, and special spray contacts or alcohol.
4) Reset the code again, and try it. if the problem persist, go to the repair shop TV for fix it.
God bless you
Jun 20, 2012 | Toshiba Rem48tvb Remote Control
I have a Quasar TV that has worked perfectly fine until the other day. Picture is fine, but no sound. The speaker volume is on.
Check all your channels. If you are getting sound on some channels but not others it is a good possibility that your SAP setting is turned on. Simply go into your audio menu and disable the SAP. Not sure about your model tv but some Tv sets had a switch on the back to disable the speakers and some have a setting in the menu to disable the speakers. If you have a digital cable box hooked to the tv it is possible the cable box volume is turned all the way down which will override your tv volume. Check these options and hopefully one of them works for you.
Jul 10, 2010 | Quasar SP-3235 32" TV
My wife was hitting buttons on our satellite remote and the audio no longer works. She thinks the tv is the problem. I have tried all of the Satellite volume menus and am unable to get the sound back on.
TV: check for SAP or MTS features, set them to STEREO. Also, verify that the TV Speakers are set to ON.
Cable Box: If the box has volume controls, make the volume is turned up. Also, check for the SAP or MTS feature. Again, set this to STEREO.
I hope this was helpful, best wishes.
Jun 12, 2010 | Televison & Video
No sound on some channels, other channels fine
Your SAP/MTS function is most likely turned on. This feature has 3 modes: Stereo, Mono and SAP. Stereo and Mono are easy to understand, it's the SAP that can get you. SAP stands for Second Audio Production. It is used to provide weather, information or an additional language translation of a program. Some broadcasters simply transmit the mono audio over the SAP audio channel when the are not using it for other purposes. Other broadcasters simply do not use it, which does not give you any audio. Look on your remote for a SAP or MTS button. If you do not see one, look in your TV user menu for this feature. If you are using a cable box, look in the audio menu of the cable box. You are looking for something set to SAP... just change it to STEREO. I hope this was helpful.
Mar 26, 2010 | Televison & Video
Vizio 22 inch HDTV--Loss of volume on non-HD channels only
Good evening! Go into your audio section of the Menu and make sure that SAP is off.....let me know how you did.
Apr 21, 2009 | Televison & Video
White horizontal dashed lines appear and at top of tv screen
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Mar 13, 2017 | Apex Digital GB43HD09 43" Rear Projection...
No sound on my 32'' Insignia LCD HDTV
you might try checking the sap (secondary audio programming) option in your tv if it has one make sure it is turned off. if it is off or does not have that option you will most likely have to take it to a repair shop. i would not try to fix it my self as you will do more harm than good.
Dec 09, 2008 | Insignia IS 20" TV040919 TV
Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable.  The Installation  Guide should appear.  The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
Nov 21, 2008 | Zenith DBZN-311 Remote Control
Sharp Aquos LC-42D62U VOlume Control
OK guys I'll save you. The tv is in hotel mode. To get it out from there you have to go in service menu but DO NOT CHANGE ANY OTHER THING IN THERE, only what i tell you. With the tv on and the K letter on the screen press in the same time vol- and ch- on the tv set. Now you'll be in service mode. On the remote press down arrow (not -channel) and you'll see up industry init. go there with ch- and press vol+ and enter. let the tv like that for few seconds and the tv will go green and hopefully industry init succsesfull will be on the screen. After that unplug the tv and replug it. Done!
Oct 19, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Insignia Digital-to-Analog Converter for Analog TVs Logo
170 people viewed this question
Top Insignia Audio Players & Recorders Experts
Curt Larson
Level 1 Expert
Steven Wander
Steven Wander
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
