Question about Whirlpool GEW9250 Electric Dryer
Whirlpool electric dryer model "WED5820SWO" not starting
Rotating dial to a drying cycle and press start button - hear a "click" and nothing happens. The door is closed - the dryer has power - light is on when I open the door. Dryer is only two years old - any ideas on what is wrong?
  • scotthsmith Jun 01, 2009
    Okay, how do i gain access to repair the start delay part?
  • Whirlpool Master
  • 19,396 Answers
The push to start relay is part n.39, located right behind the push to start switch.
Here is how it looks like, click on part:
Do not forget to leave feedback afterward.
Thanks.
G.
Posted on Jun 01, 2009
    President:
  • 1,734 Answers
First of all ensure these things:
Has a household fuse blown, or has a circuit breakertripped?
Electric dryers use 2 household fuses or circuit breakers. The
drum may be turning, but you may not have heat. Replace the
fuse or reset the circuit breaker. If the problem continues, call
an electrician.
■ Is the correct power supply available?
Electric dryers require 240 volt power supply. Check with a
qualified electrician.
■ Was a regular fuse used?
Use a time-delay fuse.
■ Is the dryer door firmly closed?
■ Was the Start button firmly pressed?
■ Is a cycle selected?
The dryer will not start in the Wrinkle Guard® position. Move
the dial past OFF.
If all these points can be answered with "yes" then check first if there is power to it, the water tank light comes on and the door switch is ok. The most common reason for the starting problem is the start relay, located behind the front timercontrol panel. This is more often not more than a cubed shape box made ofclear plastic with about 6 spade connectors on it, look for burn marksinside it, replace if looks damaged, do not attempt to bypass or shortout to test, as you will blow the timer or and control circuit boardand cause extensive damage. Ensure that power cables are disconnected when doing this!
If you need to replace some parts, find the parts manual here.
Turn on power, the lights come on but when you press start nothing happens just a click sound.
Click sound at power button and start button should get it going. If not then Dryer drum is not turning.
Aug 08, 2013 | Whirlpool Cabrio WED5550XW 27" Front-Load...
When I try to start a drying cycle with the dryer plugged in, I push the start button and nothing happens. Can you tell me what the problem is?
The problem is usually caused by a blown thermal fuse located on the blower housing. This thermal fuse is wire in series with the motor and when it blows open, power to the motor is cut and consequently the dryer will not start. No dryer function works when the motor cannot run. Click on the link below for the troubleshooting details of this problem.
Whirlpool and Kenmore Electric Dryers Not Starting
Aug 21, 2011 | Whirlpool Dryers
My whirlpool dryer wed9400sw2 is over a year old, but has stopped running. The last load was left damp. When I tried to restart the load, I pressed Power, Start. I hear a brief click from the start...
Hello Cdewlodge, we sincerely regret to hear this. If resetting the Dryer did not help then we would recommend scheduling service. If you would like for us to schedule service for you, please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com.
May 28, 2017 | Whirlpool GEW9250 Electric Dryer
The machine will not start. You hit the power button in comes on, but when you press the start button -- nothing happens. You can hear the clicking while pressing it - but it doesn't start drying.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 23, 2011 | General Electric GE DBVH520EJWW Electric...
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
My whirlpool duet dryer will not start. Power
You have to slam the dryer door shut. Sounds silly... but it worked. Guy said it has to do with it being stacked??
Jan 11, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer wont start when start button is pressed, but humming sound
I'd sure start by making sure the belt isn't broken. You can usually see the belt with a flashlight after accessing the panel (some are in front, others in the rear) - don't go probing around bare armed without unplugging the unit....
Jun 20, 2009 | Whirlpool LER5636P Electric Dryer
I have a 5 year old Whirlpool Electric Dryer, Model #LER7648KT2. The Dryer won't start. I have checked the door switch, start button switch and visible thermo switches or thermostats with an ohm meter...
There are usually 2 thermal fuses in dryer circuits. One is on the heater housing and will blow in an overtemp condition around 310-350F.
The other is on the blower or exhaust housing and will blow around 200F
Make absolutely sure the 2nd one is continuous and not intermittently functional. This will definitely stop the motor from functioning
Below is a diagram for an older model (LER4634). Your dryer has some additional terminals probably because it has additional drying cycle options.
The diagram may be more readable when copied and pasted into a plain text editor such as Notepad or another editor with non-proportional fonts
Switch Terminals
|TM |TM |BK |BK |BK |
|WB |OR |BU |BU |R |
|-- |-- |V |-- |-- |
|O |X |O |X |X |Auto - High Heat
|O |X |X |X |X |Auto - Low Heat
|<> |<> |~ |X |O |Cool Down / Fluff
|O |X |O |O |O |End of Cycle
|X |O |O |X |X |Timed - High Heat
|X |O |X |X |X |Timed - Low Heat
Legend:
O = Open (Infinite Resistance)
X = Closed (Continuous)
<> = Either (But not Both)
~ = Doesn't Matter
NA = Not Applicable
Switch Terminals:
TM - Timer Motor (Different Models may use different colors)
WB - Black/White
OR - Orange
BK - Black
BU - Blue
V - Violet/Purple
R - Red
Example: For the Auto - High Heat Dry cycle, the following terminals are continuous:
Terminals
<TM - OR>
<BK - BU>
<BK - R>
(of course since BK-BU is continuous and BK-R is continuous, then BU-R is also continuous.
This should allow you to test at least some of the cycles your timer switch has
I have a general schematic in PDF for whirlpool for gas and electric, but did not see an option to add an attachment to this message.
Hope this helps or point you in the right direction.
Apr 21, 2009 | Dryers
Nothing happens when I push the start button on my Gas Dryer
Three things you can check the door switch is it clicking? The thermal fuse you want to make sure there is continuity or worse case would be your motor.
Apr 02, 2009 | Whirlpool LGV4634JQ Gas Dryer
Why wont my machine start drying?
I called Whirlpool on 08706008989. The machine can only dry half a load of washing at a time. At the end of the washing cycle, the Programme dial should be at either the sun or half sun symbol. Remove half the washing, set the drying time via the drying time dial and press the 1/2 Load Dryer button - Voila dry clothes!
Oct 28, 2007 | Whirlpool AWG320 Front Load Washer / Dryer
Whirlpool GEW9250 Electric Dryer Logo
107 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
