Question about Sylvania 6432GG 32" TV
Image compresses to the middle of the screen after 20 minutes
The TV functions perfectly for the first 20 or 30 minutes it is powered on. After that, the image compresses vertically to the middle third of the screen. The image still fills the screen horizontally. It also appears that the top of the picture is folded over. Turning the TV off and on has no immediate effect, but leaving the TV off for a period of time seems to reset the issue.
Any help would be greatly appreciated.
  • 379 Answers
This TV have problem in Vertical section, probably the capacitor or cold solder. by replacing the dried capacitor and resoldering the component will help to solve the problem.
Posted on Jun 01, 2009
SOURCE:
LG 32LH30 LCD TV Problem
IMO Seriously for $119 it's not worth it.
However, it does sound like a capacitor problem
If you are "Serious" about fixing I'd find a TV repair Forum.
Else I'd go here and get a new one.
https://www.walmart.com/browse/electronics/32-inch-tvs/3944_1060825_2489948_7156390
Best Wishes.
Apr 29, 2017 | LG 32LH30 32 in. LCD HDTV
My Epson Perfection 1650 Photo scanner keeps producing scans that have a 3-4 inch bright panel vertically down the middle. The image is visible, but the outer thirds are quite darker than the middle...
Make sure all the scanning settings are correct first then set everything first before you preview image then hit scan.
make sure the size is correct drag the image on the prview screen make ths dotted lines frame your image then scan
remember you tell the machine what to do by setting it, if you dont the machine trys to do thevscan its self. Good luck, have fun
Feb 08, 2011 | Epson Perfection 1650 Photo Flatbed...
Hitachi LCD TV, Problem with the image
I am having the same problem with my 50v500 as well. Please let me know if you find a solution.
Apr 20, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Different color vertical lines on screen Sony KDF-E55A20
Go to the last page of troubleshooting in the manual and perform the system reset procedure. Basically hold the Wega "arrow up" as you manually switch the TV off. It will automatically switch back on and reset. I had only vertical colored lines on the screen, with audio but no response to any remote control functions. The rest worked perfectly.
Aug 06, 2009 | Sony KDF-E55A20 55 in. LCD Television
RCA F27442 27" TV - topper half screen stripped and bottom-half is still good
check for bad c14505 220mf.
or u14501 vertical output ic.
Nov 04, 2007 | RCA F27442 27" TV
Screen on rca tv compressed into 2 inch line in middle
The 20F530T uses the relatively newer ITC008 chassis. If the picture collapses down and only a small bright line is visible, it means that your vertical output IC has stopped working correctly. This could be due to a defective IC, cracked solder joints on the IC or the power supply that feeds it. The IC should be replaced or resoldered and/or the vertical power supply restored by an experienced tech familiar with the new line of RCA TV's.
Aug 10, 2007 | RCA 20F530T 20" TV
Picture vanished
The problem might have started because of loose conections in the vertical circuit,if the vertical circuit fails completly the screen blanks out to prevent a line being burnt in the picture tube so that part is normal but the problem is still in the vertical circuit.Maybe the IC just went bad all the way and it might have taken a fusible resistor. If you are familiar with tv service you have a place to check but if you are not too familiar be safe and call for assistance from a servicer,is a straight forward problem and it should not be expensive.Let US know how it goes or if you need more information.
Oct 30, 2006 | Philips TS2754C 27" TV
Sylvania 6432GG 32" TV Logo
141 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
