Question about Danby DPAC10031 Air Conditioner
Unit does not cool with the exhaust pipe connection covered
How can I use the Danby DPAC 10030(R) without outside hose?
    Champion:
  • 233 Answers
You need to get the exhaust air out if the structure or it will never work, you can use regular duct from a supply house as a temp fix
Posted on Jul 12, 2009
Danby dpac 10071 air conditioner is not cooling. a red light is on next to an icon with a full cup. Does anyone know how to make it cool?
That indicates that the water collection bucket is full and needs to be drained. Once the unit is turned OFF, unplugged and drained, the unit will start up and start cooling again. The drain hole is on the rear of the unit, just above floor level. You can either drain it in a shallow sided pan capable of holding 1 quart of water. Or roll it to a floor drain or outside to drain it.
Hope this helps you and thanks for choosing FixYa.
Jul 29, 2011 | Danby DPAC10061 Air Conditioner
Remove Water Tank
  • require you empty the unit by hand (usually less expensive units). These have either a removable water tank which must be emptied, or have an internal tank and a drain, where you have to empty the water into your own pan. Sometimes the drain is on the bottom of the unit, making it hard to find a pan that will fit under the unit to drain it.
  • discharge most of the water through the exhaust hose (usually more expensive units). This is called "Auto-evaporation" or "Self-evaporating" feature.
Most units are made so that they can be drained with a gravity hose that flows to a drain inside or outside your house. But the water must drain down. If the drain is higher than the unit, you may need a condensation pump to move the water upward. A few units do include a pump to send the water a short distance through the drain pipe.
do no forget to rate the solution as fixya if it helps you.
thanks.
Jul 02, 2008 | Danby DPAC10031 Air Conditioner
I connected my brand new one Danby DPAC 7099 unit, but is not cooling the room. It only goes to 1 degree less than the actual temperature of the room and stays there forever. Is there something I should...
Your question "Should I wait before starting the unit, after bringing it from the store?" may be the answer to the problem. If the unit was turned on it's side or back when you brought it home in your car? Then yes. that is the problem. When AC Units, Dehumidifiers, etc are turned on their side or back, the refrigerant gas and the lubricating oil runs out of the compressor. It should not be operated, unit it's been setting upright for 6 to 8 hours. This allows all the fluids to run back into place.
If the above is the case. Turn the unit Off and unplug it for at least 6 hours. Hopefully, all the fluids will return to where they are supposed to be.
I hope this helped you and thanks for choosing FixYa.
Jul 23, 2011 | Danby DPAC7099 Air Conditioner
We have 2 Danby air conditioners. One is a Danby Designer, Model DPAC 10060 and the other is a Danby Silhouette Model DPAC 12006. The venting hoses have broken to pieces and we need to buy new ones that...
You can purchase similar hoses at most home improvement center. Take a section of the old hose with you to get the right diameter and use the existing fittings to attach them to the unint and the window exhaust. What you may find is a better quality hose/duct, than what came with the unit. You may have to buy more than you need in length, but then you'll have some left over, if you ever have to replace it again.
Hope this helped. Good luck.
Jul 18, 2011 | Danby Heating & Cooling
I recently purchased a Danby Premiere 13000 btu portable air conditioner. I live in a condo with swing out windows. What are my options for venting (short of returning the unit for a refund or replacing...
John, unfortunately, you don't have many options, short of putting a hole in an exterior wall and putting an exhaust pipe with a cap (like a dryer vent has) and connecting the exhaust hose to it. OR if you have a clothes dryer in your condo and it's vented to the outside. You could temporarily disconnect the dryer's vent hose and connect the A/C's vent hose to the the dryer's outside vent.
Either way, it may be to much of a hassle . But, I'll let you decide that. I guess it will all depend on how hot your condo gets without A/C.
Let me know how it works out for you. Thanks.
May 05, 2011 | Danby Heating & Cooling
I want to use my danby 7599 as a heater, do I need to have the exhaust tube vented to the outside on the back?
As per instructions on page 4 of the manual I printed out from the internet (which I cannot find again) :
The exhaust/window kit must be installed AT ALL TIMES WHEN THE UNIT IS OPERATING UNDER THE AIR CONDITIONING MODE.
There should be at least 11.8" clearance between the unit and any other objects or building structure. The unit should be installed on a level surface. The window kit does not have to be installed during operation of the remaining three modes. (Heating (DPAC 7599) /Dehumidifying/Fan)
Nov 21, 2010 | Danby DPAC7599 Air Conditioner
Do we need to use both hoses?
You could draw the air from inside however the system works much more effeciently with 2 hoses.
The air that is drawn into the unit and heated then exhausted back outside. If you don't use the second hose all the air that is exhausted will have to be drawn in around windows and doors or othe voids in the area. This would draw in warm moist air that would then have to be cooled and dehumidified.
Jul 19, 2010 | Danby DPAC120061 Portable Air Conditioner
Using the DPAC 8020 AIR Conditioner (Danby)
these portable units will usually have a knob reading from low to high. set it about half way and adjust as needed. half way is usually low 70's
Aug 03, 2009 | Danby DPAC8020 Air Conditioner
Actually it's a DPAC 13009. We need to extend the 2 air pipes 4 to 5 feet each to reach upper windows over patio doors to keep doors locked and secure. Does Danby provide air pipe extensions? Thanks.
No solution possible, given that the air ducts going up over the patio doors are quite an eyesore. This building is entirely fieldstone outside, so either the patio doors or windows above them are the only way to go in or out.
We will return the unit and get instead one that can be placed in the upper window and activated by remote control. Thanks.
May 16, 2009 | Danby DPAC12031 Air Conditioner
Danby DPAC10031 Air Conditioner Logo
415 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
