Fan motor the fan on my 4 ton rheem 2006 will not turn the unit hums and sounds like its going thru the motions but the fan will not come on
  • fougzki May 11, 2010
    This could be fan capacitor is faulty, stuck, or shorted turns. Or loose connection maybe?
  • 83 Answers
Hi, the bearing on your fan must be stuck, have it checked by a technician. humming builds current in the motor and might overload.
I hope it helps
Posted on Jun 01, 2009
  • Miguel Tulipat
    Miguel Tulipat Jun 01, 2009
    I hope it helps
What is problem when fan motor on outdoor unit gets very hot and compressor will not restart?
Ur compressor depends on fan motor of ur condenser. Ur compressor undergoes Hi-pressure because ur fan not working properly
Sep 06, 2014 | Rheem Air Handler 3 Ton With RBHP Series
How do I fix my A/C
can be a bad fan motor, defective capacitor or contactor issue. capacitor is cheapest fix if bad.
May 11, 2014 | Bryant Heating & Cooling
I need exact replacement ac air handler Weather King model RCBA4882GH21...4 ton 10 kw elec heat with the I need to replace my Weather King ac air handler unit...4 ton, W shape evap coil ,elec...
What's wrong with your current AHU? Any Ruud dealer can assist you. Most 4 ton units work with r-22 or 410a. As a side note, most parts in an air handler can be replaced unless the case is rusted thru.
Sep 24, 2013 | Rheem Air Handler 4 Ton With Rhplhm Series
Hello all My Rudd AC unit will start and run find maybe for 10 minutes and cool air then the fan outside will stop and unit hums or hisses and blows hot air inside vents. I changed out Thermostat and Run...
Welcome to the world of Ruud! Ok James heres the deal. It sounds like the condenser fan motor has failed. Its not a repairable item but the motor is not too expensive. Disconnect the main power at the fuse block on the side of your house next to your a/c. Remove the screws that hold the top fan section and carefully turn the fan/panel assembly over taking care not to stress the wires. Determine how the fan is mounted (probably 4 screws) and go find your new motor. Both Rheem and Ruud use the same motor mounting. Most a/c supply houses have a motor that will fit or go to graingers. Make sure you get a matching run capacitor for that motor. It will have separate wires and not share any wiring with the old capacitor. The old capacitor will have to stay in place since it is also connected to the compressor. The old motor will have 3 wires and the new one 4 (2 brown for the capacitor and 2 others to put on the contactor that the compressor wires go to). If its a heat pump it could be a board and youll need help. good luck
Aug 15, 2013 | Ruud UBHC Air Conditioner
Rheem outside unit humming, fan not spinning
there is a dual cap in unit. kill the power and remove the silver cylinder. on top it has 3 places it can put wires. F, H, C. write the colors of wires and where they belong. take part up to granger and buy. 30 bucks most. replace. if same problem do the same with fan motor, around 60.
Jun 18, 2013 | Heating & Cooling
Rheem classic 80 fan motor on furnace hums will not turn on
Have you checked the capacitor? Try spinning the blower wheel by hand, if this gets the motor going you have a bad capacitor. If not, the motor will need to be replaced.
Nov 16, 2012 | Rheem Prestige 14 Series 2.0 ton 14 SEER...
What is a reasonable price for a fan motor to be installed in a air conditioner 3.5 ton unit
I am retired now but a few years ago I sold the motors:
MOTOR SPECIALS Blower motors
1/4 HP 220v____82.17____63984
1/3 HP 220v____84.02____63986
1/2 HP 220v____103.00____63988
1/4 HP 115v____80.00____63983
1/3 HP 115v____82.17____63985
1/2 HP 115v____100.82____63987
Condenser motors
1/6 HP 220v enclosed____75.22____FSE1016SVI
1/4 HP 220v enclosed____75.15____FSE1026SVI
1/3 HP 220v enclosed____82.17____FSE1036SVI
1/2 HP 220v enclosed____100.82____FE1056SB
Specialty motors
ORM5458 Rheem multi amp___81.50
____98____125.67
___463___104.90
___510___41.85
___509___43.90___
EM550___22.00__
Brackets
A60055__18.95
KIT 200__14.07
A67804K_15.85
TFM-55__18.95
A67805K_13.27
A60007K_12.90
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 20, 2010 | Heating & Cooling
A/C fan will not start when therm clicks on, also a Rheem Model
What make & model is it? How hard to get at the fan that's humming? Sounds like capacitor to fan is shot.
Aug 03, 2009 | Heating & Cooling
Ruud achiever 10 seer air conditioner
It sounds like your condenser fan motor may be locked up or the capacitor that helps give the condenser fan motor a kick to get it started may be defective. Try turning your system on and using a long screwdriver try to push the fan blade on the condenser fan motor to see if it will run normally if you give it the starting boost it needs.If it does run at full speed and doesn't over heat or start and then slow down then you probably only need to replace a simple 10-12$ capacitor. If it barely turns, makes an odd humming sound or overheats etc. then you will have to replace the condenser fan motor. This is assuming that the outdoor condenser has the 220v supplied and the 24v supplied to the compressor relay, that the compressor relay is engaged and suppling 220v to the condenser fan motor.
May 28, 2008 | Ruud Matching Split Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
