Question about Orion XTR Pro 2400 Car Audio Amplifier
Wiring diagram I like to hook up a orion xtr pro 2400 amp in a 2006 ford f-250
  • 655 Answers
Hello rivertoyz,
If your F250 has the stock radio, there are no preamp outputs, so you will need to use the speaker outputs. The best solution would be to wire a LOC (line output converter) to the rear channels and run RCA cables to the amp.
Speaker wire color code:
Left rear positive - Gray/Light Blue
Left rear negative - Tan/Yellow
Right rear positive - Orange/Red
Right rear negative - Brown/Pink
You'll need an amp wiring kit with 4gauge power and ground. Both the LOC and wiring kits are available at numerous online stores. The best service is from www.crutchfield.com. Another reputable online seller is www.sonicelectronix.com.
You did not say what subwoofer(s) you intend to use with the amp. If you want to stick with the Maxxsonics product, a pair of 10" Orion HP10D2's would be an excellent match. Wire each of the subs dual voice coils in series for 4ohms, then parallel them to the amp for a final load of 2ohms. Both of the linked retailers above sell the Orion's and many other brands as well. Just make sure that your sub selection has adequate power handling capability. At least 1000 watts RMS if you use a single sub and 500 watts RMS if you go with 2.
Hope this helps.
Posted on Jun 02, 2009
How to bridge a Orion 250 hcca amp?
Should have a diagram on the bottom of amp or where you hook up the speakers to amp......Its usually the two outside speaker connections.....just be sure to hookup negative to negative and positive to positive.let me know if this helps.........
Mar 25, 2012 | Orion Car Audio & Video
My amp works when the volume is low, but if i go higher it turns off and then it power up again but i can't go higher, what will be the problem
Your Output devices are most likely going faulty. When that happens your protection mechanism is cutting in. OR it could be a speaker problem, You manual to troubleshoot is below. www.teamcsw.com/manuals/orixtrpro1000_2400.pdf
May 21, 2010 | Orion XTR Pro 2400 Car Audio Amplifier
Will not power up
Hard question to answer because of the lack of information, but my first guess would be the remote turn on wire and my second and third gueses would be a resistors or a blown fuse.
Oct 17, 2009 | Orion XTR Pro 2400 Car Audio Amplifier
Orion hcca 250 digital reference & orion XTR 12" 500w dual subs
If you have one sub dual voice coil, just paralel the sub and conect to brigde amp. Simple...
Mar 02, 2009 | Orion HCCA-D5000 Car Audio Amplifier
if its hot its drawing to much current sound as if you have something improperly hooked up..if i could see your wiring i could help u out better steve
Feb 27, 2009 | Orion HCCA-D5000 Car Audio Amplifier
How to wire 2 dvc subs to a orion 2150sx ? dont know the wire colors or how to hook um to my amp.
what impedence are the voicecoils?
Dual 4 - Dual 2 - Dual 1 ??
Orion SX / GS / HCCA amp Wiring guide:
Orange = Right Positive
Black/ Orange = Right Negative
Yellow = Left Positive
Black/ Yellow = Left Negative
Blue = 1+1
Bridging of SX or HCCA Amps:
1. Use the Orange wire for Positive.
2 Use the Black/ Yellow wire for Negative
3. Push "in" the Mono Button
That amplifier is only 4ohm mono stable - so assuming the subs are dual 4 ohm voicecoils...
First wire both in Parallel Independently So each subwoofer is now a 2 ohm load. (combine + and + - and- on both subwoofers)
Now Take a positive on one voicecoil of sub #1 and attach to amplifier+(orange)
Take a - on that same subwoofer and attach it to a + on the OTHER subwoofer.
Finally, take a - from the second woofer to the amplifier -(black/yellow)
Now you have a 4 ohm load on your bridged channels.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 23, 2009 | JBL 1200GTi Car Speaker
Orion 2400 mono
My esp light is blinking yellowish and the amp isn't putting out. I have power to it, just not putting power to my subs. anyone know how to help?
Feb 25, 2008 | Orion XTR Pro 2400 Car Audio Amplifier
Orion XTR PRO 2400 power on... no sound
it could be that it burned the stereo inputs or outputs
Sep 24, 2007 | Orion 1200D Car Audio Amplifier
Car Audio & Video Logo
355 people viewed this question
Top Orion Car Audio & Video Experts
Tygh Duval
Tygh Duval
Steve Sweetleaf
Steve Sweetleaf
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
