Question about Fimco Spot Sprayer, 25 Gallon, 3.8 GPM, 45 PSI, 12 Volt
Pump surging and not priming itself
As soon as the pump hits 45 psi it turns off and on causing irregular spray patterns; and pump does not prime itself. Check strainer everything good, hooked garden hose directly to suction side and still same result
Fimco Pump 3.8 gpm 45 psi
Model # 5275017
    Problem Solver:
  • 6 Answers
Old pump. they've been updated!
Posted on Aug 21, 2009
5 Suggested Answers
  • 63 Answers
SOURCE: LAWN SPRAYER PUMP WILL NOT SUCTION
Check the screen in the tank, it very well may be clogged.
Posted on May 03, 2009
  • 6 Answers
SOURCE: I have a Fimco 2.1 gpm pump that worked fine last
clean the checkvalve in the pump with dish soap, and a toothbrush. scrub thoroughly and rinse off. replace and see if that works!
SOURCE: I also have a FIMCO 15 gallon 12 v spot sprayer, won't prime
I use an emulsifier with Round-up to make it stick better to the weeds (Sticky Spreader). The emulsifier had made the solution less viscous and was not moving through the wire mesh filter that comes out of the bottom of the tank. I removed the filter and it works fine. I have a filter in the handle anyway so there is no need for two filters for my application.
Posted on Jun 06, 2009
SOURCE: Insufficient Pressure From Pump
Take the strainer at the end of the hose on the tank off. Throughly clean it. I used an old tooth brush, then ran hot water through it several times. Also drained the tank and flushed it out 3-4 times with fresh water, then ran fresh water through the pump for several minutes
Hope this helps
Posted on Aug 09, 2009
Pumping psi into gastank not priming carb
Fuel filter may be plugged. Pumping up a fuel tank will cause damage to the fuel pump diaphragm , the gas tank itself. Priming the carb is done by pouring gasoline in the vent hole of the float chamber.
Aug 28, 2016 | Cars & Trucks
How do i prime the pump on the soaper or chemical dispenser on my troy built 2550 psi pressure washer?
There is no need to prime. But you do need to use the black spray nozzle to get soap to siphon out.
if that doesn't solve the problem let me know
Oct 26, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
How do i prime my troy built 2550 psi pump for the soap?
You have to use a low pressure nozzle ( usually black with very large spray opening) With the low pressure nozzle siphons your detergent in with the spray water . If you are using a high pressure nozzle the soap will not prime.
Oct 26, 2014 | Garden
My titan 330 airless paint spray will not shut off while primming
Airless paint sprayers should not turn off while in prime mode. As long as the prime valve is open the motor can pump paint but the system will not build any pressure. Once the prime valve is closed the pump should pump paint into the hose until it gets to the pressure level required to turn the motor off. If the pump does not turn off with the prime valve closed, it could be that the spring in the valve is weak and won't hold the valve closed under pressure. If the hose is up to pressure and the motor just keeps trying to pump paint, you may have a bad pressure sensor or it is disconnected from the circuit board.
Jul 10, 2012 | Air Tools & Compressors
Wagner 404 Plus Airless motor stops.
All airless sprayers are on-demand pumps. The two settings are prime and spray. When it is set to prime, the pump will draw liquid from the bucket below and pump it out the side tube and will never stop until you switch it back to spray. When set to spray, the pump will run until the pre-set pressure is reached, then stop. As soon as you start spraying, the pump will run until a few seconds after you stop spraying. Tip size and pressure setting will affect how long after you stop spraying the pump will run. A large tip and high pressure will cause the pump to run longer after you stop spraying.
Sep 02, 2017 | Wagner Air Tools & Compressors
Im working on a 95 s10 blazer.It has the 4.3 engine.It will only start if it is sprayed with starting fluid.the fuel pump,fuel filter,and pressure regulator have all been replaced.Seems like the system...
It sounds like the fuel pump is not working. Perhaps the install was not completed correctly. Things to check, fuel pump relay, wiring, voltage to the pump.
The priming happens as soon as you put the key in and turn it to "acc" (you may hear a humming sound). Then once you turn it to "start" the injectors and spark plugs start firing.
Another possibility is that the fuel filter was installed backwards.
Apr 22, 2010 | 1995 Chevrolet S-10 CA Edition
How do I prime fuel system on my 1998 gmc jimmy
Turn the key on for 5 sec. Turn the key off for 20 sec. Repeat 3 times
Aug 09, 2009 | 1998 GMC Jimmy
I have a Guundfos CHIE 4 circulation pump that is constantly running. I closed the valve on the pressure side but is still runs. On a previous post I was told it "may have lost its prime". The pump is...
You have a defective pressure switch.But replacing the switch. Do the following; Open the pressure switch cover, and find the two adjusting nuts. One is for the cut-off pressure (40psi) and the other is for the cut-in pressure (20 psi). Adjust the the nut with a longer stem counter clockwise (loose) with the pump running. Take care not to touch the power line attach
to it. Continue the adjustment until the pump stops,
at 40 psi. Then, observe - Pump must stop once the
pressure is attained. Then, open the valve until it
start (20psi).. Then you can adjust the other nut to
cut in at 20 psi.
To prime the pump; open and fill the priming port full
with water.and replace the priming port plug. Set
the water flow control valve at full close position.
Switch the power on to run the pump and slowly
open the control valve to appropriate setting such
that the pump doesn't lost the suction. Send your e-
mail for further comment. God bless u
Aug 07, 2009 | Grundfos JPS4 1 HP Pressure Booster Pump
HMSK80 Carb Queston
if it has a prime bulb on it the rubber may have deteriorated and is failing to prime?Just my first "guess" hope it helps (replacement bulbs can be found easily)
Jan 19, 2009 | Karcher 2500 PSI Pressure Washer
Fimco Spot Sprayer, 25 Gallon, 3.8 GPM, 45 PSI, 12 Volt Logo
1,195 people viewed this question
Top Fimco Garden Experts
lnbn1975
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Are you a Fimco Garden Expert? Answer questions, earn points and help others
