Question about Adobe Acrobat Professional 7.0 for PC
I want to OCR my PDF's but the error message displayed is saying that the documents contain renderable files. What does this mean.
  • 233 Answers
Re: Adobe Acrobat Professional 7.0
Try printing then scanning the PDF.
(Or spend the money to install Adobe Acrobat -- and I do not mean just the READER program)
I have no clue about your "error message displayed is saying that the documents contain renderable files."
Posted on Oct 23, 2007
0 characters
3 Points
When I attempt to convert a word document into an PDF file I get a message "missing PDF maker files" I'm given the option to say yes or no to "do you want to run the installer in repari...
From the info you provided, seems like your Adobe Acrobat Professional wasn't installed properly or there are some missing files.
If you have the installation file, try installing the software again.
(When you click on Yes, nothing happens because adobe cannot find the Installation/setup file on your laptop.)
If you do not have the Adobe installation files, as an alternative download CutePDF writer. Its free and hardly takes any space on your pc/laptop (<4MB)
Direct Download Link for CutePDF
Once downloaded, install the software and follow the steps below:
1. Open the Word file you want to convert to pdf
2. try to print it
3. before printing, the time when u have to select your printer, select Cute PDF Writer as shown in the image below
4. Click on print
5. The Word document will be printed as a PDF file and you'll be asked where you want to save it :)
6. Choose your destination.
7. When the printing is completed, you can open the pdf file in Adobe PDF reader
* You don't need a printer to do this
* You can follow the same steps and print excel/powerpoint files to pdf (or any other file type that you can "print")
Hope this helped!
Mar 31, 2011 | Adobe Acrobat 7.0 Professional
I installed adobe 6 professional a few days ago on win 7 computer. but the printer drivers were not installed. i am not able to create pdf documents. also, when i try to download any pdf file from a web...
I am not 100% certain but I am not sure you can use that old a Adobe version with Win 7. The current Adobe Pro for creating .pdf files is now version 9 for Win 7. That may be part of your problem. Consult the Adobe website and see if that older version will even run in Win 7
Dec 04, 2010 | Adobe Acrobat 6.0 Professional for PC
What is acrobat reader?
Adobe Acrobat is a family of computer programs developed by Adobe Systems, designed to view, create, manipulate and manage files in Adobe's
Plug-in from Adobe. It reads documents in PDF format on any platform.
A program from Adobe that lets you capture a document and then view it in its original format and appearance
Adobe has changed the names of the products in the Acrobat family regularly, also splitting-up, joining, or discontinuing products. Between version 3 and 5, Standard and Professional versions were one product simply called Adobe Acrobat.
As of October 2009[update], the current main members of the Adobe Acrobat family are:
64px-adobe_reader.svg.png magnify-clip.pngAdobe Reader 8/9 Icon
  • Adobe Reader 9 (Windows, Mac and Unix)
  • Adobe Acrobat 9 (Windows & Mac only; no Unix version)
    • Adobe Acrobat 9 Standard
    • Adobe Acrobat 9 Pro
    • Adobe Acrobat 9 Pro Extended (includes Adobe Presenter)
The latest version
Version 9.0 Adobe Acrobat 9.0 was released July 2008:[10][11]
  • PDF version 1.7 (and prior) supported. There are Adobe extensions to PDF 1.7 for Acrobat 9.
  • Product Family includes: Acrobat Standard 9 (Windows only), Acrobat Pro 9, Acrobat Pro Extended 9 (Windows only).
  • Pro Extended Version includes Adobe Presenter and the features of Acrobat 3D.
  • The ability to create Acroforms was restored to Acrobat Standard in this release (in versions 6 through 8, Acrobat Professional was required).
  • Enable real-time collaboration of PDFs with synchronized document views and chat.
  • Improved Web Capture for capturing entire web pages or just some parts into PDF.
  • Integration with to enable storage and sharing of PDF files.
  • Personalize a PDF Portfolio with customizable templates for navigation and branding.
  • Compare and highlight the differences between two versions of a PDF document.
  • Insert FLV (Flash) or H.264 video for direct playback in Adobe Acrobat and Adobe Reader.
  • Convert a variety of video formats to FLV for playback in PDF.
  • Create PDF maps by importing geospatial files that retain metadata and coordinates.
  • OCR PDFs (Paper Capture) using ClearScan. Adobe ClearScan technology creates custom Type1-CID fonts to match the visual appearance of a scanned document after optical character recognition (OCR). ClearScan does not replace the fonts with your system fonts or substitute them by Type1-MM (as in Acrobat 8 and earlier versions), but uses these newly created custom fonts. The custom fonts are embedded in the PDF file (this is obviously mandatory). If the OCR does not recognize a word with enough confidence, then the image (bitmap) of the word is shown in the PDF and the text is put above but hidden (same as what is made in "Searchable Image" mode).
  • Adobe Reader 9 drops support for Adobe Reader Extensions 5 and 6 which permit Adobe Reader client software to save changes to filled-in forms in PDFs. Adobe Reader Extensions 6.1 and newer are still supported. Legacy PDFs will still be viewable, however they will open with the warning "This document enables Reader capabilities that are no longer enabled in this Reader version."[12]
  • On March 10, 2009, Adobe Reader 9.1 was released which addresses a number of customer workflow issues and a critical security vulnerability while providing more stability.[13]
  • On May 12, 2009, Adobe Reader 9.1.1 was released which addresses two critical security vulnerabilities.[14]
  • On June 9, 2009, update version 9.1.2 was released which addresses a number of critical security vulnerabilities.[15]
  • On July 31, 2009, update version 9.1.3 was released which addresses a number of critical security vulnerabilities.[16]
  • On October 14, 2009, Adobe Acrobat 9.2 was released (added support for Windows 7 x86/x64 and fixed many security issues).[17]
  • On January 12, 2010, Adobe Reader 9.3 was released which addresses a number of critical security vulnerabilities.[18]
  • On February 16, 2010, Adobe Acrobat 9.3.1 was released which addresses two critical security vulnerabilities.[19]
  • On April 13, 2010, Adobe Acrobat 9.3.2 was released which addresses several critical security vulnerabilities.[20]
Jun 03, 2010 | Adobe Graphics Publishing, Design &...
I replaced a older pdf with newer one sent by client .when tested in live site then it gives error message Acrobat may not display the page correctly .Please contact the person who created the PDF document...
all over the world the compatibility issue works higher up and not loswer down...i.e.
if you have created a doc in MS Word 2003 then you can open it in Word2007 and not the other way...
in the similar way a PDF doc created in Adobe Acrobat 7 cannot be viewed in the lower version
Dec 10, 2009 | Adobe Acrobat 7.0 Professional
The Japanese Language Support Package is required
The PDF document contains data in Japanese and needs the support package to display the correct Japanese characters. This is common with files on websites of Japanese companies even thought the document may contain English language also. You can simply cancel and then view the document English text but the Japanese text will not be displayed and you will see various garbage and blank spaces instead. Alternatively, you could simply install the support package. This will then enable Acrobat reader to correctly display Japanese characters. Note: you can also get a similar message if you access a document in Chinese which will then prompt you to install the Chinese support package!
Jul 30, 2009 | Adobe Acrobat 7.0 Professional
Not able to resign a pdf file when making revision (changing a date). Keep getting error message of: CSigDict.cpp Line 1663
If the file is opened in Acrobat Reader you can not do editing. You have to use Acrobat Writer to do this.
If you do not have Acrobat Writer, you have to download a free PDF Creator.
If you are using a PDF writer to convert a word document to PDF format, save both files, that is- the Word document (or Excel worksheet) and the PDF file. This way, if you need to edit, you can go back to the original document and edit.
Hope this will help.
Apr 27, 2009 | Adobe Acrobat 6.0 Professional for PC
Adobe reader error message
In Internet Explorer, when you click on a link to a pdf file,
you get the error message “Adobe Reader could not open ‘filename.fdf’ because it is either not a supported file type or because the file has been corrupted.”
This error is due to an issue with Adobe Acrobat viewing PDF files in a web browser.
Try the following:
1. Open Internet Explorer, go to Tools -> Internet Options and on the General tab to erase all temporary files, cookies and history data.
2. Under Internet Explorer -> Tools -> Internet Options, on the General tab click on Settings and make sure you select the option “Automatically” for checking for newer versions of the stored pages. Then attempt to open the PDC file again.
3. If solutions 1 and 2 do not work then uninstall Adobe Acrobat, then reinstall it again.
It seems that Acrobat 6 is more prone to this error so upgrading to Acrobat 7 may solve the problem.
All d best.
Any furthur help feel free to ask me again i will be more than happy to assist you.
Dec 22, 2008 | Adobe Acrobat 7.0 for PC
Adobe acrobat v7 can't open file
Do this:
1. Exit Acrobat.
2. Choose Start > Run, and type: %APPDATA%\Adobe\Acrobat\ into the Open text box. Click OK.
3. Right-click either the 6.0 or 7.0 folder, and choose Delete.
4. Start Acrobat and attempt to print.
Note:Acrobat preference files contain application settings such as toolbar arrangements. When you restart Acrobat, new preferences are created automatically based on application defaults. Deleting preference files will not result in the loss of saved documents.
Or, if u have having Quarkexpress in your machine update the version. Quarkexpress also creates PDF files, maybe this is where it was created from
Mar 14, 2008 | Adobe Acrobat 7.0 for PC
Getting a message about and error on page.
Dear Wendy,
This can happen because of multiple reason:
a) It isn't your fault. The file publisher has not correctly made pdf or its corrupt and won't work on your system because all pdf files can be opened in almost all versions.
b)You might like to check your adobe 8.1 settings for complete installation. Have you correctly installed the program. Also check if you are able to other pdf files on your system or not.
c) you can also try an older version of acrobat, which i doubt should affect the problem.
Finally check the file extensions and password protection problems.
If that was helpful please press solved.
Nov 14, 2007 | Adobe Acrobat 6.0 Professional for PC
TOC Page Numbers Don't Display in PDFed Document
Apparently Adobe doesn't consider importing pagination data from Word documents to be important enough to code Acrobat to find Microsoft's record of the page numbers and import them properly. I would suggest using Adobe Acrobat 7's page numbering feature, and simply number your pages appropriately, to match your table of contents.
Nov 13, 2007 | Adobe Acrobat Professional 7.0 for PC
Adobe Acrobat Professional 7.0 for PC Logo
171 people viewed this question
Top Adobe Graphics Publishing, Design & Multimedia Software Experts
Laxman Bisht
Laxman Bisht
Are you an Adobe Graphics Publishing, Design and Multimedia Software Expert? Answer questions, earn points and help others
