Question about Galaxy Radios DX-2517 CB Radio
Galaxy 2517 I have a Galaxy 2517, i have had for 8 years. You can be listerning to it and , all of a sudden it will cut way down. I can turn the knob from AM,USB,LSB and the audio will come back up. Any ideals ? thanks......
    Scholar:
  • 66 Answers
I have the same radio. But I never had this problem with the Galaxy, only with my Midland. Sometimes like Jim said the switches get dirty and must be cleaned. My problem was that the receive gain knob was moving on its own on my midland, something called auto adjust, but the Galaxy has a similar function built in the radio's PC board that allows more clearer listening and transmit. You cannot remove this component because it is in the PC board itself, however you can isolate it or you can have it calibrated by a licensed professional.
Hope this helps!
-Gavin
Posted on Jul 01, 2008
  • 2,130 Answers
Sounds like to me that one or more of the switches are dirty. Open the unit with the power disconnected and purchase a spray can of electrical contact cleaner. Spray all of the switches and volume controls on the inside. Rotate all of the controls several times, back and forth to work the contact cleaner into the controls. Repeat as necessary. Over time, these switches get dirty and they don't make a good connection. The cleaner will restore continuity to the switches.
Good Luck,
- Jim
Posted on Jan 28, 2008
How to set band
turn the band selection knob to channel " D " thats the CB channel.
Mar 20, 2016 | Galaxy Radios DX-2517 CB Radio
How to install echo board in a Galaxy 2517
  • This radio already has an echo board installed in it from the factory. On the bottom set of knobs, left side, over three knobs. That knob is your echo/delay knob. No need to install one. Just turn it on.
  • Hope this helps.
Nov 03, 2011 | Galaxy Radios DX-2517 CB Radio
Install Echo Board in Galaxy 2517
  • Hope this helps..
I HAVE A GALAXY 2517 BASE IT WILL KEY UP BUT IT WONT MODULATE IT RECIEVES FINE
could be a couple transistors or caps near center board. you may check your mic out or mic gain knob.
Jun 04, 2011 | Radio Communications
Galaxy dx 2517 frequency drifts sometimes on recieve and sometimes while talkng freq will go both ways up and down
The mixer crystal is unstable. It may need replacing. Some times you can reset them. Take a soldering iron and heat up the mixer crystal up for about 5-7 seconds. See if this stabilizes it. If the radio still drifts,then you need to replace the mixer crystal.
Nov 23, 2010 | Galaxy Radios DX-2517 CB Radio
Watts to high ,how do i turn the output downin my galaxy 2517
First I would check to see that no one has turned up the power supply voltage over 13.8 volts this is sometimes done and called volting it is a very poor practice and results in damaging the radio. If this has not been done then seek professional help there is a calibration power out put adjustment.
May 12, 2010 | Galaxy Radios DX-99V 40-Channels Base CB...
My galaxy 2517 (NO TX)
if you have another radio put it right next to the 2547. turn on the monitor radio with no antenna on the same channel and key the 2547. if you can hear it the final transistor is bad. let me know if that worked
Jul 18, 2009 | Galaxy Radios DX-2517 CB Radio
I HAVE A 2517 GALAXY RADIO IT IS MUFFELD ON TRANSMIT
What is the power output on a watt meter telling you? if it is up above an 8 watt dead key with the rf power turned all the way down, someone has turned up the radio inside and you will ned to turn it back inside to get about a 2 or 3 watt dead key with the rf power turned all the way down on the outside knob on the face of the radio. to do this, you will need to locate the VR18 pot for low power on am/fm and the VR14 pot for high power on am/fm and adjust accordingly, you are most likely overdriving the radio in some way and if you are not familiar doing this sort of thing, then my suggestion would be for you to take it to your nearest electronics repair tech and have them do it for you. It is not a costly procedure and you will be better off to have an experienced tech in there. Also if you are running a power mic on it, try turning it down some or going back to the stock mic to see if the problem persists. If it does while running the stock mic, then most likely it's internal issues like the one explained above.
Dec 10, 2008 | Galaxy Radios DX-2517 CB Radio
Not a Galaxy DX-2517
its a mexican kraco clone,lol
Aug 09, 2008 | Galaxy Radios DX-2517 CB Radio
Radio Communications Logo
145 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
