Question about AO Smith 1 1/2 HP 115/230V 56C Replacement Motor
Irrigation sprinkler pump, flotec, 230VAC wiring
I have an A O Smith 1 HP pool pump motor. I have disconnected it from the pump (Jacuzzi Magnum pump) and am trying to put it back on but I did not tag the wiring. What I need to know is which wire goes where. There are three wires, 1 each, green, red and black (the shortest) On the motor is L1 and L2 connections and then above them there is another screw where a wire goes. Any idea what goes where? BTW, this site forces you to type in an exact brand, model but the site does not contain the one I have so I picked the closest one. flowtec 2hp irrigation sprinkler pump, 230vac, I am running 230vac to the switch and out to pump. Pump MFG shows green on case as ground and two other terminals for what? Where do I put the white wire? Hope someone can helpout. Thank you, Jim - Boise, ID
  • 142 Answers
Green to srcew on the motor. this is ground.,
Black on T1
Red on T2
If the rotation is going the wrong way, simply switch the black to T2
Red to T1.
Check this before you couple it to the pump..
Posted on Jun 03, 2009
Leaky Motor
This sounds like it could be the shaft seals, which is a cheap fix.
The Jacuzzi Magnum calls for seal 35-423-1021
You might consider replacing the seal plate O-Ring as well. - 35-105-1120
Aug 06, 2012 | Jacuzzi Pool & Spa
Motor won't turn on
CHECK POWER AT THE PUMP, MOTOR BUZZES ? YES CHECK TO SEE IF ROTOR TURNS, YES CLEAN START SWITCH, HAVE CAPACITORS CHECKED , NO ROTOR DOESN'T TURN MOTOR WILL NEED TO BE SERVICED. ROTOR MAY HAVE RUSTED TO STATOR OR LOCKED UP BEARING .. JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FL
May 15, 2012 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
I need a motor end cover, where can I get one? Thank you!
Jacuzzi (Carvin) Magnum, Force & Plus pump parts are hard to find.
Here is a link to our site which has a parts explosion/diagram for those pumps.
Jacuzzi Magnum, Magnum Plus, and Magnum Force Pumps
Jun 08, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP 2 HP...
Motor removal on a Jacuzzi magnum force pump.
The impeller is threaded onto the end of the motor shaft and the housing (pump body) is attached to the motor with the same bolts that hold the rear cover on the motor they run all the way through on most pumps.
May 27, 2010 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
Motor runs for 10 seconds and shuts off
I believe it is your starting capacitor, It is a long round thing usually black that has two wires, this is what makes it kick on. just us rubber handled pliars when disconnecting the other one. because it holds electricity. You can get one at a hardware or pool supply, usually 10.00 or so...I hope this helps
Donna
Apr 29, 2010 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
My jacuzzi magnum pump has a small crack in the 'skimmer box' section - not actual motor part. Is this fixable?
clean thoroughly and lightly sand to roughen surface and use two part epoxy with fiberglass mess, can find both at auto parts store
Jul 13, 2009 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
Pool pump motor wiring issue
IF THE SCREW ABOVE IS IN THE METAL MOTOR HOUSING IT IS MOST LIKELY THE GROUND. GREEN WIRES ARE ASSOCIATED WITH GROUND IN ALL ELECTRICAL APPLICATIONS. YOU SHOULD BE SAFE IN HOOKING THE GREEN TO THE SCREW. HOPE THIS HELPS, JODY
Apr 11, 2009 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
AO Smith 1 1/2 HP 115/230V 56C Replacement Motor Logo
1,431 people viewed this question
Top AO Smith Plumbing Experts
David Baisa
Lawrence Oravetz
Gil Shultz
Are you an AO Smith Plumbing Expert? Answer questions, earn points and help others
