Question about Earthquake Sound XTREME 900W.5 Car Audio Amplifier
Wiring problem NEED CAR HARNESS WIRING DIAGRAMS I AM HOOKING UP IN MY MAZDA 626. I AM HOOKING UP A SOUND Xtreme st-904 in it. thanks
  • 51 Answers
If you have an aftermarket stereo, the hook up is fairly simple. On your amp there should be a minimum of 5 terminals and an audio input. one is for remote which is connected to the blue wire on your stereo. Second is your ground which is your negative connection. it should be connected to the body of the car close to the frame. Third is your hotwire which is the positive lead, it should go straight to your battery. The fourth and fifth are speaker wires, you may have 2 or more of these that have + and - signs above or below them. When wiring the speakers make sure to match the positive and negative connections on the speakers. If your rewiring all of the door speakers to your new amp then the colors that you see once you have them out are the colors you route to the appropriate locations on your amp. If this is for a sub then you just the connect th positive terminal on the sub which is red to the + on the amp and the black terminal on the sub the the - location on the amp.
Lastley there should be an audio input that runs from your stereo to your amplifier. This wire should be ran as far away from the positive wire as possible to avoid engine noise coming through your speakers.
Posted on Jun 01, 2009
Where is the location of the backup light switch on a 1991 Mazda 626 w/manual transmission?
the switch is on the outside of the case of the transmission, here is a picture of it, has a long wiring harness with four wires.
Jan 23, 2010 | 1991 Mazda 626
I need help on hooking up a JVC cd player in my 1997 mazda protege. Mostly just figuring out the wiring of the car.
well you should buy your cars wiring harness,then you can hook up the wires from it to your deck,get everything ready and then just pull factory deck and plug it in,unless some **** has chopped all the wires in your car then you will need a tester light
Jan 07, 2010 | Car Audio & Video
Engine swap. color codes are different need wiring diagram
I've done several of these swaps that sound good at the time but end up being a Huge problem.I would start with the correct harness for the engine you've put in.It must include the under hood harness and what ever harness connects to it thru the firewall to the computer.You'll also need everything connected to the transmission to the computer including any thing connected with the brake and accelerator pedals.Next get the wiring diagrams from Jeep or buy the Chilton or Haynes manual,they have the diagrams included.Get the harnesses connected to the engine,trans and computer,then work backward towards hooking up everything else.I really feel your pain,I've put 20 year newer engines in older cars,V-8's where 6's were,an olds V-8 where a in-line six was(ford),Late model v-8 in a 59' Chevy.All these were simple compared to what your going thru.Please contact me if I can be of any help?
Sep 28, 2009 | 1991 Jeep Cherokee Limited
HOW TO CONNECT PIONEER DEH-P4700MP TO 91 MAZDA 626
Hello pleazallnite,
Here's a link to the wiring color code for the Mazda 626. This link is to downlaod a copy of the DEH-P4700MP owners manual. The wiring diagram is on page 50. You can simply connect the wires by function to the vehicle wiring. But a better solution to avoid cutting or tapping into the vehicle wiring is to purchase an aftermarket wiring harness. The Metra part number 70-7901 appears to be the correct harness for your vehicle and is available from Crutchfield for $12.99.
Hope this helps.
Jun 14, 2009 | Pioneer DEH-P4700MP CD Player
Installing after market stereo
Dave,
You will need to go buy a wiring harness adapter from your local Walmart (usually cheapest there) or Local Electronics place (ie Best Buy). The wire harness that goes out from the radio goes into the Adapter and the adapter plugs into the car harnesses. Also these Adapters come with the wiring diagrams for your vehicle. They typically run 10 - 15 bucks depending on where you get them. Thanks for using FixYa!
Sincerely,
JC
Nov 21, 2008 | 2000 Pontiac Grand Prix
Need to know factory wiring colors to hook up aftermarket stereo
1990 Mazda 626 Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/White
Car Radio Ground Wire: N/A
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Blue
Left Front Speaker Negative Wire (-): Blue/White
Right Front Speaker Positive Wire (+): Blue/Red
Right Front Speaker Negative Wire (-): Blue/Yellow
Car Audio Rear Speakers Size: 6 1/2′
Car Audio Rear Speakers Location: Side Shelves
Left Rear Speaker Positive Wire (+): Blue/Red
Left Rear Speaker Negative Wire (-): Blue/Green
Right Rear Speaker Positive Wire (+): Blue/White
Right Rear Speaker Negative Wire (-): Blue/Green
Aug 03, 2008 | 1990 Mazda 626
Need wiring harness for 1993 626 with 2.0/5 speed manual
If i were you i would advising with a dealer or mechanic.
Jun 16, 2008 | 1993 Mazda 626
Wiring
This person can assist you with this issue.
tom@xtremesoundandlight.com
May 15, 2008 | Xtreme Sound WMS6100RW 10-Disc CD Changer
Wireing harness
you can buy the proper harness for any vehicle at most stereo shops or even some at WalMart, but you have to hook it to the one that plugs into the radio. The colors on each harness will be identical- just match them up.
Dec 06, 2007 | Xtreme Sound WMS303 CD Player
Earthquake Sound XTREME 900W.5 Car Audio Amplifier Logo
159 people viewed this question
Top Earthquake Sound Car Audio & Video Experts
xxxxxx xxx
Are you an Earthquake Sound Car Audio and Video Expert? Answer questions, earn points and help others
