Question about Canon GL2 Mini DV Digital Camcorder
No Power I have installed 2 charged batteries and the GL2 will not turn on -no power at all. I have the same problem. Has anyone fixed this yet?
    President:
  • 688 Answers
Does the camera work with the a/c power adapter?
If not then it could be something internal.
But if it works with the adapter, your batteries are bad or your battery terminals are dirty.
But just to be safe I would replace the back-up battery which is locate in the screen pocket of the camera. its a CR-2025 Nickel Cadmium battery
also I don;t know if you have a manual but here is a link to one.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=165&modelid=7512#DownloadDetailAct
Scroll down on the page for manuals
Good Luck
Posted on Jun 01, 2009
Canon gl2 fell from tripod. it hasn't turned on since neither from the power outlet or the battery power. i don't see anything broken or scratches. i put the 3v lithium battery in but no power. i took the...
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Jan 23, 2011 | Canon GL2 Mini DV Digital Camcorder
My laptop turn off itself while loading
You may have a loose DC jack:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it's still under warranty, it would be fixed at no charge to you.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Jan 05, 2011 | Toshiba Satellite Pro L300 Notebook
How to chrge it?
You will need a charger like the one listed below. Just remove the battery and place it on the charger.
CA-920 Compact Power Adapter
This is the standard charger and power source for the GL2. It will charge one battery at a time.
Oct 03, 2010 | Canon GL1 Mini DV Digital Camcorder
Battery/Charge Problems with my MC7801u Laptop
try draining power first from system, take battery and adapter out then push and hold power button for 1 min. after try powering your computer with adapter only, then try with battery, if same thing, means you have bad battery.
Jun 11, 2010 | Gateway MC7801u Notebook
Need new LG AC Power Supply Model H-P 220
I had a similr problem It turned out that the power supply cord was not the problem, it was the main battery. Luckily, in 2000, I bought 2 extra main batteries. I took out the old battery and put in one the 2 new unused ones and my machine is working and charging perfectly now.
Jan 06, 2009 | LG Phenom Express
Red light blinking
i was filming, and i tripped and my gl2 hit the ground. it hit the battery kind of hard and now it wont work properly. now when i turn it on, the power light blinks red or green, depending on playback and recording mode. i want to know how i can fix this.
Dec 18, 2008 | Canon GL2 Mini DV Digital Camcorder
Canon GL2 NO POWER, NO FUNCTIONS
Hi david;
There are a few floating around some of the forums but getting one is not going to be easy. I can see if I can find you one. Ill post here if I do.
Feb 04, 2008 | Canon GL2 Mini DV Digital Camcorder
Canon GL2 shuts down automatically while in record mode
Turn off the power saver mode. I did it and it works!
Apr 19, 2007 | Canon GL2 Mini DV Digital Camcorder
Cassette Jam
The most frequent cause of this type situation is not having a power source attached, or a depleted battery pack. Once the power source is available, some models require manually unlatching and opening the cassette compartment cover. When the cover is fully open, the videocassette will eject automatically. Please try the following procedures. 1. Attach the power source to the camcorder correctly or use a fully-charged battery pack. 2. Fully-open the cassette compartment cover until it stops while sliding and holding the OPEN/EJECT switch. The videocassette will eject automatically after a few seconds.
Sep 04, 2005 | Canon GL2 Mini DV Digital Camcorder
Canon GL2 Mini DV Digital Camcorder Logo
186 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
