Need One Soldering Joint Information.Brown Jumper Wire,G3 To Where?
I have A RCA 32V432T chassis# M134C.I don't have service manual or schematic.Question: On the main board,there is 2 jumper wires.Color of these are brown.One wire connects from S1 to S1.The other wire is connected to G3,the other end is not connected to anything.Can you tell me where to solder this end to? Hope you can help!! Thanks
  • 378 Answers
Try Check in Matrix Board this board is located near the neck of CRT (picture TUBE) try to find the G3
Posted on Jun 01, 2009
Vrtical problem
What is the problem you faces with this TV? Vertical rolling? Vertical jitter? Provide more details please.
Jan 04, 2013 | RCA Televison & Video
Rca 32" 32v432t
What is the problem with your RCA TV? Provide some more details, please.
Jun 23, 2012 | RCA TruFlat 27F520T 27" TV
I urgently need a Clarion cd1500r installation manual or wirng color codes
Hello, here is Clarions wire codes.
FRONT Right SPKR: +Gray -Gray/Blk,
FRONT Left SPKR: +White -White/Blk,
REAR Right SPKR: +Purple -Purple/Blk,
REAR Left SPKR: +Green -Green/Blk
Brown Wire = Phone Mute Lead (If applicable)
Yellow Wire = 12V battery lead in (Connect directly to battery)
Red Wire = 12V Ignition wire (Connect to Acc switch)
Blue/White Wire = Amp turn on lead
Black Wire = Chassis Ground
Orange/White Wire = Illumination Lead (Connect to dimmer switch)
Blue Wire = Auto Antenna Lead (lowers power antenna Do not use for Amp Turn on! Use the Blue/White Wire for Amp,EQ, Ect.. turn on wire only
RCA Connectors if applicable:
Black RCA Harness:
White RCA = Rear Audio Left Sub Output 1
Red RCA = Rear Audio Right Sub Output 2
Gray RCA Harness:
White RCA = Front Left Audio Out to amp
Red RCA = Front Right Audio Out to amp
Oct 19, 2010 | Clarion Car Audio & Video
Need wireing diagram for instalation
Hello bulldogwjm,
You can download the Kenwood manual here:
http://www.kenwoodusa.com/Support/Car_Entertainment_Owners_Manuals/#_
Just select the model number from the dropdown and download it.
Hope this helps.
Apr 14, 2009 | Car Audio & Video
Rca tv model 32v432t
This set is not digital tuning and you would need a converter for off-the-air reception. You can get full specs and manual downloads from RCA's site:
http://tv.rca.com/en-us/productdownloads.html?MN=32V432T
Nov 18, 2008 | RCA 32V420T 32" TV
Hd 52w59 how to disable shutdown protection circuit
You never want to disable protection circuits. They are designed to detect malfunctions and prevent further damage by shutting down the power. Trying to defeat this may render the unit useless or a fire hazard. Have unit serviced
Aug 03, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rcaflat screen m134c chassis
Greetings,
Turn the TV OFF
Remove the batteries from the remote
Turn ON the TV
If the issue still persists, check the channel-changer buttons on the TV
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 28, 2008 | RCA Televison & Video
T.V.
Valerie,
That is a M134C chassis - one of the most inexpensive (throw-away) chassis ever built and the so-called v-chip is actaully a function of the micro, short for micro controller Ic. It would be less expensive to replace the entire board, RCA p/n# 268733 which is around $70.00 bucks plus shipping, than to replace just the micro.
You can find them available at Vance Baldwin... Just login as guest and enter thr RCA part number above and order it there.
Putting in an entire chassis is a plug-n-play repair...
Hope this helps.
Bill
Feb 11, 2008 | RCA TruFlat 27F520T 27" TV
RCA color tv,model 27F520T,Chassis M134C
On the tv panel push and hold volume down until volume is all the way down and keep holding, then push the info button on the remote.
Dec 21, 2007 | RCA TruFlat 27F520T 27" TV
Televison & Video Logo
119 people viewed this question
Top Televison & Video Experts
Electro Med Services...
