Question about Koss KS3102 System
Audio in I was just wondering how i would set up the ks3102 system to play sound of my computer everything is connected through coaxial plug. Yes my computer has out and home theatre has in. Is there a setting somewhere to change it to audio in?
SOURCE: KS3102 - Audio Input help!!
Hey I have the same home theater and experience the same audio problem from time to time. What you have to do is use the menu button on the remote and select all the speakers again. For some reason this home theater just turns off the speakers randomly from time to time. Now I'm experiencing problems with video not displaying on different inputs. I'm getting a new home theater, I think this one has had it.
Posted on Nov 11, 2006
SOURCE: Koss KS3102 - Audio Problems
I think I have had the same problem. It seems like the system resets itself randomly. I think if you first turn it on in AV-1 or AV-2 mode, then hit the menu button on the remote, then scroll to ihe 'input'option, hit that then pick 'digital'. Do this for both AV-1&2. UI hope this fixes your problem!
Posted on Jan 28, 2007
snakehead
  • 1074 Answers
SOURCE: koss ks3102 hts turns on but no sound
the system audio output is faulty call a tech and let them look at your set for repair.good luck
Posted on Apr 24, 2007
whitesox
  • 64 Answers
SOURCE: sound but no video
Run your yellow cable from the DVD player directly to the TV in the port connected to the red/white cables. If this is already done or doesnt, work, let me know
Posted on Jul 26, 2007
SOURCE: Home theater system
optical or spidif rca - cable guy
Posted on Sep 01, 2007
How to fit a sound bar to a proscan tv
1) Go the Sound Tab on the remote's Proscan menu
2) Set the system's "Digital Audio Output" to PCM (pulse code modulation)
3) Connect a coaxial cable from the Coaxial "jack" on the back of the TV to the Digital Input "jack" on the back of the sound bar.
It should work now!
Feb 05, 2015 | Proscan Televison & Video
Everything works fine ,no audio on most channels
How do i get surround on tv channels it works on dvd setting but not tv koss model ks3102
Apr 18, 2014 | Koss KS3102 System
Sound no picture
Hi,i suggests there is a loose or broken connection on your video connections between the Koss KS3102 System dvd player and tv. Having sound suggests the optical pickup is fine. If you did not have sound then the Koss KS3102 System dvd player could have been broken. If checking the connections doesn't work, try a cleaning disk.
Take care.
Mar 25, 2011 | Koss KS3102 System
Cant get sound from tv on speakers.
lost remote and cant get sound from ks3102
Dec 16, 2009 | Koss KS3102 System
I have an lg lcd mod#lc427d hdtv how do i hook up an rca rt2280 system to it. i have a dvd player hooked up to tv now using hdmi cables, rca av reciever does not have them...
You can check your dvd player for a coaxial or an optical sound output, then you can plug it directly to your receiver. Those two are the best options after HDMI. Another option is A/V RCA type cable, you´ll need 3 stereo A/V wires, in order to connect the 6 channels. Remember to uncheck the HDMI sound output option on the DVD menu.
Nov 14, 2009 | RCA RT2280 System
MX 3950D Philips - PS3 no sound
Aside from the xbox360 working via the coaxial digital cable. I got the PS3 to work this way.
I had to use the supplied SCART > (Y-video) (Red-Audio) (White-Audio) cable. Basically plugged this in from the PS3 directly to the MX 3950D Aux (Auxiliary) audio input.
On the PS3 audio settings menu, switched from HDMI to the 3rd option SCART.
Turn on the MX 3950D and set to Aux. Bang, got sound again.
I missed this cause I "assumed" the video/audio cable that came with the PS3 was a HDMI to Audio/Video cable, and didn't even see the SCART port in the back of the PS3. So I thought I didn't want to lose 1080p ..etc etc. Anyways. MX 3950D still good =)
May 18, 2009 | Philips MX3950 System
No audio from TV
Run a set of phono cables from tv audio out to input on your system,set system to this input and sound to prologic 2 if you have a surround system and you should have sound for tv through system.
Hope this helps.
CABLE GUY.
Apr 20, 2009 | Audio Players & Recorders
Help with connecting home cinema to xbox
if your tv supports this. go to ebay type in "hdmi" buy one for around $10.00 plug into xbox. set your tv to which port you have ,(if you have more then one). bingo,bango ,your done.
"no hdmi"? and you have com. on your tv. plug corrosponding color plugs for component ,L&R audio plugs .
change tv to comp.( not video) your done
Jan 30, 2009 | Audio Players & Recorders
Won't play sound out of the AV. 1 and 2
You probably have the av inputs set to digital instead of analog. The easiest way to fix this is to turn the theater system on, turn it to one of the the inputs, then hit menu on the remote. You will cycle through some options with the right arrow until you get to "input", which will offer av 1 and av 2, you can select either one with the ok button. then you will get some more options, analog - optical - coaxial, the first one that shows up is the one you've got currently selected. unless you're using one of the other audio input formats, the system should most likely be set to analog. You will probably need to do this with both inputs.
You have to do this every time the system loses power in my experience.
Dec 29, 2008 | Koss KS3102 System
Pioneer vsx d512
All you have to do is connect the coaxial out from pc to any audio i/p at the back of vsx d512.but ensure you select the right channel to play the audio ( eg. tape i/p select tape at front control, aux i/p select the aux at front control )
Aug 03, 2007 | Pioneer VSX-D511 Receiver
Koss KS3102 System Logo
182 people viewed this question
Top Koss Audio Players & Recorders Experts
Steven Wander
Steven Wander
Carlos L. Burgos
Carlos L. Burgos
Michael Galve
Michael Galve
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
